Copying struct from host to device using cudaMemcpy
I am facing a problem in copying struct data from host to device in the CUDA architecture.
Following is the code snippet.
struct point
     double x,y;
int main()
   point * a = (point*)malloc(sizeof(point));
   a->x=10.0;
   a->y=10.0;
   point * d_a;
   cudaMalloc((void**)d_a,sizeof(point));
   cudaMemcpy((void**)d_a,a,sizeof(point),cudaMemcpyHostToDevice);
   dim3 dimblock(16,16);
   dim3 dimgrid(1,1);
   MyFunc<<<dimgrid,dimblock>>>(d_a);
   cudaMemcpy((void**)a,d_a,sizeof(point),cudaMemcpyDeviceToHost);
   printf("%lf %lf\n",a->x,a->y);
__global__ void MyFunc(point* d_a)
     if(threadIdx.x == 0 && threadIdx.y == 0)
        d_a->x=100.0;
        d_a->y = 100.0;
The x and y fields of point a should have been changed to 100. Instead, it is still 10 as initialized. What is happening here? Please help.
In the allocation of d_a take the address with an “&” to actually form a double pointer:
cudaMalloc((void**)&d_a,sizeof(point));
and remove the nonsensical casts to (void**) from the cudaMemcpy()s.
In general, check return codes of Cuda calls for errors.
Use %f as format string for double variables, %Lf is for long doubles.
And declare kernels before they are invoked (or use prototypes).
