ALL:
Booting Linux on physical CPU 0x0
Linux version 4.9.108 (jason@ubuntu) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #8 SMP PREEMPT Thu Mar 28 19:54:31 PDT 2019
Boot CPU: AArch64 Processor [4e0f0040]
OF: fdt:memory scan node memory, reg size 48,
OF: fdt: - 80000000 , 2a000000
OF: fdt: - aa200000 , 46a00000
OF: fdt: - 100000000 , 380000000
earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
enabled
Found tegra_fbmem: 00800000@a0791000
Found lut_mem: 00002008@a078e000
OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
cma: Reserved 64 MiB at 0x00000000ec800000
On node 0 totalpages: 4130816
DMA zone: 7200 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 460800 pages, LIFO batch:31
Normal zone: 57344 pages used for memmap
Normal zone: 3670016 pages, LIFO batch:31
psci: probing for conduit method from DT.
psci: PSCIv1.0 detected in firmware.
psci: Using standard PSCI v0.2 function IDs
psci: MIGRATE_INFO_TYPE not supported.
psci: SMC Calling Convention v1.1
percpu: Embedded 23 pages/cpu @ffffffc3ffdb4000 s54424 r8192 d31592 u94208
pcpu-alloc: s54424 r8192 d31592 u94208 alloc=23*4096
7
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4066272
Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa078e000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
PID hash table entries: 4096 (order: 3, 32768 bytes)
Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Memory: 16124888K/16523264K available (15358K kernel code, 2944K rwdata, 6704K rodata, 8512K init, 1625K bss, 332840K reserved, 65536K cma-reserved)
Virtual kernel memory layout:
modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
.text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
.rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
.init : 0xffffff8009610000 - 0xffffff8009e60000 ( 8512 KB)
.data : 0xffffff8009e60000 - 0xffffff800a140008 ( 2945 KB)
.bss : 0xffffff800a140008 - 0xffffff800a2d6584 ( 1626 KB)
fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 64.
RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
** trace_printk() being used. Allocating extra memory. **
** This means that this is a DEBUG kernel and it is **
** unsafe for production use. **
** If you see this message and you are not debugging **
** the kernel, report this immediately to your vendor! **
NR_IRQS:64 nr_irqs:64 0
GIC: Using split EOI/Deactivate mode
arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
Console: colour dummy device 80x25
enabled
disabled
kmemleak: Kernel memory leak detector disabled
Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
ftrace: allocating 48016 entries in 188 pages
sched-energy: Sched-energy-costs installed from DT
ASID allocator initialised with 65536 entries
tegra-id: chipid=21917.
tegra-id: opt_subrevision=0.
Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
DTB Build time: Mar 28 2019 19:53:36
tegra-roc-flush: DT required.
CPU1: Booted secondary processor [4e0f0040]
CPU2: Booted secondary processor [4e0f0040]
CPU3: Booted secondary processor [4e0f0040]
CPU4: Booted secondary processor [4e0f0040]
CPU5: Booted secondary processor [4e0f0040]
CPU6: Booted secondary processor [4e0f0040]
CPU7: Booted secondary processor [4e0f0040]
Brought up 8 CPUs
SMP: Total of 8 processors activated.
CPU features: detected feature: Privileged Access Never
CPU features: detected feature: LSE atomic instructions
CPU features: detected feature: User Access Override
CPU features: detected feature: 32-bit EL0 Support
CPU: All CPU(s) started at EL2
alternatives: patching kernel code
devtmpfs: initialized
Initilizing CustomIPI irq domain
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
futex hash table entries: 2048 (order: 6, 262144 bytes)
pinctrl core: initialized pinctrl subsystem
OS set in device tree is not L4T.
regulator-dummy: no parameters
Initializing plugin-manager
Plugin module not found
Plugin-manager status disabled
NET: Registered protocol family 16
pstore: using zlib compression
enabled
pstore: Registered ramoops as persistent store backend
ramoops: attached 0x200000@0xf0a00000, ecc: 0/0
cpuidle: using governor menu
bpmp: waiting for handshake
bpmp: handshake completed
bpmp: synchronizing channels
bpmp: channels synchronized
bpmp: mail init ok
t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
t19x-arm-smmu 12000000.iommu: probing hardware configuration...
t19x-arm-smmu 12000000.iommu: SMMUv2 with:
t19x-arm-smmu 12000000.iommu: stage 1 translation
t19x-arm-smmu 12000000.iommu: stage 2 translation
t19x-arm-smmu 12000000.iommu: nested translation
t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e64000)
hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
atomic_pool_init():622: DMA: preallocated 2048 KiB pool for atomic allocations
Registering BPMP clocks...
tegra_bpmp_clk_init: clock init ok (395 clks)
tegra_bpmp_of_clk_init: EMC proxy not found.
tegra_powergate_init: DONE
tegra_debug_uart_syscore_init: stdout-path property missing
Tegra reboot handler registered.
iommu: Adding device 14180000.pcie to group 0
iommu: Adding device 14100000.pcie to group 1
iommu: Adding device 14140000.pcie to group 2
iommu: Adding device 141a0000.pcie to group 3
iommu: Adding device 2490000.ether_qos to group 4
iommu: Adding device 3100000.serial to group 5
iommu: Adding device 3110000.serial to group 6
iommu: Adding device 3140000.serial to group 7
tegra-pmc c360000.pmc: scratch reg offset dts data not present
tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
tegra-pmc: ### PMC reset status reg: 0x2d
tegra-pmc: PMC Prod config success
padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
tegra-pmc c360000.pmc: IO padctrl driver initialized
iommu: Adding device 3460000.sdhci to group 8
iommu: Adding device 3400000.sdhci to group 9
iommu: Adding device 3210000.spi to group 10
iommu: Adding device c260000.spi to group 11
iommu: Adding device 3230000.spi to group 12
iommu: Adding device 3270000.spi to group 13
iommu: Adding device 3300000.spi to group 14
iommu: Adding device 3160000.i2c to group 15
iommu: Adding device c240000.i2c to group 16
iommu: Adding device 3180000.i2c to group 17
iommu: Adding device 3190000.i2c to group 18
iommu: Adding device 31b0000.i2c to group 19
iommu: Adding device 31c0000.i2c to group 20
iommu: Adding device c250000.i2c to group 21
iommu: Adding device 31e0000.i2c to group 22
iommu: Adding device sound to group 23
iommu: Adding device 3510000.hda to group 24
iommu: Adding device bc00000.rtcpu to group 25
iommu: Adding device 13e10000.host1x to group 26
iommu: Adding device 13e10000.host1x:ctx0 to group 27
iommu: Adding device 13e10000.host1x:ctx1 to group 28
iommu: Adding device 13e10000.host1x:ctx2 to group 29
iommu: Adding device 13e10000.host1x:ctx3 to group 30
iommu: Adding device 13e10000.host1x:ctx4 to group 31
iommu: Adding device 13e10000.host1x:ctx5 to group 32
iommu: Adding device 13e10000.host1x:ctx6 to group 33
iommu: Adding device 13e10000.host1x:ctx7 to group 34
iommu: Adding device 15340000.vic to group 35
iommu: Adding device 15380000.nvjpg to group 36
iommu: Adding device 15500000.tsec to group 37
iommu: Adding device 15100000.tsecb to group 38
iommu: Adding device 15480000.nvdec to group 39
iommu: Adding device 15140000.nvdec1 to group 40
iommu: Adding device 154c0000.nvenc to group 41
iommu: Adding device 15a80000.nvenc1 to group 42
iommu: Adding device 15880000.nvdla0 to group 43
iommu: Adding device 158c0000.nvdla1 to group 44
iommu: Adding device 15200000.nvdisplay to group 45
platform 15200000.nvdisplay: IOVA linear map 0x00000000a0791000(800000)
platform 15200000.nvdisplay: IOVA linear map 0x00000000a078e000(3000)
t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
iommu: Adding device 15210000.nvdisplay to group 46
t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
iommu: Adding device 15220000.nvdisplay to group 47
t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
iommu: Adding device 15c10000.vi to group 48
t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
iommu: Adding device 14800000.isp to group 49
iommu: Adding device 16000000.pva0 to group 50
iommu: Adding device 16800000.pva1 to group 51
iommu: Adding device 15810000.se to group 52
iommu: Adding device 15820000.se to group 53
iommu: Adding device 15830000.se to group 54
iommu: Adding device 15840000.se to group 55
iommu: Adding device c1a0000.aon to group 56
iommu: Adding device d000000.bpmp to group 57
bpmp: ping status is 0
bpmp d000000.bpmp: firmware tag is 588c62054ecdba8a44cb9d6ff5d04cb0
bpmp d000000.bpmp: probe ok
tegra-reset 0.bpmp_reset: registered 186 resets.
iommu: Adding device smmu_test to group 58
mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c10000
mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2c20000
mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2c30000
mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
mc: mapped MMIO address: 0xffffff800b210000 -> 0x2b80000
mc: mapped MMIO address: 0xffffff800b230000 -> 0x2b90000
mc: mapped MMIO address: 0xffffff800b250000 -> 0x2ba0000
mc: mapped MMIO address: 0xffffff800b270000 -> 0x2bb0000
mc: mapped MMIO address: 0xffffff800b290000 -> 0x1700000
mc: mapped MMIO address: 0xffffff800b2b0000 -> 0x1710000
mc: mapped MMIO address: 0xffffff800b2d0000 -> 0x1720000
mc: mapped MMIO address: 0xffffff800b2f0000 -> 0x1730000
mc: mapped MMIO address: 0xffffff800b310000 -> 0x1740000
mc: mapped MMIO address: 0xffffff800b330000 -> 0x1750000
mc: mapped MMIO address: 0xffffff800b350000 -> 0x1760000
mc: mapped MMIO address: 0xffffff800b370000 -> 0x1770000
mc-err: mcerr ops are set to t19x
iommu: Adding device 2600000.dma to group 59
GPIO line 339 (wifi-enable) hogged as output/high
gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
GPIO line 253 (pex-refclk-sel-low) hogged as output/low
gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
iommu: Adding device 3550000.xudc to group 60
iommu: Adding device 3610000.xhci to group 61
arm64_ras arm64_ras: RAS driver enabled
carmel_ras_enable:RAS enabled on cpu0
carmel_ras_enable:RAS enabled on cpu1
carmel_ras_enable:RAS enabled on cpu2
carmel_ras_enable:RAS enabled on cpu3
carmel_ras_enable:RAS enabled on cpu4
carmel_ras_enable:RAS enabled on cpu5
carmel_ras_enable:RAS enabled on cpu6
carmel_ras_enable:RAS enabled on cpu7
carmel_ras carmel_ras: probed
tegra-cbb 2300000.cbb-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
tegra-cbb c600000.aon-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
tegra-cbb d600000.bpmp-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
tegra-cbb be00000.rce-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
tegra-cbb b600000.sce-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
vdd-3v3-cvb: 3300 mV
vdd-1v8-cvb: 1800 mV
vdd-1v8-sd: 1800 mV
vdd-epb-1v0: supplied by vdd-3v3-cvb
vdd-epb-1v0: 1000 mV
vdd-sdmmc1-sw: 3300 mV
avdd-cam-2v8: 2800 mV
vdd-sata-1v5: 1500 mV
vdd-1v8-slt: 1800 mV
vdd-3v3-slt: 3300 mV
vdd-fan: 5000 mV
vdd-hdmi-5v0: 5000 mV
vdd_sys_en: 1200 mV
vdd-5v-sata: 5000 mV
vdd-ac-bat: 5000 mV
vdd-5v-sata: supplied by vdd-ac-bat
eventlib_kernel: keventlib is initialized, test id: 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
vdd-1v0: at 1000 mV
vdd-1v8-hs: at 1800 mV
vdd-1v8-ls: at 1800 mV
vdd-1v8-ao: at 1800 mV
vddio-ddr-1v1: at 1100 mV
vdd-rtc: at 800 mV
spmic-ldo1: at 2375 mV
vdd-ao-3v3: at 3300 mV
vddio-emmc-3v3: at 3300 mV
spmic-ldo4: at 1587 mV
vdd-usb-3v3: at 3300 mV
vddio-sdmmc1-3v3: at 3300 mV
vdd-csi-1v2: at 1200 mV
spmic-ldo8: at 1800 mV
GPIO line 246 (gpio_default) hogged as output/high
GPIO line 247 (gpio_default) hogged as output/high
gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
max77620 4-003c: max77620 probe successful
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
tegra_wdt_t18x 30c0000.watchdog: Registered successfully
tegra_fiq_debugger_init: found FIQ source (IRQ 472)
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.22
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
camchar: rtcpu character device driver loaded
clocksource: Switched to clocksource arch_sys_counter
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
nvmap_heap_init: nvmap_heap_init: created heap block cache
tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
nvmap_page_pool_init: Total RAM pages: 4047606
nvmap_page_pool_init: nvmap page pool size: 505950 pages (1976 MB)
nvmap_background_zero_thread: PP zeroing thread starting.
tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
la/ptsa driver initialized.
NET: Registered protocol family 2
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
UDP hash table entries: 8192 (order: 6, 262144 bytes)
UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 128
Trying to unpack rootfs image as initramfs...
host1x 13e10000.host1x: initialized
hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.964:1): initialized
workingset: timestamp_bits=46 max_order=22 bucket_order=0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
ntfs: driver 2.1.32 [Flags: R/W].
9p: Installing v9fs 9p2000 file system support
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
io scheduler noop registered
io scheduler cfq registered (default)
gic 2a41000.agic-controller: GIC IRQ controller registered
random: fast init done
iommu: Adding device 2993000.adsp to group 62
iommu: Adding device aconnect@2a41000:adsp_audio to group 63
tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
tegra-pwm c340000.pwm: PWM clk can sleep in ops
tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
tsec 15500000.tsec: initialized
tsec 15100000.tsecb: initialized
nvdec 15480000.nvdec: initialized
nvdec 15140000.nvdec1: initialized
falcon 15340000.vic: initialized
falcon 15380000.nvjpg: initialized
falcon 154c0000.nvenc: initialized
falcon 15a80000.nvenc1: initialized
iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
t194-nvcsi 15a00000.nvcsi: initialized
scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
scare-pigeon 14b00000.isp-thi: initialized
pva 16000000.pva0: initialized
pva 16800000.pva1: initialized
nvdla 15880000.nvdla0: initialized
nvdla 158c0000.nvdla1: initialized
tegra-slvs-ec 15ac0000.slvs-ec: initialized
tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
tegra-slvs-ec 15ac0000.slvs-ec: probed
tegradccommon 15200000.dc_common: host1x channel mapped
tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
tegradccommon 15200000.dc_common: dma mapping done
tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
generic_infoframe_type: 0x87
tegradc 15200000.nvdisplay: DT parsed successfully
tegradc 15200000.nvdisplay: Display dc.ffffff800bfd0000 registered with id=0
tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
kfuse 3830000.kfuse: initialized
tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
tegradc 15200000.nvdisplay: probed
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
enabled
Console: switching to colour frame buffer device 240x67
syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
tegradc 15200000.nvdisplay: fb registered
gpio tegra-gpio wake71 for gpio=98(M:2)
brd: module loaded
loop: module loaded
tegra_profiler: version: 1.128, samples/io: 44/25
tegra_profiler: auth: init
nct1008_nct72 4-004c: starting parse dt
nct1008_nct72 4-004c: !!!Found deprecated property!!!
THERMAL EST: found 3 subdevs
THERMAL EST num_resources: 0
[THERMAL EST subdev 0]
[THERMAL EST subdev 1]
[THERMAL EST subdev 2]
thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
THERMAL EST: thz register success.
THERMAL EST: end of probe, return err: 0
hisi_sas: driver version v1.6
tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
nct1008_nct72 4-004c: success parsing dt
Parent Clock set for DC plld3
nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
tegra-qspi 3270000.spi: Prod settings list not found
tegra-qspi 3300000.spi: Prod settings list not found
nct1008_nct72 4-004c: LOC shutdown limit 107
nct1008_nct72 4-004c: EXT shutdown limit 109
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
igb: Copyright (c) 2007-2014 Intel Corporation.
igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
Copyright(c) 1999 - 2017 Intel Corporation.
sky2: driver version 1.30
eqos 2490000.ether_qos: no PHY interrupt found
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
VFIO - User Level meta-driver version: 0.3
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-pci: OHCI PCI platform driver
ohci-platform: OHCI generic platform driver
eqos 2490000.ether_qos: No prod values found
eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb ad 2f
libphy: dwc_phy: probed
tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
Could not get extcon-dev /xhci@3610000:id(0)
usbcore: registered new interface driver uas
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
Could not get extcon-dev /xudc@3550000:vbus(0)
tegra-i2c c240000.i2c: no acknowledge from address 0x8
ucsi_ccg 1-0008: read version failed
ucsi_ccg 1-0008: get_fw_info fail,, err=-121
ucsi_ccg: probe of 1-0008 failed with error -121
mousedev: PS/2 mouse device common for all mice
tegradc 15200000.nvdisplay: hdmi: tmds rate:148367K prod-setting:prod_c_hdmi_111m_223m
Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
Wake73 for irq=42
rtc rtc1: alarm rtc device
tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
i2c /dev entries driver
max77620-power max20024-power: Event recorder REG_NVERC : 0x0
FAN dev name: pwm-fan
FAN:gpio request success.
FAN: can't find tach_gpio
pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
pwm_fan_driver pwm-fan: tach period: 1000
pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
tegra194_cpufreq_probe: platform driver Initialization: pass
cpuidle: Initializing cpuidle driver
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
sdhci-tegra 3400000.sdhci: Got CD GPIO
sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
tegra-se-nvhost 15810000.se: initialized
tegra-se-nvhost 15810000.se: tegra_se_probe: complete
tegra-se-nvhost 15820000.se: initialized
tegra-se-nvhost 15820000.se: tegra_se_probe: complete
tegra-se-nvhost 15830000.se: initialized
tegra-se-nvhost 15830000.se: tegra_se_probe: complete
tegra-se-nvhost 15840000.se: initialized
tegra-se-nvhost 15840000.se: tegra_se_probe: complete
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
tegra_aon c1a0000.aon: tegra aon driver probe OK
tegra186-aondbg aondbg: aondbg driver probe() OK
denver_knobs_init:MTS_VERSION:43306594
tegra19x_actmon d230000.actmon: in actmon_register()...
tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
t19x_cache tegra-cache: probed
misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
nvpmodel: initialized successfully
usbcore: registered new interface driver snd-usb-audio
tegra-hda 3510000.hda: Override SDO lines to 4
using ADMA 64-bit with 64 bit addr
input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
gpio tegra-gpio wake8 for gpio=55(G:7)
mmc0: periodic cache flush enabled
mmc0: new HS400 Enhanced strobe MMC card at address 0001
mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36
tegradc 15200000.nvdisplay: blank - powerdown
nct1008_nct72 4-004c: initial LOC temp: 30000
nct1008_nct72 4-004c: initial EXT temp: 34500
nct1008_nct72 4-004c: hi_b:-10, lo_b:128
nct1008_nct72 4-004c: nct1008_probe: initialized
tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
tegradc 15200000.nvdisplay: blank - normal
tegradc 15200000.nvdisplay: unblank
tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
gpio tegra-gpio wake12 for gpio=149(S:5)
OPE platform probe
OPE platform probe successful
tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
u32 classifier
Actions configured
Initializing XFRM netlink socket
NET: Registered protocol family 10
NET: Registered protocol family 17
NET: Registered protocol family 15
bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
9pnet: Installing 9P2000 support
Key type dns_resolver registered
Registered cp15_barrier emulation handler
Registered setend emulation handler
registered taskstats version 1
tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
OF: PCI: host bridge /pcie@14180000 ranges:
OF: PCI: IO 0x38100000..0x381fffff -> 0x38100000
OF: PCI: MEM 0x38200000..0x39ffffff -> 0x38200000
OF: PCI: MEM 0x1800000000..0x1bffffffff -> 0x1800000000
tegra-pcie-dw 14180000.pcie: link is down
tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [bus 00-ff]
(bus address [0x38100000-0x381fffff])
pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
type 01 class 0x060400
pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
iommu: Adding device 0000:00:00.0 to group 64
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
aer 0000:00:00.0:pcie002: service driver aer loaded
pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
aer 0000:00:00.0:pcie002: unloading service driver aer
is released
iommu: Removing device 0000:00:00.0 from group 64
is released
tegra-pcie-dw 14180000.pcie: PCIe link is not up...!
tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
OF: PCI: host bridge /pcie@14100000 ranges:
OF: PCI: IO 0x30100000..0x301fffff -> 0x30100000
OF: PCI: MEM 0x30200000..0x31ffffff -> 0x30200000
OF: PCI: MEM 0x1200000000..0x123fffffff -> 0x1200000000
tegradc 15200000.nvdisplay: hdmi: plugged
tegra-pcie-dw 14100000.pcie: link is down
tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
pci_bus 0001:00: root bus resource [bus 00-ff]
(bus address [0x30100000-0x301fffff])
pci_bus 0001:00: root bus resource [mem 0x30200000-0x31ffffff]
pci_bus 0001:00: root bus resource [mem 0x1200000000-0x123fffffff pref]
pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
iommu: Adding device 0001:00:00.0 to group 64
pci 0001:00:00.0: PCI bridge to [bus 01-ff]
pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
aer 0001:00:00.0:pcie002: service driver aer loaded
pcie_pme 0001:00:00.0:pcie001: unloading service driver pcie_pme
aer 0001:00:00.0:pcie002: unloading service driver aer
is released
iommu: Removing device 0001:00:00.0 from group 64
is released
tegra-pcie-dw 14100000.pcie: PCIe link is not up...!
tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
OF: PCI: host bridge /pcie@14140000 ranges:
OF: PCI: IO 0x34100000..0x341fffff -> 0x34100000
OF: PCI: MEM 0x34200000..0x35ffffff -> 0x34200000
OF: PCI: MEM 0x1280000000..0x12bfffffff -> 0x1280000000
tegra-pcie-dw 14140000.pcie: link is down
tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0002:00
pci_bus 0002:00: root bus resource [bus 00-ff]
(bus address [0x34100000-0x341fffff])
pci_bus 0002:00: root bus resource [mem 0x34200000-0x35ffffff]
pci_bus 0002:00: root bus resource [mem 0x1280000000-0x12bfffffff pref]
pci 0002:00:00.0: PME# supported from D0 D3hot D3cold
iommu: Adding device 0002:00:00.0 to group 64
pci 0002:00:00.0: PCI bridge to [bus 01-ff]
pci 0002:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
pcieport 0002:00:00.0: Signaling PME through PCIe PME interrupt
pcie_pme 0002:00:00.0:pcie001: service driver pcie_pme loaded
aer 0002:00:00.0:pcie002: service driver aer loaded
pcie_pme 0002:00:00.0:pcie001: unloading service driver pcie_pme
aer 0002:00:00.0:pcie002: unloading service driver aer
is released
iommu: Removing device 0002:00:00.0 from group 64
is released
tegra-pcie-dw 14140000.pcie: PCIe link is not up...!
tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
OF: PCI: host bridge /pcie@141a0000 ranges:
OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
OF: PCI: MEM 0x3a200000..0x3bffffff -> 0x3a200000
OF: PCI: MEM 0x1c00000000..0x1fffffffff -> 0x1c00000000
tegra-pcie-dw 141a0000.pcie: link is down
tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0003:00
pci_bus 0003:00: root bus resource [bus 00-ff]
(bus address [0x3a100000-0x3a1fffff])
pci_bus 0003:00: root bus resource [mem 0x3a200000-0x3bffffff]
pci_bus 0003:00: root bus resource [mem 0x1c00000000-0x1fffffffff pref]
pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
iommu: Adding device 0003:00:00.0 to group 64
pci 0003:00:00.0: PCI bridge to [bus 01-ff]
pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
aer 0003:00:00.0:pcie002: service driver aer loaded
pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
aer 0003:00:00.0:pcie002: unloading service driver aer
is released
iommu: Removing device 0003:00:00.0 from group 64
is released
tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
tegra-cbb 14040000.cv-noc: noc_secure_irq = 101, noc_nonsecure_irq = 100>
tegra194-isp5 14800000.isp: initialized
tegra194-vi5 15c10000.vi: initialized
tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
tegra186-cam-rtcpu bc00000.rtcpu: Coverage buffer configured at IOVA=0xbfef8000
tegra186-cam-rtcpu bc00000.rtcpu: IOVM setup error: 130
tegra186-cam-rtcpu bc00000.rtcpu: RTCPU coverage: IOVM setup error : 4294967291
tegra186-cam-rtcpu bc00000.rtcpu: (expected if RTCPU was not built with coverage enabled)
tegra186-cam-rtcpu bc00000.rtcpu: coverage boot sync status: -5
tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
tegra-ivc-cdev ivc-bc00000.rtcpu:echo@0: probing /dev/camchar-echo
tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
tegra-ivc-cdev ivc-bc00000.rtcpu:dbg@1: probing /dev/camchar-dbg
tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (72)
tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=5d9f1c48356a1dad5a597123920f5319cb04aa87
gpio tegra-gpio wake67 for gpio=48(G:0)
gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
input: gpio-keys as /devices/gpio-keys/input/input5
tegra_rtc c2a0000.rtc: setting system clock to 2019-05-07 09:18:01 UTC (1557220681)
mmcblk mmc0:0001: Card claimed for testing.
bpmp: mounted debugfs mirror
vdd-1v8-cvb: disabling
vdd-1v8-sd: disabling
vdd-epb-1v0: disabling
vdd-sdmmc1-sw: disabling
avdd-cam-2v8: disabling
vdd-sata-1v5: disabling
vdd-3v3-slt: disabling
vdd-fan: disabling
vdd_sys_en: disabling
vdd-5v-sata: disabling
ALSA device list:
#0: tegra-hda-galen-t194 at 0x3518000 irq 71
#1: tegra-snd-t19x-mobile-rt565x
EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:1.
devtmpfs: mounted
Freeing unused kernel memory: 8512K
ip_tables: (C) 2000-2006 Netfilter Core Team
cgroup: cgroup2: unknown option "nsdelegate"
systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
systemd[1]: Detected architecture arm64.
systemd[1]: Set hostname to <jetson-0423518031540>.
systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
random: systemd: uninitialized urandom read (16 bytes read)
systemd[1]: Reached target Swap.
systemd[1]: Started Forward Password Requests to Wall Directory Watch.
systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
systemd[1]: Created slice User and Session Slice.
systemd[1]: Reached target User and Group Name Lookups.
EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
gpio tegra-gpio wake44 for gpio=192(Y:0)
systemd-journald[2366]: Received request to flush runtime journal from PID 1
bmi160 8-0069: nvs_vregs_init vdd err=-19
bmi160 8-0069: nvs_vregs_init vdd_IO err=-19
tegra-i2c 31e0000.i2c: no acknowledge from address 0x69
bmi160 8-0069: bmi_i2c_rd ERR: 0x00
bmi160 8-0069: bmi_init _id_i2c ERR
bmi160 8-0069: bmi_pm pm_en=0 ERR=-22
bmi160 8-0069: bmi_remove
bmi160 8-0069: bmi_probe done
spidev: module is already loaded
random: crng init done
random: 7 urandom warning(s) missed due to ratelimiting
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
CAN device driver interface
Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x00000300|
| rxbc_rbsa |0x00000540|
| txefc_efsa |0x00000780|
| txbc_tbsa |0x00000800|
| tmc_tmsa |0x00000c80|
Release 3.2.0 from 19.12.2014
net can0: mttcan device registered (regs=ffffff8008007000, irq=69)
| base addr |0x0c322000|
net can1: mttcan device registered (regs=ffffff800800d000, irq=70)
mttcan c310000.mttcan can0: Bitrate set
CPU4: shutdown
mttcan c320000.mttcan can1: Bitrate set
mttcan_controller_config: ctrlmode 30
psci: CPU4 killed.
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
CPU5: shutdown
psci: CPU5 killed.
CPU6: shutdown
psci: CPU6 killed.
gpio tegra-gpio wake20 for gpio=52(G:4)
CPU7: shutdown
psci: CPU7 killed.
no value change, same mask already set
eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP socket layer initialized
fuse init (API version 7.26)
