It always throws this error although I am connected with target device tx2.
Could not detect target hardware
Please make sure the target hardware is connected and is in recovery mode, choose OK and RETRY.
I am using sdkmanager 4.3
15:04:04 INFO : Flash Jetson TX2 : ###############################################################################
15:04:04 INFO : Flash Jetson TX2 : # L4T BSP Information:
15:04:04 INFO : Flash Jetson TX2 : # R32 , REVISION: 3.1
15:04:09 INFO : Flash Jetson TX2 : Error: probing the target board failed.
15:04:09 INFO : Flash Jetson TX2 : Make sure the target board is connected through
15:04:09 INFO : Flash Jetson TX2 : USB port and is in recovery mode.
15:04:09 INFO : Flash Jetson TX2 : exit status 1
15:04:09 INFO : Flash Jetson TX2 : [ Component Install Finished with Error ]
15:04:09 INFO : Flash Jetson TX2 : [ 172.00 KB used. Disk Avail: 26.51 GB ]
15:04:09 INFO : Flash Jetson TX2 : [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 6s ]
15:04:09 ERROR : Flash Jetson TX2 : Run commands failed at step Install: command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
15:04:09 ERROR : Flash Jetson TX2 : command terminated with error
15:04:09 ERROR : Flash Jetson TX2 : install ‘Flash Jetson TX2’ failure, command < cd ‘/home/saggi/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP’ -v=‘32.3’ -l=‘/home/saggi/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310’ -L=‘/home/saggi/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘8918’ -t=‘P3310’ -e=‘undefined’ > terminated with error
