Converting NvMediaImage with Block Linear surface layout to Pitch Linear surface layout efficiently
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
I would like to learn the suggested way to convert NvMediaImage data with Block-Linear surface layout (for a semi-planar YUV 420) into Pitch-Linear surface layout, by using NvMedia libraries in Drive OS 5.2
The purpose is to be able to directly feed the output of the ISP0/1 into the jpeg encoder, which seems to accept only Pitch-Linear surface layout.
My current approach is doing the following:
 status = NvMedia2DBlitEx(m_i2d,           /* i2d */
	                             imageFrame,      /* dstSurface */
	                             NULL,       /* dstRect */
	                             imagePtr,      /* srcSurface */
	                             NULL,       /* srcRect */
	                             NULL,   /* params */
	                             NULL);              /* paramsOut */
where imageFrame is allocated with NvMediaImageCreateNew , with a pitch linear surface layout, and imagePtr is obtained from the output buffer of ISP0, which is in block linear surface layout.
This seems to work, since I can use imageFrame with NvMediaIJPEFeedFrame. However, I’m not sure if this way of blitting is the most efficient way to use the hardware.
Dear @goksani ,
Is the ask is same as in YUV 420 Semi-planar block linear format to JPEG encoding - #6 by VickNV?
Yes it is.
