I figured out, evaluation_config
was missing on my spec file i have added it now.
latest error:
Using TensorFlow backend.
[[50944,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
Host: tlt
Another transport will be used instead, although this may result in
lower performance.
NOTE: You can disable this warning by setting the MCA parameter
btl_base_warn_component_unused to 0.
2020-05-05 11:48:10,029 [INFO] iva.detectnet_v2.scripts.train: Loading experiment spec at specs/train.txt.
2020-05-05 11:48:10,032 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from specs/train.txt
2020-05-05 11:48:10,147 [INFO] iva.detectnet_v2.scripts.train: Cannot iterate over exactly 7644 samples with a batch size of 24; each epoch will therefore take one extra step.
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 500, 700) 0
conv1 (Conv2D) (None, 64, 250, 350) 9472 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 250, 350) 256 conv1[0][0]
activation_1 (Activation) (None, 64, 250, 350) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 125, 175) 36928 activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 125, 175) 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (None, 64, 125, 175) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 125, 175) 36928 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 125, 175) 4160 activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 125, 175) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 125, 175) 256 block_1a_conv_shortcut[0][0]
add_1 (Add) (None, 64, 125, 175) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (None, 64, 125, 175) 0 add_1[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 125, 175) 36928 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 125, 175) 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (None, 64, 125, 175) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 125, 175) 36928 block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 125, 175) 256 block_1b_conv_2[0][0]
add_2 (Add) (None, 64, 125, 175) 0 block_1b_bn_2[0][0]
block_1a_relu[0][0]
block_1b_relu (Activation) (None, 64, 125, 175) 0 add_2[0][0]
block_1c_conv_1 (Conv2D) (None, 64, 125, 175) 36928 block_1b_relu[0][0]
block_1c_bn_1 (BatchNormalizati (None, 64, 125, 175) 256 block_1c_conv_1[0][0]
block_1c_relu_1 (Activation) (None, 64, 125, 175) 0 block_1c_bn_1[0][0]
block_1c_conv_2 (Conv2D) (None, 64, 125, 175) 36928 block_1c_relu_1[0][0]
block_1c_bn_2 (BatchNormalizati (None, 64, 125, 175) 256 block_1c_conv_2[0][0]
add_3 (Add) (None, 64, 125, 175) 0 block_1c_bn_2[0][0]
block_1b_relu[0][0]
block_1c_relu (Activation) (None, 64, 125, 175) 0 add_3[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 63, 88) 73856 block_1c_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 63, 88) 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (None, 128, 63, 88) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 63, 88) 147584 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 63, 88) 8320 block_1c_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 63, 88) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 63, 88) 512 block_2a_conv_shortcut[0][0]
add_4 (Add) (None, 128, 63, 88) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (None, 128, 63, 88) 0 add_4[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 63, 88) 147584 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 63, 88) 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (None, 128, 63, 88) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 63, 88) 147584 block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 63, 88) 512 block_2b_conv_2[0][0]
add_5 (Add) (None, 128, 63, 88) 0 block_2b_bn_2[0][0]
block_2a_relu[0][0]
block_2b_relu (Activation) (None, 128, 63, 88) 0 add_5[0][0]
block_2c_conv_1 (Conv2D) (None, 128, 63, 88) 147584 block_2b_relu[0][0]
block_2c_bn_1 (BatchNormalizati (None, 128, 63, 88) 512 block_2c_conv_1[0][0]
block_2c_relu_1 (Activation) (None, 128, 63, 88) 0 block_2c_bn_1[0][0]
block_2c_conv_2 (Conv2D) (None, 128, 63, 88) 147584 block_2c_relu_1[0][0]
block_2c_bn_2 (BatchNormalizati (None, 128, 63, 88) 512 block_2c_conv_2[0][0]
add_6 (Add) (None, 128, 63, 88) 0 block_2c_bn_2[0][0]
block_2b_relu[0][0]
block_2c_relu (Activation) (None, 128, 63, 88) 0 add_6[0][0]
block_2d_conv_1 (Conv2D) (None, 128, 63, 88) 147584 block_2c_relu[0][0]
block_2d_bn_1 (BatchNormalizati (None, 128, 63, 88) 512 block_2d_conv_1[0][0]
block_2d_relu_1 (Activation) (None, 128, 63, 88) 0 block_2d_bn_1[0][0]
block_2d_conv_2 (Conv2D) (None, 128, 63, 88) 147584 block_2d_relu_1[0][0]
block_2d_bn_2 (BatchNormalizati (None, 128, 63, 88) 512 block_2d_conv_2[0][0]
add_7 (Add) (None, 128, 63, 88) 0 block_2d_bn_2[0][0]
block_2c_relu[0][0]
block_2d_relu (Activation) (None, 128, 63, 88) 0 add_7[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 32, 44) 295168 block_2d_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 32, 44) 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (None, 256, 32, 44) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 32, 44) 590080 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 32, 44) 33024 block_2d_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 32, 44) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 32, 44) 1024 block_3a_conv_shortcut[0][0]
add_8 (Add) (None, 256, 32, 44) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (None, 256, 32, 44) 0 add_8[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 32, 44) 590080 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 32, 44) 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (None, 256, 32, 44) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 32, 44) 590080 block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 32, 44) 1024 block_3b_conv_2[0][0]
add_9 (Add) (None, 256, 32, 44) 0 block_3b_bn_2[0][0]
block_3a_relu[0][0]
block_3b_relu (Activation) (None, 256, 32, 44) 0 add_9[0][0]
block_3c_conv_1 (Conv2D) (None, 256, 32, 44) 590080 block_3b_relu[0][0]
block_3c_bn_1 (BatchNormalizati (None, 256, 32, 44) 1024 block_3c_conv_1[0][0]
block_3c_relu_1 (Activation) (None, 256, 32, 44) 0 block_3c_bn_1[0][0]
block_3c_conv_2 (Conv2D) (None, 256, 32, 44) 590080 block_3c_relu_1[0][0]
block_3c_bn_2 (BatchNormalizati (None, 256, 32, 44) 1024 block_3c_conv_2[0][0]
add_10 (Add) (None, 256, 32, 44) 0 block_3c_bn_2[0][0]
block_3b_relu[0][0]
block_3c_relu (Activation) (None, 256, 32, 44) 0 add_10[0][0]
block_3d_conv_1 (Conv2D) (None, 256, 32, 44) 590080 block_3c_relu[0][0]
block_3d_bn_1 (BatchNormalizati (None, 256, 32, 44) 1024 block_3d_conv_1[0][0]
block_3d_relu_1 (Activation) (None, 256, 32, 44) 0 block_3d_bn_1[0][0]
block_3d_conv_2 (Conv2D) (None, 256, 32, 44) 590080 block_3d_relu_1[0][0]
block_3d_bn_2 (BatchNormalizati (None, 256, 32, 44) 1024 block_3d_conv_2[0][0]
add_11 (Add) (None, 256, 32, 44) 0 block_3d_bn_2[0][0]
block_3c_relu[0][0]
block_3d_relu (Activation) (None, 256, 32, 44) 0 add_11[0][0]
block_3e_conv_1 (Conv2D) (None, 256, 32, 44) 590080 block_3d_relu[0][0]
block_3e_bn_1 (BatchNormalizati (None, 256, 32, 44) 1024 block_3e_conv_1[0][0]
block_3e_relu_1 (Activation) (None, 256, 32, 44) 0 block_3e_bn_1[0][0]
block_3e_conv_2 (Conv2D) (None, 256, 32, 44) 590080 block_3e_relu_1[0][0]
block_3e_bn_2 (BatchNormalizati (None, 256, 32, 44) 1024 block_3e_conv_2[0][0]
add_12 (Add) (None, 256, 32, 44) 0 block_3e_bn_2[0][0]
block_3d_relu[0][0]
block_3e_relu (Activation) (None, 256, 32, 44) 0 add_12[0][0]
block_3f_conv_1 (Conv2D) (None, 256, 32, 44) 590080 block_3e_relu[0][0]
block_3f_bn_1 (BatchNormalizati (None, 256, 32, 44) 1024 block_3f_conv_1[0][0]
block_3f_relu_1 (Activation) (None, 256, 32, 44) 0 block_3f_bn_1[0][0]
block_3f_conv_2 (Conv2D) (None, 256, 32, 44) 590080 block_3f_relu_1[0][0]
block_3f_bn_2 (BatchNormalizati (None, 256, 32, 44) 1024 block_3f_conv_2[0][0]
add_13 (Add) (None, 256, 32, 44) 0 block_3f_bn_2[0][0]
block_3e_relu[0][0]
block_3f_relu (Activation) (None, 256, 32, 44) 0 add_13[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 32, 44) 1180160 block_3f_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 32, 44) 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (None, 512, 32, 44) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 32, 44) 2359808 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 32, 44) 131584 block_3f_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 32, 44) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 32, 44) 2048 block_4a_conv_shortcut[0][0]
add_14 (Add) (None, 512, 32, 44) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (None, 512, 32, 44) 0 add_14[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 32, 44) 2359808 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 32, 44) 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (None, 512, 32, 44) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 32, 44) 2359808 block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 32, 44) 2048 block_4b_conv_2[0][0]
add_15 (Add) (None, 512, 32, 44) 0 block_4b_bn_2[0][0]
block_4a_relu[0][0]
block_4b_relu (Activation) (None, 512, 32, 44) 0 add_15[0][0]
block_4c_conv_1 (Conv2D) (None, 512, 32, 44) 2359808 block_4b_relu[0][0]
block_4c_bn_1 (BatchNormalizati (None, 512, 32, 44) 2048 block_4c_conv_1[0][0]
block_4c_relu_1 (Activation) (None, 512, 32, 44) 0 block_4c_bn_1[0][0]
block_4c_conv_2 (Conv2D) (None, 512, 32, 44) 2359808 block_4c_relu_1[0][0]
block_4c_bn_2 (BatchNormalizati (None, 512, 32, 44) 2048 block_4c_conv_2[0][0]
add_16 (Add) (None, 512, 32, 44) 0 block_4c_bn_2[0][0]
block_4b_relu[0][0]
block_4c_relu (Activation) (None, 512, 32, 44) 0 add_16[0][0]
output_bbox (Conv2D) (None, 12, 32, 44) 6156 block_4c_relu[0][0]
output_cov (Conv2D) (None, 3, 32, 44) 1539 block_4c_relu[0][0]
Total params: 21,322,319
Trainable params: 21,295,695
Non-trainable params: 26,624
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
2020-05-05 11:49:06,517 [INFO] iva.detectnet_v2.scripts.train: Found 7644 samples in training set
2020-05-05 11:49:37,144 [INFO] iva.detectnet_v2.scripts.train: Found 1348 samples in validation set
File "/usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
File "./common/magnet_train.py", line 47, in main
File "<decorator-gen-2>", line 2, in main
File "./detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
File "./detectnet_v2/scripts/train.py", line 667, in main
File "./detectnet_v2/scripts/train.py", line 591, in run_experiment
File "./detectnet_v2/scripts/train.py", line 525, in train_gridbox
File "./detectnet_v2/scripts/train.py", line 142, in run_training_loop
File "./detectnet_v2/training/utilities.py", line 143, in get_singular_monitored_session
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1021, in __init__
stop_grace_period_secs=stop_grace_period_secs)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 650, in __init__
self._sess = self._coordinated_creator.create_session()
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 812, in create_session
hook.after_create_session(self.tf_sess, self.coord)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/basic_session_run_hooks.py", line 568, in after_create_session
self._save(session, global_step)
File "./detectnet_v2/tfhooks/checkpoint_saver_hook.py", line 77, in _save
File "./detectnet_v2/tfhooks/checkpoint_saver_hook.py", line 110, in _save_encrypted_checkpoint
IOError: [Errno 2] No such file or directory: 'trained_model/model.step-0.ckzip'
latest training spec file:
dataset_config {
data_sources: {
tfrecords_path: "/nitin/tlt-workspace/people-net/tf_records/*"
image_directory_path: "/nitin/tlt-workspace/people-net/dataset"
image_extension: "jpg"
target_class_mapping {
key: "pedestrians"
value: "pedestrians"
key: "riders"
value: "riders"
key: "crowd"
value: "crowd"
validation_fold: 0
model_config {
pretrained_model_file: "/nitin/tlt-workspace/people-net/pretrained_weights/tlt_peoplenet_vunpruned_v1.0/resnet34_peoplenet.tlt"
num_layers: 34
freeze_blocks: 0
arch: "resnet"
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 8.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 24
num_epochs: 12
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 0.0005
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-09
optimizer {
adam {
epsilon: 9.9e-09
beta1: 0.9
beta2: 0.999
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
augmentation_config {
preprocessing {
output_image_width: 700
output_image_height: 500
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config{
target_class_config{
key: "pedestrians"
value: {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.265
dbscan_min_samples: 0.05
minimum_bounding_box_height: 4
key: "riders"
value: {
clustering_config {
dbscan_eps: 0.15
key: "crowd"
value: {
clustering_config {
dbscan_eps: 0.15
minimum_bounding_box_height: 2
bbox_rasterizer_config {
target_class_config {
key: "pedestrians"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.40000000596
cov_radius_y: 0.40000000596
bbox_min_radius: 1.0
key: "riders"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "crowd"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "pedestrians"
value: 0.5
key: "riders"
value: 0.5
key: "crowd"
value: 0.5
evaluation_box_config {
key: "pedestrians"
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
key: "riders"
value {
minimum_height: 2
minimum_width: 2
maximum_width: 9999
key: "crowd"
value {
minimum_height: 40
minimum_width: 4
maximum_width: 9999
