I want to use Isaac on my PC.
I followed https://docs.nvidia.com/isaac/isaac/doc/setup.html to setup it.
When I tried to build an application using the command:
bazel build //apps/samples/stereo_dummy
It got an error as follows:
ERROR: error loading package ‘’: Extension file not found. Unable to load package for ‘//engine/build:isaac.bzl’: BUILD file not found on package path
ERROR: Skipping ‘//apps/samples/stereo_dummy’: no such package ‘apps/samples/stereo_dummy’: BUILD file not found on package path
WARNING: Target pattern parsing failed.
What should I do to solve it?
Please help! Thanks in advance!
