Copy struct to device variable
Good evening, everyone. First message here.
I would like to know if it is possible to copy the following structure to a device variable
using cudaMemcpyToSymbol.
This is the struct, it has a fixed array, I don’t know if that’s a problem:
typedef struct esf{
obj3d centro;
FLOAT r;
color col;
FLOAT dif;
FLOAT spec;
FLOAT shi;
FLOAT a;
FLOAT refl;
triang lista_triang[MIN_TRIANGULOS];
long qtd_triangulos;
} esf;
I’m receiveing this error: “Error invalid argument at line 1315 in file raytrace_cudav1.cu”
Please help and sorry for my poor english.
Regards to all…
you should be able to copy the structure with cudaMemcpy(), after having allocated memory for it
Struct* d_struct;
cudaMalloc(&d_struct, sizeof(Struct));
cudaMemcpy(d_struct, h_struct, sizeof(Struct), cudaMemcpyHostToDevice);
I am assuming you wish to copy from host to device
Yes, but then I have to use it as a pointer on my kernel. I want to make that variable global so all my device functions can access it.
I see; I would think that you still use (cudaMalloc and) cudaMemcpy to copy the actual structure; you would use cudaMemcpyToSymbol to merely copy the pointer to the structure
So, you need to use both cudaMemcpy and cudaMemcpyToSymbol
Not so?
Yes, it’s possible to copy a structure to a device variable using cudaMemcpyToSymbol. And you don’t need to do any extra operations with cudaMalloc or cudaMemcpy.
struct my_struct {
__device__ my_struct dev;
int main(){
  my_struct host;
  cudaMemcpyToSymbol(dev, &host, sizeof(my_struct));
Would it not depend on whether you want the whole structure as symbol, or just the address of/ pointer to the structure as symbol?
Actually, guys. What I was trying to do is to allocate an array of those structs and then copy to the GPU. After that, I was trying to set a global device variable to point to that space im memory to which I copied my array of structs.
Anyway, now I’m trying to pass as a parameter to my device functions, but i’m getting another erro “out of bound access”, and I’m pretty sure that the access of the array by the threads are in limit.
Is it possible to cause that error if you have an array of structs, and that struct has an array of other struct?
Thanks for the help, guys.
I believe it is much possible to pass to a kernel function a structure, with the structure containing another structure
The best way to do it, is another story, though
If the grand structure is static for all threads, then you can merely pass one instance of the structure for all threads, otherwise you would need to pay attention to offsets - ensure indexing is appropriate
Also, one would likely pass a pointer to the structure, as opposed to the structure itself
If the grand structure contains another structure, I personally would rather move the child structure out, and merely include a pointer or pointer array to the child structure, under the grand structure
Thus, with regards to your error, I think it is not a question of possibility, but rather one of proper allocation and indexing
Thanks, my friend. I don’t know if my allocation is correct. I’m stuck with that problem since 5 A.M of thursday, rsrsrs.
If you guys could help me figure it out. Here is my code, I’m realy sorry for it be kind messy.
 * Copyright 1993-2012 NVIDIA Corporation.  All rights reserved.
 * Please refer to the NVIDIA end user license agreement (EULA) associated
 * with this source code for terms and conditions that govern your use of
 * this software. Any use, reproduction, disclosure, or distribution of
 * this software and related documentation outside the terms of the EULA
 * is strictly prohibited.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <math.h>
#include "rply.h"
 * This macro checks return value of the CUDA runtime call and exits
 * the application if the call failed.
#define CUDA_CHECK_RETURN(value) {											\
	cudaError_t _m_cudaStat = value;										\
	if (_m_cudaStat != cudaSuccess) {										\
		fprintf(stderr, "Error %s at line %d in file %s\n",					\
				cudaGetErrorString(_m_cudaStat), __LINE__, __FILE__);		\
		exit(1);															\
__host__ __device__ unsigned int bitreverse(unsigned int number) {
	number = ((0xf0f0f0f0 & number) >> 4) | ((0x0f0f0f0f & number) << 4);
	number = ((0xcccccccc & number) >> 2) | ((0x33333333 & number) << 2);
	number = ((0xaaaaaaaa & number) >> 1) | ((0x55555555 & number) << 1);
	return number;
 * CUDA kernel function that reverses the order of bits in each element of the array.
//MACROS
#define FLOAT double
#define QTD_LUZ 1
#define HEIGH 600
#define WIDTH 800
#define TAM_RAIO 100000
#define LIMITE 5
#define ERR_MARGIN		1e-6
#define MIN_TRIANGULOS 10
#define PIx180 0.017453293
typedef struct obj3d{
	FLOAT x,y,z;
} obj3d;
typedef struct color{
	FLOAT r,g,b;
} color;
typedef struct ipoint{
	obj3d pos;
	obj3d vrefl;
	obj3d normal;
	FLOAT dist;
	long id;
	int id_tri;
} ipoint;
typedef struct triang{
	obj3d A;
	obj3d B;
	obj3d C;
	obj3d normal;
	obj3d baricentro;
	color col;
	FLOAT dif;
	FLOAT spec;
	FLOAT shi;
	FLOAT a;
	FLOAT refl;
} triang;
typedef struct esf{
	obj3d centro;
	FLOAT r;
	color col;
	FLOAT dif;
	FLOAT spec;
	FLOAT shi;
	FLOAT a;
	FLOAT refl;
} esf;
typedef struct camera{
	obj3d eye, dir, up;
	FLOAT fov;
} camera;
typedef struct ray{
	obj3d orig, dir;
} ray;
typedef struct light{
	obj3d pos;
	color dif;
	color spec;
} light;
__host__ __device__ obj3d cross_product(obj3d v1, obj3d v2) {
	obj3d res;
	res.x = v1.y * v2.z - v1.z * v2.y;
	res.y = v1.z * v2.x - v1.x * v2.z;
	res.z = v1.x * v2.y - v1.y * v2.x;
	return res;
//MACROS: Operações geométricas básicas
#define DET(A, B, C) ((((A).x * (B).y * (C).z) + ((B).x * (C).y * (A).z) + ((C).x * (A).y * (B).z)) - (((C).x * (B).y * (A).z) + ((A).x * (C).y * (B).z) + ((B).x * (A).y * (C).z)))
#define SQ(x)		((x) * (x))
#define MAX(a, b)	((a) > (b) ? (a) : (b))
#define MIN(a, b)	((a) < (b) ? (a) : (b))
#define DOT(a, b)	((a).x * (b).x + (a).y * (b).y + (a).z * (b).z)
#define NORMALIZE(a)  do {\
	FLOAT len = sqrt(DOT(a, a));\
	(a).x /= len; (a).y /= len; (a).z /= len;\
} while(0);
__device__ color trace(ray raio, int lim, light luz[QTD_LUZ], long ind, esf *esferas, esf *esf_cab, long qtd_nodes);
__device__ color shade_esf(esf esfera, ipoint S1, int lim, ray raio, light luz[QTD_LUZ], long ind, esf *esferas, esf *esf_cab, long qtd_nodes);
__device__ color shade(triang tri, ipoint S1, int lim, ray raio, light luz[QTD_LUZ], long ind, esf *esferas, esf *esf_cab, long qtd_nodes);
FLOAT aspect = 1.333333;
color *h_imagem, *imagem;
obj3d *vertices;
triang *faces;
esf *d_esferas, *h_esferas;
esf *d_esf_cab, *h_esf_cab;
long jind_v=0, jind=0, vert_aux1, vert_aux2, vert_aux3;
long qtd_nodes;
int altura;
__host__ __device__ obj3d rotacao(obj3d aux, int tipo, FLOAT t){
	obj3d A;
	t*=PIx180;
	switch(tipo)
	{	case 0:
			A=aux;
		break;
		case 1:
			(A).y = (((aux).y * (cos(t))) - ((aux).z * (sin(t))));
			(A).z = (((aux).y * (sin(t))) +  ((aux).z * (cos(t))));
		break;
		case 2:
			(A).x = (((aux).x * (cos(t))) +  ((aux).z * (sin(t))));
			(A).z = (-((aux).x * (sin(t))) +  ((aux).z * (cos(t))));
		break;
		case 3:
			(A).x = (((aux).x * (cos(t))) -  ((aux).y * (sin(t))));
			(A).y = (((aux).x * (sin(t))) +  ((aux).y * (cos(t))));
		break;
	return A;
__host__ __device__ obj3d escala(obj3d aux, FLOAT sx, FLOAT sy, FLOAT sz){
	obj3d A;
	(A).x = (aux).x * (sx);
	(A).y = (aux).y * (sy);
	(A).z = (aux).z * (sz);
	return A;
__host__ __device__  obj3d trans(obj3d aux, FLOAT tx, FLOAT ty, FLOAT tz){
	obj3d A;
	(A).x = (aux).x + (tx);
	(A).y = (aux).y + (ty);
	(A).z = (aux).z + (tz);
	return A;
  triang construc_triang(obj3d A, obj3d B, obj3d C,
					 FLOAT r, FLOAT g, FLOAT b, FLOAT a,
					 FLOAT spec, FLOAT dif, FLOAT shi, FLOAT refl){
		triang tri;
		obj3d tri_BA;
		obj3d tri_CA;
		tri.A.x=A.x; tri.A.y=A.y; tri.A.z=A.z;
		tri.B.x=B.x; tri.B.y=B.y; tri.B.z=B.z;
		tri.C.x=C.x; tri.C.y=C.y; tri.C.z=C.z;
		tri.baricentro.x= (A.x + B.x + C.x)/3;
		tri.baricentro.y= (A.y + B.y + C.y)/3;
		tri.baricentro.z= (A.z + B.z + C.z)/3;
		tri.col.r=r; tri.col.g=g; tri.col.b=b; tri.a=a; tri.refl=refl;
		tri.spec=spec;
		tri.dif=dif;
		tri.shi=shi;
		tri_BA.x=tri.B.x - tri.A.x;
		tri_BA.y=tri.B.y - tri.A.y;
		tri_BA.z=tri.B.z - tri.A.z;
		tri_CA.x=tri.C.x - tri.A.x;
		tri_CA.y=tri.C.y - tri.A.y;
		tri_CA.z=tri.C.z - tri.A.z;
		tri.normal=cross_product(tri_BA, tri_CA);
		NORMALIZE(tri.normal);
		return tri;
esf construct_esf(FLOAT x, FLOAT y, FLOAT z, FLOAT raio, FLOAT r, FLOAT g, FLOAT b,  FLOAT a, FLOAT spec, FLOAT dif, FLOAT shi, FLOAT refl){
	esf esf_aux;
	esf_aux.centro.x=x;
	esf_aux.centro.y=y;
	esf_aux.centro.z=z;
	esf_aux.r=raio;
	esf_aux.col.r=r;
	esf_aux.col.g=g;
	esf_aux.col.b=b;
	esf_aux.a=a;
	esf_aux.spec=spec;
	esf_aux.dif=dif;
	esf_aux.shi=shi;
	esf_aux.refl=refl;
	return esf_aux;
void dump_triang(triang tri, int i){
	printf("triangulo %d:\n",i);
	printf("Vertices A(%f,%f,%f) B(%f,%f,%f) C(%f,%f,%f)\n", tri.A.x, tri.A.y, tri.A.z,
														     tri.B.x, tri.B.y, tri.B.z,
														     tri.C.x, tri.C.y, tri.C.z);
    printf("Normal N(%f,%f,%f)\n",tri.normal.x,tri.normal.y,tri.normal.z);
    printf("Baricentro N(%f,%f,%f)\n",tri.baricentro.x,tri.baricentro.y,tri.baricentro.z);
    /*printf("componentes rgba(%f,%f,%f,%f)  spec=%f  shi=%f  dif=%f\n\n", tri.col.r,  tri.col.g,  tri.col.b, tri.a,
																			   tri.spec, tri.shi, tri.dif);*/
void dump_camera(FLOAT m[12], camera cam){
	int i;
	printf("Camera:\n");
	printf("Posicao (%f, %f, %f)   Direcao(%f, %f, %f)   Up(%f, %f, %f)  fov=%f\n\n", cam.eye.x, cam.eye.y, cam.eye.z,
																		              cam.dir.x, cam.dir.y, cam.dir.z,
																		              cam.up.x, cam.up.y, cam.up.z,
																		              cam.fov);
	printf("Matriz Transformação\n");
	for(i=0;i<9;i+=3){
			printf("%f  %f  %f\n", m[i], m[i+1], m[i+2]);
void dump_ray(ray raio, int i){
	printf("Raio %d\n", i);
	printf("O(%f, %f, %f)   Dir(%f, %f, %f)\n",raio.orig.x,raio.orig.y, raio.orig.z,
											 raio.dir.x, raio.dir.y, raio.dir.z);
/* calculate reflection vector */
__device__ obj3d get_vrefletido(obj3d v, obj3d n) {
	obj3d refl;
	FLOAT dot = v.x * n.x + v.y * n.y + v.z * n.z;
	refl.x = -(2.0 * dot * n.x - v.x);
	refl.y = -(2.0 * dot * n.y - v.y);
	refl.z = -(2.0 * dot * n.z - v.z);
	return refl;
 * Função criada para verificar se um raio intercepta um triângulo.
 * Recebe como parâmetros o raio, o triangulo em questão e um ipoint
 * como referência que armazenará os dados do ponto interceptado.
 * A função retorna 1 se ocorreu interceptação e 0 do contrário.
__device__ int intercepta(ray raio, triang tri, ipoint *S){
	//intercepta plano?
	obj3d aux1, aux2, P, u, v, w;
	FLOAT dot1, dot2, dot3, dot4, dot5, dot6, r, s, t;
	aux1.x=tri.A.x - raio.orig.x;//V0 - P0
	aux1.y=tri.A.y - raio.orig.y;
	aux1.z=tri.A.z - raio.orig.z;
	aux2.x=raio.dir.x - raio.orig.x;//P1 - P0
	aux2.y=raio.dir.y - raio.orig.y;
	aux2.z=raio.dir.z - raio.orig.z;
	dot2=DOT(tri.normal,aux2);
	//Não intercepta plano, muito menos triângulo.
	if(dot2==0)
		return 0;
	dot1=DOT(tri.normal,aux1);
	r=dot1/dot2;
	if(r<0)
		return 0;
	P.x = raio.orig.x + r * (aux2.x);
	P.y = raio.orig.y + r * (aux2.y);
	P.z = raio.orig.z + r * (aux2.z);
	w.x=P.x - tri.A.x;
	w.y=P.y - tri.A.y;
	w.z=P.z - tri.A.z;
	u.x=tri.B.x - tri.A.x;//v1-v0
	u.y=tri.B.y - tri.A.y;
	u.z=tri.B.z - tri.A.z;
	v.x=tri.C.x - tri.A.x; //v2-v0
	v.y=tri.C.y - tri.A.y;
	v.z=tri.C.z - tri.A.z;
	dot1= DOT(u,v);
	dot2= DOT(w,v);
	dot3= DOT(v,v);
	dot4= DOT(w,u);
	dot5= DOT(u,u);
	dot6= (dot1*dot1) - (dot5 * dot3);
	s = ((dot1 * dot2) - (dot3 * dot4)) / dot6;
	t = ((dot1 * dot4) - (dot5 * dot2)) / dot6;
	//Reaproveitando variáveis
	u.x=tri.B.x - P.x;
	u.y=tri.B.y - P.y;
	u.z=tri.B.z - P.z;
	v.x=tri.C.x - P.x;
	v.y=tri.C.y - P.y;
	v.z=tri.C.z - P.z;
	w.x=P.x - raio.orig.x;
	w.y=P.y - raio.orig.y;
	w.z=P.z - raio.orig.z;
	S->dist=sqrt(DOT(w, w));
	S->normal=cross_product(u, v);
	if(DOT(raio.dir,S->normal)>0){
		S->normal.x*=-1;
		S->normal.y*=-1;
		S->normal.z*=-1;
	//Intercepta Triângulo
	if(s>=0 && t>=0 && ((s + t) <= 1) && S->dist>ERR_MARGIN){
		NORMALIZE(S->normal);
		NORMALIZE(raio.dir);
		S->vrefl=get_vrefletido(raio.dir,S->normal);
		NORMALIZE(S->vrefl);
		S->pos=P;
		return 1;
	return 0;
__device__ int intercepta_esf(ray raio, esf esfera, ipoint *sp){
	FLOAT a, b, c, d, sqrt_d, t1, t2;
	a = SQ(raio.dir.x) + SQ(raio.dir.y) + SQ(raio.dir.z);
	b = 2.0 * raio.dir.x * (raio.orig.x - esfera.centro.x) +
				2.0 * raio.dir.y * (raio.orig.y - esfera.centro.y) +
				2.0 * raio.dir.z * (raio.orig.z - esfera.centro.z);
	c = SQ(esfera.centro.x) + SQ(esfera.centro.y) + SQ(esfera.centro.z) +
				SQ(raio.orig.x) + SQ(raio.orig.y) + SQ(raio.orig.z) +
				2.0 * (-esfera.centro.x * raio.orig.x - esfera.centro.y * raio.orig.y - esfera.centro.z * raio.orig.z) - SQ(esfera.r);
	if((d = SQ(b) - 4.0 * a * c) < 0.0) return 0;
	sqrt_d = sqrt(d);
	t1 = (-b + sqrt_d) / (2.0 * a);
	t2 = (-b - sqrt_d) / (2.0 * a);
	if((t1 < ERR_MARGIN && t2 < ERR_MARGIN) || (t1 > 1.0 && t2 > 1.0)) return 0;
	if(sp) {
		if(t1 < ERR_MARGIN) t1 = t2;
		if(t2 < ERR_MARGIN) t2 = t1;
		sp->dist = t1 < t2 ? t1 : t2;
		sp->pos.x = raio.orig.x + raio.dir.x * sp->dist;
		sp->pos.y = raio.orig.y + raio.dir.y * sp->dist;
		sp->pos.z = raio.orig.z + raio.dir.z * sp->dist;
		sp->normal.x = (sp->pos.x - esfera.centro.x) / esfera.r;
		sp->normal.y = (sp->pos.y - esfera.centro.y) / esfera.r;
		sp->normal.z = (sp->pos.z - esfera.centro.z) / esfera.r;
		sp->vrefl = get_vrefletido(raio.dir, sp->normal);
		NORMALIZE(sp->vrefl);
	return 1;
 * Função utilizada para calcular a posição do raio no sistema de coordenadas
 * do view frame. Serve tambpem para calcular sua direção. Recebe como parâmetro
 * o valor da linha e coluna corrente da imagem a ser criada, e a quantidade de raios
 * por pixel Por fim, retorna uma estrutura do tipo raio com sua posição e direção
 * calculados, o qual será utilizado na função trace.
__device__ ray get_p_ray(int x, int y, int ray_per_pixel, FLOAT m[12]){
	ray raio;
	obj3d dir_aux;
	raio.dir.x = ((FLOAT) WIDTH) * (((FLOAT) x / (FLOAT) WIDTH) - 0.5);
	raio.dir.y = -(((FLOAT) HEIGH)* (((FLOAT) y / (FLOAT) HEIGH) - 0.5)) ;
	//raio.dir.z = -1;
	dir_aux.x = raio.dir.x * m[0] + raio.dir.y * m[3] - m[6];
	dir_aux.y = raio.dir.x * m[1] + raio.dir.y * m[4] - m[7];
	dir_aux.z = raio.dir.x * m[2] + raio.dir.y * m[5] - m[8];
	dir_aux.x-=m[9];
	dir_aux.y-=m[10];
	dir_aux.z-=m[11];
	NORMALIZE(dir_aux);
	dir_aux.x*=TAM_RAIO;
	dir_aux.y*=TAM_RAIO;
	dir_aux.z*=TAM_RAIO;
	raio.orig.x=m[9];
	raio.orig.y=m[10];
	raio.orig.z=m[11];
	raio.dir.x=dir_aux.x + raio.orig.x;
	raio.dir.y=dir_aux.y + raio.orig.y;
	raio.dir.z=dir_aux.z + raio.orig.z;
	return raio;
* Função para posicionar a câmera. Está receberá os dados necessários
* para posicionar a câmera: eye, traget, up e fov. Com os dados
* eye, target e up calculará o view coordinate frame. Por fim, cria
* uma matriz, a qual é uma variável global, que servirá para posteriormente
* expressar a posição inicial do raio em termos desse sistema de coordenadas.
__device__ void posiciona_camera(FLOAT eye_x, FLOAT eye_y, FLOAT eye_z,
					   FLOAT targ_x, FLOAT targ_y, FLOAT targ_z,
					   FLOAT up_x, FLOAT up_y, FLOAT up_z,
					   FLOAT fov, FLOAT m[12]){
	camera cam;
	obj3d Ortho_cam_i, Ortho_cam_k, Ortho_cam_j;
	cam.eye.x=eye_x; cam.eye.y=eye_y; cam.eye.z=eye_z;
    cam.dir.x=targ_x - eye_x;
    cam.dir.y=targ_y - eye_y;
    cam.dir.z=targ_z - eye_z;
    cam.up.x=up_x; cam.up.y=up_y; cam.up.z=up_z;
    cam.fov=fov;
    Ortho_cam_k = cam.dir;
    NORMALIZE(Ortho_cam_k);
    Ortho_cam_k.x*=-1; Ortho_cam_k.y*=-1; Ortho_cam_k.z*=-1;
    Ortho_cam_i = cross_product(cam.up, Ortho_cam_k);
	Ortho_cam_j = cross_product(Ortho_cam_k, Ortho_cam_i);
	m[0] = Ortho_cam_i.x; m[3] = Ortho_cam_j.x; m[6] = Ortho_cam_k.x;
	m[1] = Ortho_cam_i.y; m[4] = Ortho_cam_j.y; m[7] = Ortho_cam_k.y;
	m[2] = Ortho_cam_i.z; m[5] = Ortho_cam_j.z; m[8] = Ortho_cam_k.z;
    m[9] = cam.eye.x; m[10] = cam.eye.y; m[11] = cam.eye.z;
__device__ void cria_luz(int i, FLOAT dif_r, FLOAT dif_g, FLOAT dif_b,
			  FLOAT spec_r, FLOAT spec_g, FLOAT spec_b,
			  FLOAT x, FLOAT y, FLOAT z, light luz[QTD_LUZ]){
	luz[i].dif.r=dif_r;	    luz[i].dif.g=dif_g;   luz[i].dif.b=dif_b;
	luz[i].spec.r=spec_r;	luz[i].spec.g=spec_g; luz[i].spec.b=spec_b;
	luz[i].pos.x=x;     	luz[i].pos.y=y;   	  luz[i].pos.z=z;
void create_image_ppm(char *f_name){
  int i, j;
  FILE *fp = fopen(f_name, "wb"); /* b - binary mode */
  (void) fprintf(fp, "P6\n%d %d\n255\n", WIDTH, HEIGH);
  static unsigned char cor[3];
  for (i = 0; i < HEIGH; i++)
    for (j = 0; j < WIDTH; j++)
      cor[0] = h_imagem[i * WIDTH + j].r;  /* red */
      cor[1] = h_imagem[i * WIDTH + j].g;  /* green */
      cor[2] = h_imagem[i * WIDTH + j].b; /* blue */
      (void) fwrite(cor, 1, 3, fp);
  (void) fclose(fp);
 * Função criada para caminhar recursivamente a spheere-tree até encontrar
 * o nó que possua a quantidade de triângulos definida como mínima. Depois, procura
 * sequencialmente cada triângulo, e armazena os dados referentes ao que se encontrar
 * mais próximo à origem do raio.
 * Recebe como parâmetro o id da raiz e o raio. Retorna uma estrutura do tipo ipoint que
 * contém dados sobre o ponto do objeto onde ocorreu a interseção.
__device__ ipoint get_esf_node(ray raio, long id_no, esf *esf_cab, long qtd_nodes){
	long i_dir=(id_no+1) * 2; long k;
	long i_esq=(id_no+1) * 2 - 1;
	ipoint S1; S1.dist=TAM_RAIO+100; S1.id=-1;
	ipoint S2; S2.dist=TAM_RAIO+100; S2.id=-1;
	ipoint dummy;
	if(id_no>qtd_nodes){
		return S2;
	if(intercepta_esf(raio, esf_cab[id_no],&dummy)==1){
		if(esf_cab[id_no].qtd_triangulos <= MIN_TRIANGULOS){
			//printf("entreoi id_no=%ld\n",id_no);
			for(k=0;k<esf_cab[id_no].qtd_triangulos; k++){ //Procura triângulos.
				if(intercepta(raio, esf_cab[id_no].lista_triang[k] ,&S1)==1 && S1.dist<S2.dist){
					S2=S1;
					S2.id=id_no;
					S2.id_tri=k;
			return S2;
		else{
			S1=get_esf_node(raio,i_esq,esf_cab, qtd_nodes);
			S2=get_esf_node(raio,i_dir,esf_cab, qtd_nodes);
	else
		return S2;
	if(S1.dist <= S2.dist)
		return S1;
	else
		return S2;
/*__device__ ipoint get_esf_node_simpl(ray raio, long id_no, esf *esf_cab){
	ipoint dummy;
	/*if(i_dir>qtd_nodes)
		return S2;
	if(i_esq>qtd_nodes)
		return S2;
					S2=S1;
					S2.id=id_no;
					S2.id_tri=k;
			return S2;
		else{
			S1=get_esf_node_simpl(raio,i_esq,esf_cab);
			if(S1.dist!=TAM_RAIO+100) return S1;
			S2=get_esf_node_simpl(raio,i_dir,esf_cab);
			if(S2.dist!=TAM_RAIO+100) return S2;
	else
		return S2;
 * Função recursiva utilizada para fazer o trace do raio. Recebe como parâmetro o raio
 * que será rastreado e um limite. O limite serve para limitar a recursão, do contrário
 * o algoritmo poderia entrar em loop infinito. Primeiramente verifica se o raio intercepta algum
 * triângulo presente na spheere-tree através da função get_esf_node, e depois verifica se o raio
 * intercepta alguma esfera através da função intercepta_esf.
 * O objeto que receberá a contribuição de cor será o objeto que estiver mais perto da origem do raio.
__device__ color trace(ray raio, int lim, light luz[QTD_LUZ], long ind, esf *esferas, esf *esf_cab, long qtd_nodes){
	color col;
	int k, v_intercepta=0,  l;
	esf aux2; triang aux1;
	ipoint S1,S2;
	if(lim >= LIMITE) {
		col.r = col.g = col.b = 0.0;
		return col;
	//S2=get_esf_node(raio,0,esf_cab,qtd_nodes);
	v_intercepta=(S2.dist < TAM_RAIO+100);
	/*for(k=0;k<qtd_nodes;k++){
		if(esf_cab[k].qtd_triangulos<=MIN_TRIANGULOS){
			for(l=0;l<esf_cab[k].qtd_triangulos;l++){
				if(intercepta(raio, esf_cab[k].lista_triang[l] ,&S1)==1 &&  S1.dist<S2.dist){
					S2=S1;
					aux1=esf_cab[k].lista_triang[l];
					v_intercepta=1;
	for(k=0;k<ind;k++){ //Procura esferas.
		if(intercepta_esf(raio,esferas[k],&S1)==1 && S1.dist<S2.dist){
			S2=S1;
			aux2=esferas[k];
			v_intercepta=2;
	if(v_intercepta==1){
		//printf("dist=%f\n",S3.dist);
		col=shade(esf_cab[S2.id].lista_triang[S2.id_tri],S2,lim,raio,luz,ind,esferas,esf_cab, qtd_nodes);
	else if(v_intercepta==2){
		col=shade_esf(aux2,S2,lim,raio,luz,ind,esferas,esf_cab, qtd_nodes);
	else {
	return col;
 * Função utilizada para colorir o ponto interceptado quando este pertence a um triangluo.
 * Ela recebe como parâmetro o triângulo interceptado, o ipoint que é os dados referentes ao
 * ponto interceptado, o valor atual da chamada recursiva.
 * A função utiliza o modelo phong para calcular a cor do pixel, ela também verifica se existe alguma
 * obstrução entre o objeto interceptado e a luz para criar somra. Por fim verifica se o objeto
 * em questão possui prpriedade reflexiva. Se sim, chama o trace novamente para rastrear o raio
 * refletido.
 * A função retorna a variável cor que serve como contribuição para um pixel da imagem.
__device__ color shade(triang tri, ipoint S1, int lim, ray raio, light luz[QTD_LUZ], long ind, esf *esferas, esf *esf_cab, long qtd_nodes){
	int i, v_shadow=0, k;
	obj3d luz_dir; FLOAT luz_dist;
	ray shadow_ray;
	color  Id, Is, cor;
	Id.r = Id.g = Id.b = Is.r = Is.g = Is.b = cor.r = cor.g = cor.b = 0;
	for(i=0; i<QTD_LUZ; i++){
		luz_dir.x= luz[i].pos.x - S1.pos.x;
		luz_dir.y= luz[i].pos.y - S1.pos.y;
		luz_dir.z= luz[i].pos.z - S1.pos.z;
		luz_dist=sqrt(DOT(luz_dir,luz_dir));
		shadow_ray.orig = S1.pos;
		shadow_ray.dir = luz_dir;
		S2=get_esf_node(shadow_ray,0,esf_cab,qtd_nodes);
		v_shadow=(S2.dist < luz_dist);
		if(v_shadow==0){
			for(k=0;k<ind;k++){
				if(intercepta_esf(shadow_ray,esferas[k],&S2)==1 && S2.dist < luz_dist && S2.dist > ERR_MARGIN){
					v_shadow=1;
					break;
		if(!v_shadow) {
			NORMALIZE(luz_dir);
			Id.r = tri.dif * (MAX(DOT(S1.normal, luz_dir), 0.0));
			Is.r = tri.spec * (tri.spec > 0.0 ? pow(MAX(DOT(S1.vrefl, luz_dir), 0.0), tri.shi) : 0.0);
			Id.g = Id.b = Id.r;		  Is.g = Is.b = Is.r;
			Id.r *= luz[i].dif.r;   Is.r *= luz[i].spec.r;
			Id.g *= luz[i].dif.g;   Is.g *= luz[i].spec.g;
			Id.b *= luz[i].dif.b;   Is.b *= luz[i].spec.b;
			cor.r += Id.r * tri.col.r + Is.r;
			cor.g += Id.g * tri.col.g + Is.g;
			cor.b += Id.b * tri.col.b + Is.b;
		if(tri.refl > 0.0) {
			ray raio2;
			color rcol;
			raio2.orig = S1.pos;
			raio2.dir = S1.vrefl;
			raio2.dir.x *= TAM_RAIO;
			raio2.dir.y *= TAM_RAIO;
			raio2.dir.z *= TAM_RAIO;
			rcol = trace(raio2, lim + 1,luz, ind, esferas, esf_cab, qtd_nodes);
			cor.r += rcol.r * tri.refl;
			cor.g += rcol.g * tri.refl;
			cor.b += rcol.b * tri.refl;
	return cor;
__device__ color shade_esf(esf esfera, ipoint S1, int lim, ray raio, light luz[QTD_LUZ], long ind, esf *esferas, esf *esf_cab, long qtd_nodes){
	color col;
	ray shadow_ray;
	color  Id, Is;
	Id.r = Id.g = Id.b = Is.r = Is.g = Is.b = col.r = col.g = col.b = 0;
		luz_dir.x=luz[i].pos.x - S1.pos.x;
		luz_dir.y=luz[i].pos.y - S1.pos.y;
		luz_dir.z=luz[i].pos.z - S1.pos.z;
		if(v_shadow==0){
			for(k=0;k<ind;k++){
					v_shadow=1;
					break;
		if(v_shadow==0) {
			NORMALIZE(luz_dir);
			Id.r = esfera.dif * (MAX(DOT(S1.normal, luz_dir), 0.0));
			Is.r = esfera.spec * (esfera.spec > 0.0 ? pow(MAX(DOT(S1.vrefl, luz_dir), 0.0), esfera.shi) : 0.0);
			col.r += Id.r * esfera.col.r + Is.r;
			col.g += Id.g * esfera.col.g + Is.g;
			col.b += Id.b * esfera.col.b + Is.b;
			//col.r=1;
			//col.g=1;
			//col.b=1;
	if(esfera.refl > 0.0) {
		ray raio2;
		color rcol;
		rcol = trace(raio2, lim + 1, luz, ind, esferas, esf_cab, qtd_nodes);
		col.r += rcol.r * esfera.refl;
		col.g += rcol.g * esfera.refl;
		col.b += rcol.b * esfera.refl;
	return col;
 * Função que inicia o processo de renderização. Ela recebe como parâmetro
 * o valor da largura WIDTH (x) da imagem, o valor da altura HEIGH (y) da imagem
 * e a quantidade de pixels que cada saíra de cada pixel. Ela chamará as funções
 * trace que fará o ray tracing, e a função get_p_ray que calculará o raio primário.
 * Por fim, receberá a cor final do processo, e amrazenará suas componentes na matriz
 * imagem, que é uma variável global usada para escrever os valores dos pixels no
 * arquivo ppm.
__global__ void renderiza(int x, int y, int ray_per_pixel, long ind, esf *esferas, esf *esf_cab, color *imagem, long qtd_nodes){
	long indx, i,j;
	color col;
	col.r=0; col.g=0; col.b=0;
	light luz[QTD_LUZ];
	FLOAT m[12]; ray raio;
	cria_luz(0, 1,1,1,  1,1,1,  0,498,0, luz);
	posiciona_camera(300,100,300,  0,0,0,  0,1,0, 1.56746300581, m);
	j = (blockIdx.x * blockDim.x) + threadIdx.x;
	i = (blockIdx.y * blockDim.y) + threadIdx.y;
	indx=i * WIDTH + j;
	__syncthreads();
	if(j<WIDTH && i<HEIGH){
		raio=get_p_ray(j,i,j, m);
		col=trace(raio,0, luz, ind, esferas, esf_cab, qtd_nodes);
		imagem[indx].r = MIN(col.r,1) * 255;
		imagem[indx].g = MIN(col.g,1) * 255;
		imagem[indx].b = MIN(col.b,1) * 255;
#define pivot_index() (begin+(end-begin)/2)
#define swap(a,b,t) ((t)=(a),(a)=(b),(b)=(t))
void sort(triang array[], long begin, long end, int mod) {
   /*** Use of static here will reduce memory footprint, but will make it thread-unsafe ***/
   static triang pivot;
   static triang t;     /* temporary variable for swap */
   if (end > begin) {
      long l = begin + 1;
      long r = end;
      swap(array[begin], array[pivot_index()], t); /*** choose arbitrary pivot ***/
      pivot = array[begin];
      while(l < r) {
		switch(mod){
			case 0:
				if (array[l].baricentro.x <= pivot.baricentro.x) {
					l++;
				} else {
				while(l < --r && array[r].baricentro.x >= pivot.baricentro.x) /*** skip superfluous swaps ***/
				swap(array[l], array[r], t);
				break;
			case 1:
				if (array[l].baricentro.y <= pivot.baricentro.y) {
					l++;
				} else {
				while(l < --r && array[r].baricentro.y >= pivot.baricentro.y) /*** skip superfluous swaps ***/
				break;
			case 2:
				if (array[l].baricentro.z <= pivot.baricentro.z) {
					l++;
				} else {
				while(l < --r && array[r].baricentro.z >= pivot.baricentro.z) /*** skip superfluous swaps ***/
				break;
      l--;
      swap(array[begin], array[l], t);
      sort(array, begin, l, mod);
      sort(array, r, end, mod);
#undef swap
#undef pivot_index
esf bound_ball(long begin, long end, long qtd_triangulos){
	obj3d C, dPx, dPy, dPz, dP, Paux;
	FLOAT rad, rad2, dx2, dy2, dz2, dist, dist2;
	FLOAT xmin, xmax, ymin, ymax, zmin, zmax;
    long  Pxmin, Pxmax, Pymin, Pymax, Pzmin, Pzmax;
	long qtd_pontos = qtd_triangulos * 3;
	obj3d *P;
	long i,j=0;
	esf B;
	P= (obj3d*) malloc(sizeof(obj3d) * qtd_pontos);
	for(i=begin;i<=end;i++){
		P[j]=faces[i].A;
		P[j+1]=faces[i].B;
		P[j+2]=faces[i].C;
		j+=3;
	xmin = xmax = P[0].x;
    ymin = ymax = P[0].y;
    zmin = zmax = P[0].z;
    Pxmin = Pxmax = Pymin = Pymax = Pzmin = Pzmax = 0;
	for(i=0;i<j;i++){
		if (P[i].x < xmin) {
            xmin = P[i].x;
            Pxmin = i;
        else if (P[i].x > xmax) {
            xmax = P[i].x;
            Pxmax = i;
        if (P[i].y < ymin) {
            ymin = P[i].y;
            Pymin = i;
        else if (P[i].y > ymax) {
            ymax = P[i].y;
            Pymax = i;
		if (P[i].z < zmin) {
            zmin = P[i].z;
            Pzmin = i;
        else if (P[i].z	> zmax) {
            zmax = P[i].z;
            Pzmax = i;
	dPx.x = P[Pxmax].x - P[Pxmin].x;
	dPx.y = P[Pxmax].y - P[Pxmin].y;
	dPx.z = P[Pxmax].z - P[Pxmin].z;
	dPy.x = P[Pymax].x - P[Pymin].x;
	dPy.y = P[Pymax].y - P[Pymin].y;
	dPy.z = P[Pymax].z - P[Pymin].z;
	dPz.x = P[Pzmax].x - P[Pzmin].x;
	dPz.y = P[Pzmax].y - P[Pzmin].y;
	dPz.z = P[Pzmax].z - P[Pzmin].z;
    dx2 = DOT(dPx,dPx);
    dy2 = DOT(dPy,dPy);
	dz2 = DOT(dPz,dPz);
    if (dx2 >= dy2 && dx2 >= dz2) {
        C.x = P[Pxmin].x + (dPx.x / 2.0);
        C.y = P[Pxmin].y + (dPx.y / 2.0);
        C.z = P[Pxmin].z + (dPx.z / 2.0);
        Paux.x=P[Pxmax].x  - C.x;
        Paux.y=P[Pxmax].y  - C.y;
        Paux.z=P[Pxmax].z  - C.z;
		rad2 = DOT(Paux,Paux);
    else if (dy2 >= dx2 && dy2 >= dz2){
        C.x = P[Pymin].x + (dPy.x / 2.0);
        C.y = P[Pymin].y + (dPy.y / 2.0);
        C.z = P[Pymin].z + (dPy.z / 2.0);
        Paux.x=P[Pymax].x  - C.x;
        Paux.y=P[Pymax].y  - C.y;
        Paux.z=P[Pymax].z  - C.z;
	else {
		C.x = P[Pzmin].x + (dPz.x / 2.0);
		C.y = P[Pzmin].y + (dPz.y / 2.0);
		C.z = P[Pzmin].z + (dPz.z / 2.0);
        Paux.x=P[Pzmax].x  - C.x;
        Paux.y=P[Pzmax].y  - C.y;
        Paux.z=P[Pzmax].z  - C.z;
    rad = sqrt(rad2);
	for (i=0; i<j; i++) {
		dP.x = P[i].x - C.x;
        dP.y = P[i].y - C.y;
        dP.z = P[i].z - C.z;
		dist2 = DOT(dP, dP);
		if (dist2 <= rad2)
            continue;
        dist = sqrt(dist2);
        rad = (rad + dist) / 2.0;
        rad2 = rad * rad;
        C.x = C.x + ((dist-rad)/dist) * dP.x;
        C.y = C.y + ((dist-rad)/dist) * dP.y;
        C.z = C.z + ((dist-rad)/dist) * dP.z;
	B=construct_esf(C.x,C.y,C.z,rad,  0,1,0,1, 1,1,1,0);
	B.qtd_triangulos=qtd_triangulos;
    free(P);
    return B;
int cria_arv_esf(long ini, long fim, long qtd_triang, int mod, long id_no){
		int i,j=0;
		long aux=fim - ini + 1;
		/*if(ini>=fim){
			printf("DEU RUIM\n\n\n\n\n");
			return 1;
		if(qtd_triang<=MIN_TRIANGULOS){
			h_esf_cab[id_no]=bound_ball(ini,fim, aux);
			for(i=ini;i<=fim;i++){
				h_esf_cab[id_no].lista_triang[j]=faces[i];
				j++;
			return 0;
		sort(faces,ini,fim,mod);
		//printf("sorted...\n");
		h_esf_cab[id_no]=bound_ball(ini,fim,aux);
		//printf("balls\n");
		mod = mod % 2;
		mod++;
		qtd_triang=aux/2;
		cria_arv_esf(ini, fim - qtd_triang, qtd_triang, mod, 2 * (id_no + 1) - 1);
		cria_arv_esf(ini + qtd_triang,fim, qtd_triang, mod, 2 * (id_no + 1));
		return 0;
void montar_chao(long *ntriangles){
	obj3d A1,B1,C1;
	long paredes=6;
	long triangulos=paredes*2;
	FLOAT r_parede=0.5, g_parede=0.4, b_parede=0.6, a_parede=0;
	FLOAT spec_parede=0.0, dif_parede=1,  shin_parede=0.0, refl_parede=1;
	FLOAT r_chao=1, g_chao=1, b_chao=1, a_chao=0;
	FLOAT spec_chao=0, dif_chao=1,  shin_chao=0, refl_chao=0;
	FLOAT r_teto=1, g_teto=0, b_teto=0, a_teto=0;
	FLOAT spec_teto=0, dif_teto=1,  shin_teto=0, refl_teto=0;
	*ntriangles+=triangulos ;
	faces = (triang*) malloc(sizeof(triang) * (*ntriangles));
	jind=triangulos;
	//chão
	A1.x=-1000; A1.y=-2; A1.z=-1000;
	B1.x=-1000; B1.y=-2; B1.z=1000;
	C1.x=1000;  C1.y=-2;  C1.z=-1000;
	faces[0]=construc_triang(A1,B1,C1,  r_chao, g_chao, b_chao, a_chao, spec_chao, dif_chao, shin_chao, refl_chao);
	faces[1]=construc_triang(escala(A1,-1,1,-1),escala(B1,-1,1,-1),escala(C1,-1,1,-1),
	//parede 2
	A1.x=-1000;  A1.y=-1000; A1.z=500;
	B1.x=1000;   B1.y=1000;  B1.z=500;
	C1.x=1000;   C1.y=-1000; C1.z=500;
	faces[2]=construc_triang(A1,B1,C1,  r_parede, g_parede, b_parede, a_parede, spec_parede, dif_parede, shin_parede, refl_parede);
	faces[3]=construc_triang(escala(A1,-1,-1,1),escala(B1,-1,-1,1),escala(C1,-1,-1,1),
	//parede 3
    A1.x=-500;  A1.y=-1000; A1.z=-1000;
    B1.x=-500; B1.y=1000; B1.z=-1000;
    C1.x=-500; C1.y=1000; C1.z=1000;
	faces[4]=construc_triang(A1,B1,C1, r_parede, g_parede, b_parede, a_parede, spec_parede, dif_parede, shin_parede, refl_parede);
	faces[5]=construc_triang(escala(A1,1,-1,-1),escala(B1,1,-1,-1),escala(C1,1,-1,-1),
	//teto
	A1.x=-1000; A1.y=500; A1.z=-1000;
	B1.x=-1000; B1.y=500; B1.z=1000;
	C1.x=1000;  C1.y=500;  C1.z=-1000;
	faces[6]=construc_triang(B1,A1,C1,  r_teto, g_teto, b_teto, a_teto, spec_teto, dif_teto, shin_teto, refl_teto);
	faces[7]=construc_triang(escala(B1,-1,1,-1),escala(A1,-1,1,-1),escala(C1,-1,1,-1),
	//parede 2 - complemento
	A1.x=-1000;  A1.y=-1000; A1.z=-500;
	B1.x=1000;   B1.y=1000;  B1.z=-500;
	C1.x=1000;   C1.y=-1000; C1.z=-500;
	faces[8]=construc_triang(B1,A1,C1,  r_parede, g_parede, b_parede, a_parede, spec_parede, dif_parede, shin_parede, refl_parede);
	faces[9]=construc_triang(escala(B1,-1,-1,1),escala(A1,-1,-1,1),escala(C1,-1,-1,1),
	//parede 3 - complemento
	A1.x=500;  A1.y=-1000; A1.z=-1000;
    B1.x=500; B1.y=1000; B1.z=-1000;
    C1.x=500; C1.y=1000; C1.z=1000;
	faces[10]=construc_triang(B1,A1,C1, r_parede, g_parede, b_parede, a_parede, spec_parede, dif_parede, shin_parede, refl_parede);
	faces[11]=construc_triang(escala(B1,1,-1,-1),escala(A1,1,-1,-1),escala(C1,1,-1,-1),
static int vertex_cb(p_ply_argument argument) {
    long eol;
    ply_get_argument_user_data(argument, NULL, &eol);
    switch (eol) {
        case 0:
			vertices[jind_v].x=ply_get_argument_value(argument);
			break;
        case 1:
            vertices[jind_v].y=ply_get_argument_value(argument);
            break;
        case 2:
            vertices[jind_v].z=ply_get_argument_value(argument);
            jind_v++;
            break;
        default:
            break;
    return 1;
static int face_cb(p_ply_argument argument) {
    long length, value_index;
    ply_get_argument_property(argument, NULL, &length, &value_index);
    switch (value_index) {
        case 0:
			vert_aux1=ply_get_argument_value(argument);
			//printf("caso %ld Indice %ld\n", value_index, vert_aux1);
			break;
        case 1:
            vert_aux2=ply_get_argument_value(argument);
            //printf("caso %ld Indice %ld\n", value_index, vert_aux2);
            break;
        case 2:
            vert_aux3=ply_get_argument_value(argument);
            faces[jind]=construc_triang(trans(escala(vertices[vert_aux1],1000,1000,1000),0,30,0),
									    trans(escala(vertices[vert_aux2],1000,1000,1000),0,30,0),
										trans(escala(vertices[vert_aux3],1000,1000,1000),0,30,0),
										1,1,1,1 ,0,1,1,0);
			jind++;
            break;
        default:
            break;
    return 1;
int ler_ply(char *fname) {
    long nvertices, ntriangles;
    jind_v=0; jind=0;
    p_ply ply = ply_open(fname, NULL, 0, NULL);
    if (!ply) return 1;
    if (!ply_read_header(ply)) return 1;
    nvertices = ply_set_read_cb(ply, "vertex", "x", vertex_cb, NULL, 0);
    ply_set_read_cb(ply, "vertex", "y", vertex_cb, NULL, 1);
    ply_set_read_cb(ply, "vertex", "z", vertex_cb, NULL, 2);
    ntriangles = ply_set_read_cb(ply, "face", "vertex_indices", face_cb, NULL, 0);
    vertices = (obj3d*) malloc(sizeof(obj3d) * nvertices);
    montar_chao(&ntriangles);
    printf("%ld\n%ld\n", nvertices, ntriangles);
    if (!ply_read(ply)) return 1;
    ply_close(ply);
    free(vertices);
	jind--;
	return 0;
long ler_arq_esferas(){
	int i;
	long ind=1;
	h_esferas=(esf*) malloc(sizeof(esf) * ind);
	for(i=0;i<ind;i++){
		h_esferas[i]=construct_esf(200,100,0,50,  0,0,1,1  ,0,1,0,0);
	return ind;
long get_qtd_nos(){
	long i=jind, h=0, qtd_nos;
	while(i>=10){
		i/=2;
		h++;
	altura=h;
	qtd_nos= (pow(2,h) - 1) * 2 +1;
	h_esf_cab = (esf*) calloc(qtd_nos,sizeof(esf));
	printf("\nqtd_nos=%ld   h=%ld\n", qtd_nos, h);
	return qtd_nos;
int main(int argc, char** argv){
	long ind, qtd_nos;
	h_imagem=(color*) calloc(HEIGH * WIDTH,sizeof(color));
	ler_ply("bun_zipper.ply");
	ind=ler_arq_esferas();
	qtd_nos=get_qtd_nos();
	cria_arv_esf(0,jind,jind,0,0);
	dim3 threadsPerBlock(16, 16);
	dim3 numBlocks((WIDTH/threadsPerBlock.x)+1, (HEIGH/threadsPerBlock.y)+1);
	CUDA_CHECK_RETURN(cudaMalloc((void**) &d_esf_cab, qtd_nos * sizeof(esf)));
	CUDA_CHECK_RETURN(cudaMalloc((void**) &d_esferas, ind * sizeof(esf)));
	CUDA_CHECK_RETURN(cudaMalloc((void**) &imagem, sizeof(color) * HEIGH * WIDTH));
	CUDA_CHECK_RETURN(cudaMemcpy(d_esf_cab, h_esf_cab, qtd_nos * sizeof(esf), cudaMemcpyHostToDevice));
	CUDA_CHECK_RETURN(cudaMemcpy(d_esferas, h_esferas, ind * sizeof(esf), cudaMemcpyHostToDevice));
	printf("comecei a renderizar\n");
	renderiza <<<numBlocks,threadsPerBlock>>> (WIDTH,HEIGH,1, ind, d_esferas, d_esf_cab, imagem, qtd_nos);
	printf("terminei de renderizar\n");
	cudaDeviceSynchronize();
	CUDA_CHECK_RETURN(cudaMemcpy(h_imagem, imagem, HEIGH * WIDTH * sizeof(color), cudaMemcpyDeviceToHost));
	printf("comecei a criar imagem\n");
	create_image_ppm("teste13_64_cuda.ppm");
	printf("terminei criar imagem\n");
	cudaFree(d_esferas);
	cudaFree(d_esf_cab);
	cudaFree(imagem);
	free(h_imagem);
	free(h_esf_cab);
	free(faces);
	free(h_esferas);
	//sort(faces,0,jind,2);
	//bound_ball(0,jind, jind, esf_cab);
	/*for(i=0;i<qtd_nodes;i++){
		printf("esf_node[%d].qtd_triangulos=%ld     raio=%f   centro(%f,%f,%f)\n",i,esf_cab[i].qtd_triangulos,esf_cab[i].r,
															esf_cab[i].centro.x, esf_cab[i].centro.y, esf_cab[i].centro.z);
	/*for(i=0; i<jind; i++)
		dump_triang(faces[i],i);*/
	//printf("esfera: centro(%f, %f, %f) raio:%f\n", esf_cab->centro.x, esf_cab->centro.y, esf_cab->centro.z, esf_cab->r);
	return 0;
On my main function I do the allocations for the GPU, can you see something wrong there?
Thank you very much for the help you have be given to me.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <math.h>
#include "rply.h"
		exit(1);															\
	return number;
//MACROS
#define QTD_LUZ 1
#define HEIGH 600
#define WIDTH 800
#define LIMITE 5
	FLOAT x,y,z;
} obj3d;
	FLOAT r,g,b;
} color;
	obj3d pos;
	obj3d vrefl;
	obj3d normal;
	FLOAT dist;
	long id;
	int id_tri;
} ipoint;
	obj3d A;
	obj3d B;
	obj3d C;
	obj3d normal;
	obj3d baricentro;
	color col;
	FLOAT dif;
	FLOAT spec;
	FLOAT shi;
	FLOAT a;
	FLOAT refl;
} triang;
typedef struct esf{
	obj3d centro;
	FLOAT r;
	color col;
	FLOAT dif;
	FLOAT spec;
	FLOAT shi;
	FLOAT a;
	FLOAT refl;
} esf;
	obj3d eye, dir, up;
	FLOAT fov;
} camera;
typedef struct ray{
	obj3d orig, dir;
} ray;
	obj3d pos;
	color dif;
	color spec;
} light;
	obj3d res;
	return res;
} while(0);
obj3d *vertices;
triang *faces;
long qtd_nodes;
int altura;
	obj3d A;
	t*=PIx180;
	switch(tipo)
	{	case 0:
			A=aux;
		break;
		case 1:
		break;
		case 2:
		break;
		case 3:
		break;
	return A;
	obj3d A;
	return A;
	obj3d A;
	return A;
		triang tri;
		obj3d tri_BA;
		obj3d tri_CA;
		tri.spec=spec;
		tri.dif=dif;
		tri.shi=shi;
		return tri;
	esf esf_aux;
	esf_aux.centro.x=x;
	esf_aux.centro.y=y;
	esf_aux.centro.z=z;
	esf_aux.r=raio;
	esf_aux.col.r=r;
	esf_aux.col.g=g;
	esf_aux.col.b=b;
	esf_aux.a=a;
	esf_aux.spec=spec;
	esf_aux.dif=dif;
	esf_aux.shi=shi;
	esf_aux.refl=refl;
	return esf_aux;
	int i;
																		              cam.fov);
	for(i=0;i<9;i+=3){
	obj3d refl;
	return refl;
	//intercepta plano?
	if(dot2==0)
		return 0;
	r=dot1/dot2;
	if(r<0)
		return 0;
	w.x=P.x - tri.A.x;
	w.y=P.y - tri.A.y;
	w.z=P.z - tri.A.z;
	dot1= DOT(u,v);
	dot2= DOT(w,v);
	dot3= DOT(v,v);
	dot4= DOT(w,u);
	dot5= DOT(u,u);
	u.x=tri.B.x - P.x;
	u.y=tri.B.y - P.y;
	u.z=tri.B.z - P.z;
	v.x=tri.C.x - P.x;
	v.y=tri.C.y - P.y;
	v.z=tri.C.z - P.z;
		S->normal.x*=-1;
		S->normal.y*=-1;
		S->normal.z*=-1;
		S->pos=P;
		return 1;
	return 0;
	sqrt_d = sqrt(d);
	if(sp) {
	return 1;
	ray raio;
	obj3d dir_aux;
	//raio.dir.z = -1;
	dir_aux.x-=m[9];
	dir_aux.y-=m[10];
	dir_aux.z-=m[11];
	NORMALIZE(dir_aux);
	raio.orig.x=m[9];
	raio.orig.y=m[10];
	raio.orig.z=m[11];
	return raio;
	camera cam;
    cam.fov=fov;
  int i, j;
  (void) fclose(fp);
	ipoint dummy;
		return S2;
					S2=S1;
					S2.id=id_no;
					S2.id_tri=k;
			return S2;
		else{
	else
		return S2;
		return S1;
	else
		return S2;
	ipoint dummy;
		return S2;
	if(i_esq>qtd_nodes)
		return S2;
					S2=S1;
					S2.id=id_no;
					S2.id_tri=k;
			return S2;
		else{
	else
		return S2;
	color col;
	ipoint S1,S2;
	if(lim >= LIMITE) {
		return col;
					S2=S1;
					v_intercepta=1;
			S2=S1;
			aux2=esferas[k];
			v_intercepta=2;
	else {
	return col;
 * refletido.
	ray shadow_ray;
	color  Id, Is, cor;
		if(v_shadow==0){
			for(k=0;k<ind;k++){
					v_shadow=1;
					break;
		if(!v_shadow) {
			NORMALIZE(luz_dir);
			ray raio2;
			color rcol;
	return cor;
	color col;
	ray shadow_ray;
	color  Id, Is;
		if(v_shadow==0){
			for(k=0;k<ind;k++){
					v_shadow=1;
					break;
		if(v_shadow==0) {
			NORMALIZE(luz_dir);
			//col.r=1;
			//col.g=1;
			//col.b=1;
		ray raio2;
		color rcol;
	return col;
 * arquivo ppm.
	long indx, i,j;
	color col;
	light luz[QTD_LUZ];
	indx=i * WIDTH + j;
	__syncthreads();
   if (end > begin) {
      long l = begin + 1;
      long r = end;
      while(l < r) {
		switch(mod){
			case 0:
					l++;
				} else {
				break;
			case 1:
					l++;
				} else {
				break;
			case 2:
					l++;
				} else {
				break;
      l--;
#undef swap
#undef pivot_index
	obj3d *P;
	long i,j=0;
	esf B;
		P[j]=faces[i].A;
		P[j+1]=faces[i].B;
		P[j+2]=faces[i].C;
		j+=3;
	for(i=0;i<j;i++){
            xmin = P[i].x;
            Pxmin = i;
            xmax = P[i].x;
            Pxmax = i;
            ymin = P[i].y;
            Pymin = i;
            ymax = P[i].y;
            Pymax = i;
            zmin = P[i].z;
            Pzmin = i;
            zmax = P[i].z;
            Pzmax = i;
    dx2 = DOT(dPx,dPx);
    dy2 = DOT(dPy,dPy);
	dz2 = DOT(dPz,dPz);
	else {
    rad = sqrt(rad2);
		if (dist2 <= rad2)
            continue;
        dist = sqrt(dist2);
        rad2 = rad * rad;
    free(P);
    return B;
		int i,j=0;
		/*if(ini>=fim){
			return 1;
				j++;
			return 0;
		mod = mod % 2;
		mod++;
		qtd_triang=aux/2;
		return 0;
	obj3d A1,B1,C1;
	long paredes=6;
	jind=triangulos;
	//chão
	//parede 2
	//parede 3
	//teto
    long eol;
    switch (eol) {
        case 0:
			break;
        case 1:
            break;
        case 2:
            jind_v++;
            break;
        default:
            break;
    return 1;
        case 0:
			break;
        case 1:
            break;
        case 2:
										1,1,1,1 ,0,1,1,0);
			jind++;
            break;
        default:
            break;
    return 1;
    jind_v=0; jind=0;
    if (!ply) return 1;
    ply_close(ply);
    free(vertices);
	jind--;
	return 0;
	int i;
	long ind=1;
	for(i=0;i<ind;i++){
	return ind;
long get_qtd_nos(){
	while(i>=10){
		i/=2;
		h++;
	altura=h;
	return qtd_nos;
	long ind, qtd_nos;
	cudaFree(imagem);
	free(h_imagem);
	free(h_esf_cab);
	free(faces);
	free(h_esferas);
	return 0;
Hi, i’m receveing a bunch of this messages when i run my program with cuda memchek
========= CUDA-MEMCHECK
========= Invalid local write of size 4
========= at 0x000084f8 in renderiza(int, long, esf*, esf*, color*, long)
========= by thread (15,15,0) in block (0,0,0)
========= Address 0x00fff884 is out of bounds
========= Device Frame:renderiza(int, long, esf*, esf*, color*, long) (renderiza(int, long, esf*, esf*, color*, long) : 0x8dd0)
========= Device Frame:renderiza(int, long, esf*, esf*, color*, long) (renderiza(int, long, esf*, esf*, color*, long) : 0x560)
========= Saved host backtrace up to driver entry point at kernel launch time
========= Host Frame:/usr/lib/libcuda.so (cuLaunchKernel + 0x331) [0x1382e1]
========= Host Frame:raytrace_cudaV2 [0x23d18]
========= Host Frame:raytrace_cudaV2 [0x44653]
========= Host Frame:raytrace_cudaV2 [0x7c7d]
========= Host Frame:raytrace_cudaV2 [0x7b0f]
========= Host Frame:raytrace_cudaV2 [0x7b54]
========= Host Frame:raytrace_cudaV2 [0x78bb]
========= Host Frame:/lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main + 0xf5) [0x21ec5]
========= Host Frame:raytrace_cudaV2 [0x2aa9]
