Jetson Nano reports core dump when generating PLAN files, in fact I have successfully generated PLAN files many times using the same caffe model file and same code
The issue happens after below codes are executed
const nvcaffeparser1::IBlobNameToTensor* blobNameToTensor = parser->parse(proto_file.c_str(), model_file.c_str(), *network, nvinfer1::DataType::kFLOAT);
The issue is as below:
terminate called after throwing an instance of ‘std::bad_alloc’
what(): std::bad_alloc
Aborted
it is urgent for us, please help to check it
