copying memory, devicetohost and hosttodevice
hi everyone,
i am trying to create a matrix and trying to copy that matrix into device memory, manipulate it and send it back out to the host to check if i sent my pointers properly…but i can’t for the life of me figure out what is wrong with my code.
i’m either getting all zero’s back or random numbers back…
can someone take a look and help me out? thanks!
[codebox]global void transpose(int* matrix){
//int i = threadIdx.x;
matrix[threadIdx.x] = 1;
/* HelloCUDA */
int main(int argc, char* argv)
if(!InitCUDA()) {
	return 0;
int N = 15;
int rows, columns, matrix_length, stop;
size_t pitch;
printf("CUDA Matrix Transpose v1.0\n");
printf("===========================\n");
printf("This program will randomly generate numbers for a M x N matrix and transpose it.\n");
printf("Please enter the dimensions of the matrix dimensions:\n\n");
printf("Number of Rows: ");
scanf("%d", &rows);
printf("\nNumber of Columns: ");
scanf("%d", &columns);
matrix_length = rows * columns;
int* h_matrix;
h_matrix = (int*)malloc(sizeof(int) * matrix_length);
int* d_matrix;
cudaMalloc((void**) &d_matrix, sizeof(int) * matrix_length);
for(int i = 0; i < matrix_length; i++)
	int temp = rand() % 100;
    h_matrix[i] = temp;
printf("CPU\n===\n");
for (int i = 0; i < matrix_length;){
	printf("| ");
	for (int j = 0; j < columns; j++){
		printf("%d ", h_matrix[j]);
	printf("|");
	printf("\n");
	i += columns;
cudaMemcpy(d_matrix, h_matrix, sizeof(h_matrix) * matrix_length, cudaMemcpyHostToDevice);
transpose<<<1, matrix_length>>>(d_matrix);
cudaMemcpy(h_matrix, d_matrix, sizeof(d_matrix) * matrix_length, cudaMemcpyDeviceToHost);
printf("\nGPU\n===\n");
	printf("| ");
		printf("%d ", d_matrix[j]);
	printf("|");
	printf("\n");
	i += columns;
}[/codebox]
Your use of sizeof() in the memcpy calls is wrong. You want sizeof(int) or sizeof(h_matrix[0]), as it is, your sizeof(h_matrix) is the size of the pointer rather than the size of the type it points to.
This doesn’t seem to be correct. There’s nothing within the printf statements that is dependent on the value i.
N.
i had:
[codebox] cudaMemcpy(d_matrix, h_matrix, sizeof(int) * matrix_length, cudaMemcpyHostToDevice);
cudaMemcpy(h_matrix, d_matrix, sizeof(int) * matrix_length, cudaMemcpyDeviceToHost);[/codebox]
before but it didn’t change anything…it’s still not copying properly
oh this part was just to get to each row and the inner loop just prints the row out
ohhhh i figured it out…i was printing out the wrong matrix…\
biggest brain fart ever :(
I know that’s what you meant to accomplish, but in that case it should be
[codebox]for (int i = 0; i < rows ; ++i){
printf("| ");
printf("%d ", h_matrix[i*columns+j]);
printf(“|\n”);
}[/codebox]
N.
