So I am trying to compile and run the convolutionSeparable program. The provided executable file will run, but I was trying to compile it myself since we are doing a project at work that is basically the same thing. I am trying to compile it using nvcc, but it seems it can’t find any of the needed. The error I get is: convolutionSeparable.cu:46:26: error: cutil_inline.h: No such file or directory. Am I just totally missing where this file is located? The command I ran was:
Okay. I think I am just missing a step or something. But when I use the make file I do this:
~/NVIDIA_CUDA_SDK/projects/convolutionSeparable> make ‘convolutionSeparable’
make: *** No rule to make target `convolutionSeparable'. Stop.
I found this error usually means that the target is already made…so I figured it might be what is in the “obj” directory in that folder…but when I tried to run that I got:
