hi,
I want to develop some application on nexus 9 to make use the gpu on it. However, I couldn’t get the cuda to run on it. I installed https://developer.nvidia.com/tegra-android-development-pack. But when I run the cuda sample code, I got the error “driver could not support cuda runtime library”
- During the installation process, do I need to install the cuda library on nexus 9? I got an error when doing this " not authorized"
- Do I need to flash the whole os image to the nexus 9? If yes, how? I tried, but failed, it cannot even find the device when I set it to recovery mode. Maybe the pack is only for http://www.nvidia.com/object/jetson-tk1-embedded-dev-kit.html
I really appreciate the help!
best,
zichao
