Corrupted Jetson TX2 Partition Table
Hello all,
I was working on the Jetson TX2, and corrupted the partition table of the internal storage when attempting to repartition an SD card. I accidentally deleted all the partitions and created a new one. I know this is a really silly mistake, so I am sorry for bothering you all with it. I attempted to use Jetpack to resolve this, but Jetpack has been unable to flash the OS. It throws an error saying “invalid target board”. I think that this is because the internal storage of the Jetson cannot be read by the host, and it is not found under /dev when the Jetson is in recovery mode.
I am running Jetpack on a host with Ubuntu 16.04. I know that Jetpack is made for 14.04, but I have used it on this host before.
Does anyone know of a way to fix this? Thank you.
I think I misunderstood the problem. I was able to manually flash it by using
sudo ./flash.sh -S 29318MiB jetson-tx2 mmcblk0p1
It seems to be working now. I will probably now try to use Jetpack to finish the job.
