So I am generating a simulation of about 1000 Ues and 11 RUs, and I am able to generate the UEs fine and start the mobility, but when i get to 99% completed it throws the following error:
2025-03-26 19:15:06 [867,856ms] [Error] [aodt.common.utils] copyResultsFromDeviceToHost returned an error (-2127953920)
any advise? I am trying to find the code this is referencing so i can dig into it but i cannot locate it.
My configuration is the Microsoft Azure specification from the installation documentation as i deployed it by following those instructions.
I actually did find out that the UE spawn zone was trying to spawn UEs outside the bounds so it was finding no logical path. I fixed this issue actually after figuring it out
@michael.chiaramonte
âcopyResultsFromDeviceToHost returned an errorâ â this is unlikely due to spawn zone. The error most likely comes from the size of simulation. You should be able to fit 10RUs and 100 UEs with a 4TRX.
The spawn zone will not create UEs outsize of the spawn zone. Did you have a manual UE and a span zone? Can you share the map with the spawn zone?
I was able to fix that issue it was the size of the simulation making it crash or have that error.
