Could not detect correct NVIDIA Jetson device connected to USB
I’m trying to flash Jetpack 6.0 DP onto my SD card and configure Jetson Orin Nano 8gb Developer Kit for the new OS. However, I am encountering error saying “Could not detect correct NVIDIA Jetson device connected to USB”.
First attempt: I tried to follow the SD Card Image Method. I downloaded and flashed the jp6.0 DP.img to the SD card and inserted it into the Jetson Orin Nano, hoping that it would boot. However, the Jetson did not boot with the new SD card. I assumed that this is due to not updating “the QSPI bootloaders by installing … using SDK Manager, which will update the QSPI bootloaders…” as written in the doc.
Second attempt: I tried using SDK manager CLI through Docker. My host machine is Macbook. Mac and Jetson Orin Nano is connected via USB-C. I can see NVIDIA USB and L4T in lsusb output, but not “NVIDIA Corp”. I am able to ping 192.168.55.1 and ping 192.168.55.100.
lsusb output:
network settings:
error message:
Screenshot 2024-02-25 at 12.10.37 AM
Detailed steps for the CLI:
  1. Automatic Setup - Jetson Orin Nano [8GB developer kit]
  2. Continue? - OK
  3. IPv4 = 192.168.55.1 (tried 192.168.55.100 as well)
  4. Username and Password (I don’t recall setting a ID and PW so I set them as blank)
  5. Use current username/password? - Yes
Of course it’s not detected because it’s not even in force recovery mode…
