Correct Clara tutorial application output?
I’m getting started with the Clara SDK but am unsure if I am getting the correct output from the sample apps. When I run the run_liver and run_vnet reference app scripts, either as local or docker, they seem to run without error and generate seemingly valid MHD data and RAW image files. These files do not contain any useful data though. The RAW image is all black, and the MHD file is just a few header text strings describing the DICOM file properties. Is this correct? Should I be seeing segmented data in the image file?
I’m running Clara SDK v0.1.7 on Ubuntu 16.04 with an RTX 2060 driver 410.78.
Please see the reply to the same question, https://devtalk.nvidia.com/default/topic/1050169/clara-deploy-sdk-new-/expected-output-from-clara-sample-apps-/
Best Regards,
MQ
