Cooling fan not working after update the new version.
When I run sudo jeton_clocks it show the clock is running but fan is not working to 100% speed.
hello wmindramalw,
I assume you’re working with JetPack-4.4/ l4t-r32.4.3
could you please check the fan configurations through hw monitor and share the results.
for example,
*check the sysnodes of hwmon
cat /sys/class/hwmon/hwmon*/name
*check the current settings and also the measured rpm
cat /sys/class/hwmon/hwmon2/cur_pwm
cat /sys/class/hwmon/hwmon2/rpm_measured
try running
sudo jetson_release
under “jetson_clocks service: <active/inactive>” should tell you if jetson_clocks is working or not.
Mine says inactive, so I can confirm i have this issue as well.
Yes, I have a new update. JetPack-4.4/ l4t-r32.4.3.
Please find the output for your commands.
NOTE: If you want some details to improve the new issue update with my device, I am happy to give details about what you want.
hello wmindramalw,
I’m able to force fan spinning with below commands, could you please also have confirmation.
for example,
echo 255 > /sys/class/hwmon/hwmon2/target_pwm
This is outputs for echo 255 > /sys/class/hwmon/hwmon2/target_pwm
This is output for echo 255 > /sys/class/hwmon/hwmon2/target_pwmfan and sudo sh -c ‘echo 255 > /sys/devices/pwm-fan/target_pwm’.
Fan is working 100% for sudo sh -c ‘echo 255 > /sys/devices/pwm-fan/target_pwm’ command.
This is without running jetson_clocks.
hello wmindramalw,
there’s modification in JetPack-4.4 that fan speed will be controlled based on the temperature,
please enable the options if you would like to enable jetson_clocks also set fan speed to maximum as old behavior.
for example, $ jetson_clocks --fan
you may also check Fan Mode Configuration for more details.
thanks
