correct subarray in data regions
we wonder, which is the correct / safe / fast method do declare the subarray in a data region with OpenACC.
Lets assume an array allocated as
AA(0:Imax+1,0:Jmax+1,0:Kmax+1,Maxblocks)
This variable is used as shown here:
DO iBlock = 1, Maxblocks
!here, the complete subarray for Block iBlock should be copied
!$acc data
!$acc& copy(AA(xxxxx))
...some code...
 DO K=1,Kmax
  DO J=1,Jmax
   DO I=1,Imax
   ...some code...
   ENDDO
  ENDDO
 ENDDO
   ...some code...
!$acc end data
END DO
How should the contiguous subarray (for the actual block iBlock) of AA be declared in the data-region (create, copy, update,…) and what are the differences in the following methods:
  1. AA(:,:,:,iBlock)
  2. AA(:,:,:,iBlock:iBlock)
  3. AA(0:Imax+1,0:Jmax+1,0:Kmax+1,iBlock)
  4. AA(0:Imax+1,0:Jmax+1,0:Kmax+1,iBlock:iBlock)
(we also copy the halos / dummy cells in order to have a contiguous data transfer)
Many thanks in advance!
