convertion euclidean distance function to cuda
hey i have a sequence code for finding euclidean distance:
float euclidean_dist( float *productCoords,  float *coords points)
    int n;
    float ans=0.0;
    for (n=0; n < WEEKS_NUM; n++)
        ans += (productCoords[n]-coords[n]) * (productCoords[n]
     coords[n]);
     return(sqrt(ans));
i want to convert that function to cuda so each time i will call euclidean_dist function will do that in cuda.
how can i do that? i tried everything
This doesn’t look like valid C or C++ code to me. I think an operator (-) got removed between two of your posted lines.
But in any event, as stated in a comment on your cross posting:
https://stackoverflow.com/questions/47351198/convertion-euclidean-distance-function-to-cuda
the design pattern to use here is a parallel reduction. You can find numerous examples and discussions of this on the web, and the CUDA samples include a parallel reduction sample code, along with an accompanying presentation. Google “Mark Harris reduction”
So it seems you are computing the element-wise difference of vectors ‘productCoords’ and ‘points’, then computing the norm of the resulting vector?
If the vectors are quite long, you could apply an element-wise subtraction, then apply cublasSnrm2() to compute the norm of the difference vector, which includes guards against overflow and underflow in intermediate computations. This two-pass approach may not be the fastest, however. And cublasSnrm2() is over-kill if the vectors are short.
