I get below error when I try to create an engine from .etlt model using tao_converter.
[ERROR] 1: [wrapper.cpp::CublasWrapper::85] Error Code 1: Cublas (Could not initialize cublas. Please check CUDA installation.)
[ERROR] Unable to create engine
Environment
TensorRT Version: 8.2.3 GPU Type: Geforce RTX 3060 Nvidia Driver Version: 530.30.02 CUDA Version: 11.6.1 CUDNN Version: 8.3.3 Operating System + Version: Ubuntu 20.04 Python Version (if applicable): 3.8 TensorFlow Version (if applicable): NA PyTorch Version (if applicable): NA Baremetal or Container (if container which image + tag): Container - nvcr.io/nvidia/tensorrt:22.03-py3
This is my Dockerfile:
FROM nvcr.io/nvidia/tensorrt:22.03-py3
RUN apt-get update && apt-get install libgl1 -y
RUN pip3 install -U pip
ADD requirements.txt /tmp/requirements.txt
RUN pip3 install -r /tmp/requirements.txt
RUN /opt/tensorrt/install_opensource.sh
CMD ["bash"]
The image got built without any error, but I get the above mentioned error when I try to convert the etlt model to engine using tao_converter(8.2 version). Kindly help me fix this issue.
Hi @AakankshaS , Thanks for the reply. I’m already using the TensorRT container from NGC. Kindly refer the my comment in the environment section. The container version I’m using - nvcr.io/nvidia/tensorrt:22.03-py3
