Converting Illumination Output from Nits to W/m² per Channel
Hello everyone,
I’m working with the PtDirectIllumination annotator in Omniverse Simulation and need some clarification on how to interpret and convert its output.
Context:
  • Annotator Output: The PtDirectIllumination annotator provides per-channel (RGB) values in units of nits (cd/m²). (Source: Obtaining Accurate Illuminance Values in IRay/RTX Accurate)
  • Measurement Location: The measurements are taken on the sensor, which suggests they should represent irradiance (W/m²) rather than luminance (cd/m²), as nits are units of luminance.
  • Observation with White Light: When using a white light source, I notice that the annotator outputs equal RGB values. This seems counterintuitive because if the values are in nits (which are weighted by the human eye’s sensitivity), I would expect different values for each channel due to the photopic luminous efficiency function V(λ).
Questions:
  1. Unit Clarification: Does the PtDirectIllumination annotator output represent luminance (cd/m²) or irradiance (W/m²) per channel? If it represents irradiance, why are the units given in nits?
  2. Conversion Method: How can I accurately convert the per-channel output from nits to W/m² per channel, considering the observations above?
  3. Equal RGB Values Explanation: Why does the annotator output equal RGB values with a white light source? Shouldn’t the values be different due to the varying sensitivity of the human eye across different wavelengths?
Thank you!
  1. we output luminance per channel in nits (prior to tone mapping)
  2. to convert something to irradiance from nits for things in focus (or pinhole model)
    E = pixel_area / focal_distance^2 * L
  3. this question ties into the first, we don’t provide response curves, and in turn the material isn’t authored per-wavelength. This goes more into spectral rendering territory
Thank you!
I have a question about unit consistency:
Since L is luminance per channel in nits (cd/m²) and E is irradiance in W/m², should we include the luminous efficacy factor of 683 lm/W to convert luminance to radiance before applying the formula?
This adjustment would account for the difference between photometric and radiometric units.
Here is some updated formulas
Exposure is calculated as H = 1.3361 * cm2_factor * film_iso / (100 * shutter * fstop * fstop)
So if you want to calculate irradiance at the sensor from pixel values, you would first take the sRGB luminance of the pixel, L = 0.2126 * R + 0.7152 * G + 0.0722 * B , which corresponds to H, from which you get E_v = H * shutter / 1.3361 and then E_e = 683 . E_v
  1. in H, I think there is a typo, and it should be multiplied by L
  2. In the formula “E_e = 683 . E_v”, do you mean E_e = E_v / 683?
  3. what do you mean in “cm2_factor”?
  1. Yes
  2. Yes
  3. cm^2 factor is a multiplier of the exposure. It is by default left at 1.
