Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Dear Nvidia,
I am reading the nvstream unicast sample code, and could not understand the below code, 1. first question is : why mapped_ptr only add pitch size? the pitch size seems even smaller than the loop length (inp_surfaceMap.width * nWidth), so there are overlap and will be re-written in the next loop.
2. second question is: does here the pitch*surfaceMap.height determinate the IPC shared buffer size? or is it the same with consumer side received buffer size?
CHECK_NVMEDIAERR(NvMediaImageLock(nvmimg_in[i],
NVMEDIA_IMAGE_ACCESS_WRITE,
&inp_surfaceMap));
// Fill predefined data
uint32_t nWidth = 4U;
// This code assumes YUV 422 PL images with cpu mapping pointers
mapped_ptr = (uint8_t*)inp_surfaceMap.surface[0].mapping;
for (uint32_t y = 0U; y < inp_surfaceMap.height; y++) {
for (uint32_t x = 0U; x < inp_surfaceMap.width * nWidth; x++) {
mapped_ptr[x] = (i + ((x % 32)+ (y % 32) )) % (1 << 8);
mapped_ptr += **inp_surfaceMap.surface[0].pitch**;
NvMediaImageUnlock(nvmimg_in[i]);
