Could not create NVCCP shared memory nvccpmutex
Software Version
[1] DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (940-63710-0010-D00)
other
SDK Manager Version
1.8.2.10409
[1] other
Host Machine Version
[1] other
Hi
we upgrade the DRVIE OS to 6.0.4.0, and now run nvsipl_camera command failed. like below:
root@tegra-ubuntu:/home/nvidia# cat /etc/nvidia/version-ubuntu-rootfs.txt
6.0.4.0-31006010
root@tegra-ubuntu:/home/nvidia# ./nvsipl_camera -v 1 -c MAX96712_RAW12_TPG_DPHY_x4 -m “0x1111 0x0000 0x0000 0x0000” --showfps --disableISP1Output --disableISP2Output --disableISP0Output --enableRawOutput
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
Closing of TACP shared memory handle failed nvccpmutex
how to fix this problem?
Dear @erfeng.jef
Do you see issue when running with sudo?
Hi @SivaRamaKrishnaNV
I’ve switched to executing it as root, and the error is still the same
Dear @erfeng.jef,
Could you please confirm the board revision? Please check P/N number to know revison. Please see if the corresponding board name is used while flashing(AV PCT Configuration)
My board P/N is 940-63710-0010-D00, and I pass the board name BOARD=p3710-10-a01 when flashing.
It seems that there is something wrong with the parameters I passed.
I will try with the BOARD=p3710-10-s05
Thanks very much
