I’m trying to using a ssd with installed system package on a board with new soc. This soc is never used before. but it seems not start up at all. In additional, if I install soc on a board and flash a jetpack on it, then switch the ssd . The system can be activated. Is there any reason could explan?
You need to flash bootloader on your new modules.
For JetPack 5:
sudo ./flash.sh --no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
For JetPack 6:
sudo ./flash.sh --no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
OK. I will try this solution.
