Cosmos-Transfer2.5 for CARLA sim-to-real augmentation — best cloud GPU option, free resources, or existing datasets?
Hi all,
I’m an independent developer (solo project, not a company) building a thermal + RGB driver-safety system targeting Jetson Orin Nano deployment. I’m working on closing a sim-to-real domain gap using Cosmos-Transfer2.5’s segmentation-conditioned generation on CARLA driving data, and I’m about to run a small self-funded validation batch on rented cloud GPU time.
Before I commit, three questions for anyone who’s done something similar:
  1. Hosted GPU choice – for a small, one-off validation batch (a few hours of H100-class compute, not an ongoing workload), what’s actually been the best experience? Planning on RunPod based on my own research, but curious if others have found a better price/reliability tradeoff for short one-off runs specifically.
  2. Any free/low-cost resources? – I know Inception requires incorporation, which doesn’t fit a solo/independent project like mine. Is there anything else – research credits, community programs, eval access – worth knowing about before I self-fund this?
  3. Existing datasets? – Is anyone aware of an existing real-world night-driving dataset with segmentation labels (or something close) that might make generation unnecessary for a case like mine? Trying not to reinvent something that already exists.
Happy to share results back once I’ve run the test either way.
Pete
1. Cosmos-Transfer2.5 is available on NIM.
The other two questions are left for others to answer.
Do you already have the exact Cosmos Transfer 2.5 command or script you’re planning to use for the CARLA batch?
I’m working on Badgr Smoke Test for this kind of thing. It checks the job shape first and gives you a capped command to run before you spend on the full H100 batch.
Thanks AastaLLL, that’s really helpful – I hadn’t realized there’s a free hosted endpoint for this model on build.nvidia.com. I’ll try running a segmentation-conditioned generation there directly before spending anything on rented GPU time. Will report back on whether it handles the CARLA sim-to-real workflow well.
@michaelhireitem – appreciate the pointer to Badgr, I’ll take a look separately. For this first pass I’ll stick with a plan I’ve already got scoped out (self-hosting on a rented GPU if the free endpoint doesn’t cover what I need), just to keep things simple for a first test.
Still curious if anyone has thoughts on the other two questions – any free/low-cost resources for an independent (non-incorporated) project like this, or whether an existing real-world night-driving segmentation dataset already exists that might save the trouble of generating synthetic data at all. No rush, just leaving this open in case anyone’s run into either.
Thanks again!
