Copying structs containing dynamically allocated arrays to the GPU
I’m working on a implicit surface raytracer using CUDA, and I’m using the following structures to represent a surface:
//Term3: one term of the polynomial of a 3-dimensional algebraic implicit surface
//coeff: coefficient of the term
//x, y, z: powers of x, y and z
struct Term3
	float coeff;
	int x, y, z;
struct Polynomial3
	Term3* terms;
	int nTerms;
struct Surface
	Polynomial3 surface;
	Polynomial3 gradient[3];//one polynomial for each coordinate
	float3 position;
	float4 rotation;
	float3 scale;
	float3 aabbMin;
	float3 aabbMax;
The problem is that Polynomial3::terms is a dynamically allocated array because a polynomial may have any number of terms. How can I memcpy a Surface object to the GPU? I tried several different ways without any success External Image
Hello!
I think you’re having the same problem I did once. Check this thread, it might help you: [url=“http://forums.nvidia.com/index.php?showtopic=100493&hl=”]http://forums.nvidia.com/index.php?showtopic=100493&hl=[/url]
You can also look at this thread:
[link] [url=“http://forums.nvidia.com/index.php?showtopic=106708&mode=threaded&pid=590259”]http://forums.nvidia.com/index.php?showtop...&pid=590259[/url] [/link]
Hey, thank you guys! I got it working. Also thanks for the guys who replied in those threads.
