Could not get cuda device count (cudaErrorUnknown) in deepstream
• DeepStream Version
• TensorRT Version
Hii …
i am facing some difficulty on when i starting my pipeline :
INFO:pipeline:Creating Stream Muxer
INFO:pipeline:Creating Inference
Error: Could not get cuda device count (cudaErrorUnknown)
Failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:1392>: failed
INFO:pipeline:Creating Inference-2
INFO:pipeline:Creating Fake Sink
INFO:pipeline:Creating Video Converter
INFO:pipeline:Creating Caps filter 1
INFO:pipeline:Starting DeepStream pipeline…
INFO: Started server process [430]
Unable to set device in gst_nvstreammux_change_state
INFO: Waiting for application startup.
0:00:00.042169211 430 0x747938004bc0 WARN bin gstbin.c:2808:reset_state: Failed to switch back down to NULL
INFO: Application startup complete.
INFO:pipeline:Pipeline set to READY state.
after i execute these two lines like nvcc --version and nvidia-smi in container and as well a inhost then after i started my pipeline script and its running fine…
do you have any idea regarding this error
i am using below version (drivers , cudatoolkit)
Could you attach the command you used to launch your docker?
sudo docker run -it --privileged --name=deepstream_yolov9 --net=host -e CUDA_CACHE_DISABLE=0 -v pwd/Deepstream:/opt/nvidia/deepstream/deepstream-7.1/deepstream_yolov9 nvcr.io/nvidia/deepstream:7.1-triton-multiarch
Do you mean that after you run these two commands, there will be no errors?
Also you can try to set the --privileged=true in your command.
there is no such type of error after executing this in both host cmd prompt as well as in container cmd…
This is weird. We haven’t had this similar problem on our side before. So if you run a new docker, will this issue be occurred again?
yes still same issue … not resolved
if i use --gpus all
i am encountering this below error :
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘legacy’
nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory: unknown.
So will the problem still be solved after you run the following command nvcc --version and nvidia-smi this time?
Have you followed our step-by-step Guide docker-containers to configuring your environment?
