Correction Needed in the Documentation: Adding Multiple Robots, Adding a Manipulator and multiple tasks - Error in Code Snippet
I hope this message finds you well. I would like to bring to your attention an issue I encountered with the import statements in the omni.isaac.motion_generation module.
In the current version, the following import statement is provided:
from omni.isaac.motion_generation import WheelBasePoseController
However, it seems that WheelBasePoseController is not present in the omni.isaac.motion_generation module. Instead, it can be found in the omni.isaac.wheeled_robots.controllers module.
To resolve this, I suggest updating the import statement to the following:
from omni.isaac.wheeled_robots.controllers import WheelBasePoseController
This correction should accurately reflect the location of the WheelBasePoseController class.
Thank you for your attention to this matter, and I appreciate your efforts in maintaining the NVIDIA Isaac Omniverse platform.
Thanks,
Adlan
I met the same situation, and thanks for your sharing which really works. This is definitely a bug that needs to be fixed soon or later.
Hi @aitameuradlan - Thank you for bringing that to our attention. We will look into it.
