CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000088
I have upgraded the Jetpack version to 35. 4, the video stream successfully worked in YUV camera.When I tried to use a raw camera, I couldn’t stream the video successfully.
VERSION INFO:
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
More info:
trace.txt (378.5 KB)
command:
gst-launch-1.0 nvarguscamerasrc sensor_mode=0 sensor_id=0 ! ‘video/x-raw(memory:NVMM),width=3840, height=2160, framerate=30/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
The short frame could be cause incorrect embedded_data_height in device tree, otherwise could be the output size less than driver report.
     kworker/1:3-599     [001] ....   747.838823: rtcpu_vinotify_event: tstamp:24026368205 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:11770 vi_tstamp:768841673696 data:0x0870200001000000
