Corruption in memory copy?
I have a problem in which I have no idea what’s going wrong. After commenting some lines to isolate the origin the problem, my code is similar to this one:
[codebox]#define SURF_DESCRIPTOR_SIZE 64
#define CORRELATION_THRESH 0.99
#define TILE_WIDTH 16
#define MAX_THREADS_PER_BLOCK 512
#define MEAN_SDV_THREADS MAX_THREADS_PER_BLOCK / SURF_DESCRIPTOR_SIZE
global
void calcMean(float * desc1, float * desc2, float * m1, float * m2) {
unsigned int tx = threadIdx.x;
unsigned int ty = threadIdx.y;
unsigned int bx = blockIdx.x;
unsigned int by = blockIdx.y;
if (tx == 0) {
    m1[bx * MEAN_SDV_THREADS + ty] = desc1[(bx * (MEAN_SDV_THREADS) + ty) * SURF_DESCRIPTOR_SIZE + tx]; //partialSum1[ty][0]; // SURF_DESCRIPTOR_SIZE;
void Match(vector<t_Point> points1, vector<t_Point> points2, vector desc1, vector desc2, vector &matches, t_Timings &timings) {
cout << "Points1 " << points1.size() << endl;
cout << "Points2 " << points2.size() << endl;
// Sizes must be multiples of TILE_WIDTH
int size1 = (int(points1.size() / TILE_WIDTH) + 1) * TILE_WIDTH;
int size2 = (int(points2.size() / TILE_WIDTH) + 1) * TILE_WIDTH;
int size = max(size1, size2);
// Host memory pointers
float * h_desc1 = (float *)malloc(size * SURF_DESCRIPTOR_SIZE * sizeof(float));
float * h_desc2 = (float *)malloc(size * SURF_DESCRIPTOR_SIZE * sizeof(float));
float * h_response1 = (float *)malloc(size1 * sizeof(float));
float * h_response2 = (float *)malloc(size2 * sizeof(float));
// Initialization
for (int i = 0; i < desc1.size(); i++) {
    h_desc1[i] = desc1.at(i);
for (int i = 0; i < desc2.size(); i++) {
    h_desc2[i] = desc2.at(i);
for (int i = 0; i < points1.size(); i++) {
    h_response1[i] = points1.at(i).response;
for (int i = 0; i < points2.size(); i++) {
    h_response2[i] = points2.at(i).response;
// Extra values are setted to 0
for (int i = desc1.size(); i < size * SURF_DESCRIPTOR_SIZE; i++) {
    h_desc1[i] = 0;
for (int i = desc2.size(); i < size * SURF_DESCRIPTOR_SIZE; i++) {
    h_desc2[i] = 0;
// Device pointers
float * d_corr;
float * d_m1;
float * d_m2;
float * d_sdv1;
float * d_sdv2;
bool * d_response1;
bool * d_response2;
int * d_bestCorr1;
int * d_bestCorr2;
int * d_matches;
// Memory allocation
cutilSafeCall(cudaMalloc(&d_m1, size * sizeof(float)));
cutilSafeCall(cudaMalloc(&d_sdv1, size * sizeof(float)));
cutilSafeCall(cudaMalloc(&d_m2, size * sizeof(float)));
cutilSafeCall(cudaMalloc(&d_sdv2, size * sizeof(float)));
cutilSafeCall(cudaMalloc(&d_desc1, size * SURF_DESCRIPTOR_SIZE * sizeof(float)));
cutilSafeCall(cudaMalloc(&d_desc2, size * SURF_DESCRIPTOR_SIZE * sizeof(float)));
// Memory copy
cutilSafeCall(cudaMemcpy(d_desc1, h_desc1, size * sizeof(float), cudaMemcpyHostToDevice));
cutilSafeCall(cudaMemcpy(d_desc2, h_desc2, size * sizeof(float), cudaMemcpyHostToDevice));
// Mean is calculated
dim3 dimBlockMeanSdv(SURF_DESCRIPTOR_SIZE, MEAN_SDV_THREADS);
dim3 dimGridMeanSdv(size / dimBlockMeanSdv.y, 1);
calcMean <<< dimGridMeanSdv, dimBlockMeanSdv >>> (d_desc1, d_desc2, d_m1, d_m2);
cudaThreadSynchronize();
// Results are shown
for (int i = 0; i < 65; i++) {
    cout << i << "[" << h_desc1[i * SURF_DESCRIPTOR_SIZE] << "]";
float * m1 = (float *)malloc(size * sizeof(float));
cutilSafeCall(cudaMemcpy(m1, d_m1, size * sizeof(float), cudaMemcpyDeviceToHost));
cout << dimBlockMeanSdv.x << endl;
    cout << i << "[" << m1[i] << "]";
cout << endl;
free(m1);
}[/codebox]
The output for a given example is this:
[codebox]Points1 2136
Points2 2090
64
0[-9.84887e-07][-9.84887e-07]
1[-9.92876e-07][-9.92876e-07]
2[7.63803e-07][7.63803e-07]
3[-5.75615e-06][-5.75615e-06]
4[5.28887e-06][5.28887e-06]
32[0.00377774][0.00377774]
33[-2.09816e-06][-2.09816e-06]
34[0.00188525][-3.02126e-06] <<- At this point, the two arrays have different values. Why not before?
35[-0.00295363][-7.57153e-05]
36[0.00315898][-2.0971e-05]
37[-0.00191124][5.81767e-07]
38[-0.00143699][0.000399498]
39[0.000764901][2.25177e-06]
40[-0.0060265][2.95596e-07]
41[-0.0490147][-0.00174616]
42[-0.0559343][8.19524e-06]
43[nan][-0.00516252]
44[nan][-7.84284e-06]
45[nan][-2.47702e-06]
46[nan][-3.99062e-06]
47[nan][5.18736e-06]
48[nan][-4.69436e-06]
49[nan][0.000917098]
50[nan][5.49397e-05]
51[nan][1.4918e-06]
52[nan][0.00240714]
53[nan][-6.25982e-06]
54[nan][0.000783656]
55[nan][0.0161487]
56[nan][0.00147562]
57[nan][-1.23446e-06]
58[nan][-2.06568e-07]
59[nan][-1.09316e-06]
60[nan][-2.11338e-06]
61[nan][0.0115776]
62[nan][0.00340284]
63[nan][-5.88755e-07]
64[nan][-0.00109655][/codebox]
I have tryied a lot of tests, but I don’t understand the cause of the problem. Does anybody know why? I’m working with a GeForce 9800 GT and an Intel Core 2 Duo CPU E8400 at 3.00GHz with 4GB of RAM.
Thank you in advance,
Néstor
global
if (tx == 0) {
// Initialization
    h_desc1[i] = 0;
    h_desc2[i] = 0;
// Device pointers
float * d_corr;
float * d_m1;
float * d_m2;
float * d_sdv1;
float * d_sdv2;
bool * d_response1;
bool * d_response2;
int * d_bestCorr1;
int * d_bestCorr2;
int * d_matches;
// Memory copy
cout << endl;
free(m1);
}[/codebox]
Points2 2090
64
51[nan][1.4918e-06]
52[nan][0.00240714]
55[nan][0.0161487]
56[nan][0.00147562]
61[nan][0.0115776]
62[nan][0.00340284]
Néstor
I’ve solved it. Sorry, I hadn’t check my code good enough. The problem was in these two lines:
[codebox]// Memory copy
cutilSafeCall(cudaMemcpy(d_desc2, h_desc2, size * sizeof(float), cudaMemcpyHostToDevice));[/codebox]
They should be like these others:
cutilSafeCall(cudaMemcpy(d_desc1, h_desc1, size * SURF_DESCRIPTOR_SIZE * sizeof(float), cudaMemcpyHostToDevice));
cutilSafeCall(cudaMemcpy(d_desc2, h_desc2, size * SURF_DESCRIPTOR_SIZE * sizeof(float), cudaMemcpyHostToDevice));[/codebox]
Now it works. :rolleyes:
