Copying device memory into texture memory
Hi I was wondering if there is an easy way to copy device memory directly into texture memory?
So I have an image I am working on via cuda kernels to preform different operations. Currently the output is being placed into an array in the following format:
__device__ ushort *image;
So is there anyway that I can easily transfer it to a texture memory, which I have in the following format:
texture<ushort, 2, cudaReadModeElementType> texImage;
cudaChannelFormatDesc descTexImage = cudaCreateChannelDesc<ushort>();
Any assistance or direction would be greatly appreciated
The usual approach is to map a texture to existing storage using cudaBindTexture(), no need to copy data.
Hi, thank you for the reply, I have tried that and am stuck at getting it to work, I mean it runs with no errors, but the output is not what is expected.
Currently all my texture data is being read as 0.
Data Declarations:
ushort *host_Image;
__device__ ushort *dev_Image;
int imageW;
int imageH;
I am doing the following:
cudaBindTexture2D(0, texImage, host_Image, descTexImage,
                        imageW, imageH, imageW*sizeof(ushort));
This is after I link the host_Image ptr to the device image ptr
cudaMalloc((void**)&host_Image, imageW * imageH * sizeof(ushort));
cudaMemcpyToSymbol(dev_Image, &host_Image, sizeof(imageW * imageH * sizeof(ushort)));
I am accessing the Data via:
ushort pixel = tex2D(texImage, x, y);
Don’t forget to add an offset of 0.5 to x-coordinate (to get the center of the pixel).
see http://stackoverflow.com/questions/10643790/texture-memory-tex2d-basics
here is an working example with texture obejcts
http://devblogs.nvidia.com/parallelforall/cuda-pro-tip-kepler-texture-objects-improve-performance-and-flexibility/
