Hey!
I’m using move_prim to rename multiple prims in my scene after they have been moved to other parents during a simulation.
Since I didn’t find another way, I record the original path for each prim (and have a new id-attribute to track prims throughout the simulation). At the start of a simulation, I reset the paths with move_prim.
I now have a list of current_name → original_name pairs and run move_prim for each pair. This works most often as expected, but now I triggered the case in which both the parent and a child have been renamed. This currently leads to the case, that I call move_prim(‘/World/Foo/Bar’, '/World/ASD/foo) where a is not a valid prim anymore because /World/Foo was already renamed to /World/XYZ.
This of course can’t work, the problem (aka bug) is now that IsaacSim dies instead of raising an exception:
"terminate called after throwing an instance of ‘pxrInternal_v0_22__pxrReserved__::UsdExpiredPrimAccessError’
what(): Used null prim
I know I should not try to use invalid prims here and I should check a IsValid for the source and the parent of the target, but I think even a wrong usage should not kill the whole application.
I did some more digging into the issue and think that the issue is somewhere else.
My Code now looks like this:
src_ok = self.stage.GetPrimAtPath(old).IsValid()
tgt_parent_ok = self.stage.GetPrimAtPath(Path(new).parent.as_posix()).IsValid()
tgt_ok = not self.stage.GetPrimAtPath(new).IsValid()
if not all([src_ok, tgt_parent_ok, tgt_ok]):
continue
carb.log_warn(f"Renaming {old} to {new}")
try:
prims_utils.move_prim(old, new)
except Exception as e:
carb.log_error(f"Error renaming {old} to {new}: {e}")
continue
carb.log_warn(f"Renamed {old} to {new}")
So I think I can claim that this renaming should be valid because the source is valid, there is nothing yet at the target and the parent of the target prim exists.
The move_prim also does not trigger an Exception and even if the underlying C+±code triggers something, the second log_warn should not be executed.
This is my output (I currently run the renaming-function recursively as soon as I successfully renamed a prim to make sure that I don’t try to do invalid renames. Not the most efficient method, but safe)
2025-03-31 (...) Renaming 5 prims
2025-03-31 (...) Renaming /World/Conveyors/ConveyorTrack_T/Belt_01/Cardbox_C1_712936021172217926297711806828 to /World/Zones/outbound_zone_01/Positions/P1_02/Pallet_A1_07/items/Cardbox_C1_712936021172217
2025-03-31 (...) Renamed /World/Conveyors/ConveyorTrack_T/Belt_01/Cardbox_C1_712936021172217926297711806828 to /World/Zones/outbound_zone_01/Positions/P1_02/Pallet_A1_07/items/Cardbox_C1_712936021172217
2025-03-31 (...) Renaming 4 prims
2025-03-31 (...) Renaming /World/forklift/Pallet_A1_07 to /World/Zones/truck_zone_00/Positions/P1_02/Pallet_A1_07
2025-03-31 (...) Renamed /World/forklift/Pallet_A1_07 to /World/Zones/truck_zone_00/Positions/P1_02/Pallet_A1_07
2025-03-31 (...) Renaming 0 prims
terminate called after throwing an instance of 'pxrInternal_v0_22__pxrReserved__::UsdExpiredPrimAccessError'
Is there a way to get a better debug output? It would be extremely valuable to know in which function the error happens.
