Converting Tfrecords for kitti trainval dataset
Hello, when I try to run the tfrecord converting command:
I am using tlt 0.1.4, docker_tag: v3.0-py3.
Spec:
kitti_config {
root_directory_path: “/workspace/tlt-experiments/data/training”
image_dir_name: “image_2”
label_dir_name: “label_2”
image_extension: “.jpg”
partition_mode: “random”
num_partitions: 2
val_split: 14
num_shards: 4
image_directory_path: “/workspace/tlt-experiments/data/training”
!tlt detectnet_v2 dataset_convert
-d $LOCAL_SPECS_DIR/detectnet_v2_tfrecords_kitti_trainval.txt
-o $DATA_DOWNLOAD_DIR/tfrecords/kitti_trainval/kitti_trainval
I get this error.
2021-06-16 20:31:50,344 [INFO] root: Registry: [‘nvcr.io’]
Error: No such container: f516eb619ce39f9d8f96c5a8d9b0975631cb6ea2a0a72e296bc56f92bfcb1fbd
2021-06-16 20:31:58,410 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
File “/home/mzamanov/tlt/lib/python3.6/site-packages/docker/api/client.py”, line 259, in _raise_for_status
response.raise_for_status()
File “/home/mzamanov/tlt/lib/python3.6/site-packages/requests/models.py”, line 941, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: http+docker://localhost/v1.41/containers/f516eb619ce39f9d8f96c5a8d9b0975631cb6ea2a0a72e296bc56f92bfcb1fbd/stop
During handling of the above exception, another exception occurred:
File “/home/mzamanov/tlt/bin/tlt”, line 8, in
sys.exit(main())
File “/home/mzamanov/tlt/lib/python3.6/site-packages/tlt/entrypoint/entrypoint.py”, line 114, in main
args[1:]
File “/home/mzamanov/tlt/lib/python3.6/site-packages/tlt/components/instance_handler/local_instance.py”, line 278, in launch_command
docker_handler.run_container(command)
File “/home/mzamanov/tlt/lib/python3.6/site-packages/tlt/components/docker_handler/docker_handler.py”, line 299, in run_container
self.stop_container()
File “/home/mzamanov/tlt/lib/python3.6/site-packages/tlt/components/docker_handler/docker_handler.py”, line 306, in stop_container
self._container.stop()
File “/home/mzamanov/tlt/lib/python3.6/site-packages/docker/models/containers.py”, line 436, in stop
return self.client.api.stop(self.id, **kwargs)
File “/home/mzamanov/tlt/lib/python3.6/site-packages/docker/utils/decorators.py”, line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File “/home/mzamanov/tlt/lib/python3.6/site-packages/docker/api/container.py”, line 1167, in stop
self._raise_for_status(res)
File “/home/mzamanov/tlt/lib/python3.6/site-packages/docker/api/client.py”, line 261, in _raise_for_status
raise create_api_error_from_http_exception(e)
File “/home/mzamanov/tlt/lib/python3.6/site-packages/docker/errors.py”, line 31, in create_api_error_from_http_exception
raise cls(e, response=response, explanation=explanation)
docker.errors.NotFound: 404 Client Error: Not Found (“No such container: f516eb619ce39f9d8f96c5a8d9b0975631cb6ea2a0a72e296bc56f92bfcb1fbd”)
