now , i am testing the transfer data between gps on the cluster,but it always print some error
the code is :
real,device,allocatable :: d_0(:),d_1(:)
istat = cudaSetDevice(0)
istat = cudaGetDevice(j)
print * ,‘the first j is’ ,j
allocate(d_0(1:100))
istat = cudaSetDevice(1)
print * ,‘the second j is’ ,j
allocate(d_1(1:100))
!call test_kernel<<<1,100>>>(d_0)
istat =cudaDeviceCanAccessPeer( canAccessPeer, 0, 1 )
istat =cudaDeviceEnablePeerAccess (1,0)
print * ,'cudaDeviceEnablePeerAccess's istat is ',istat
write(fh,“('cudaDeviceEnablePeerAccess is ',i3)”) istat
!istat = cudaMemcpyPeer(d_1, 1, d_0, 0,100) !This method fail
istat = cudaMemcpy2D(d_1(:),100, d_0(:),100,100,100) !This method fail too
end subroutine test_diff_kernel_cop
the print on the log:
myid is 0
0.log
0
devicenum is 2
the first j is 0
the second j is 1
cudaDeviceEnablePeerAccess’s istat is 0
[enode25:454139] *** Process received signal ***
[enode25:454139] Signal: Segmentation fault (11)
[enode25:454139] Signal code: Address not mapped (1)
[enode25:454139] Failing at address: (nil)
[enode25:454139] [ 0] /usr/lib/gcc/x86_64-redhat-linux/4.8.5/…/…/…/…/lib64/libpthread.so.0(+0xf100)[0x2ad0e726c100]
[enode25:454139] [ 1] ./a.exe[0x403397]
[enode25:454139] [ 2] ./a.exe[0x40295a]
[enode25:454139] [ 3] ./a.exe[0x402316]
[enode25:454139] [ 4] /usr/lib/gcc/x86_64-redhat-linux/4.8.5/…/…/…/…/lib64/libc.so.6(__libc_start_main+0xf5)[0x2ad0e810cb15]
[enode25:454139] [ 5] ./a.exe[0x402189]
You will need to share a lot more information in order to provide any kind of guidance. What libraries, what are the servers, etc…
