core dump about DLA
NVMEDIA_DLA :  295, ERROR: Get runtime version failed. err: 0x2.
INTERNAL_ERROR: Assertion failed: tmp != nullptr && "dla creation failure"
dla/dlaUtils.cpp:389
Aborting...
my programe core dumped when loading model,but i can run my programme on another xavier.
It looks like an incompatible driver/libraries issue.
Do you flash and install the CUDA/cuDNN/TensorRT library with the same JetPack installer?
i have reflashed all with JetPack 4.2,but it still happened with core dump.
ERROR: dla/eglUtils.cpp (109) - EGL Error in makeEglDisplay: 12290
./run.sh: line 3: 17770 Segmentation fault      (core dumped)
Is something worry with my xavier?
Have you installed any CUDA related library after JetPack installation?
If not, could you share your the with us?
We want to reproduce this issue in our environment first.
I have installed CUDA related library.And i have contacted with nvidia’s technician to solve this problem.thanks
Good to know this.
runing DeepStream3.0 on Jetpack 4.2.I think that it is the reason why core dump.
