Could not initialize cudnn JETSON NANO
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0
Hello i have installed deepstream 6.0 but i’m not being able to run the deepstream app, it seems a problem related to cudnn .
sudo deepstream-app -c source2_1080p_dec_infer-resnet_demux_int8.txt
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b1gpu0_int8.engine open error
0:00:02.881627187 17122   0x7f1c002330 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b1gpu0_int8.engine failed
0:00:02.882854352 17122   0x7f1c002330 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b1gpu0_int8.engine failed, try rebuild
0:00:02.882911072 17122   0x7f1c002330 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
ERROR: [TRT]: 1: [executionResources.cpp::setTacticSources::156] Error Code 1: Cudnn (Could not initialize cudnn, please check cudnn installation.)
ERROR: Build engine failed from config file
ERROR: failed to build trt engine.
0:00:05.601983510 17122   0x7f1c002330 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:05.603817252 17122   0x7f1c002330 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:05.603872045 17122   0x7f1c002330 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:05.603937046 17122   0x7f1c002330 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:05.603964859 17122   0x7f1c002330 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: <main:707>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
Altough the cuda device is detected :
usr/local/cuda/samples/1_Utilities/deviceQuery$ ./deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA Tegra X1"
  CUDA Driver Version / Runtime Version          10.2 / 10.2
  CUDA Capability Major/Minor version number:    5.3
  Total amount of global memory:                 3964 MBytes (4156514304 bytes)
  ( 1) Multiprocessors, (128) CUDA Cores/MP:     128 CUDA Cores
  GPU Max Clock rate:                            922 MHz (0.92 GHz)
  Memory Clock rate:                             13 Mhz
  Memory Bus Width:                              64-bit
  L2 Cache Size:                                 262144 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
  Maximum Layered 1D Texture Size, (num) layers  1D=(16384), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(16384, 16384), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 32768
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 1 copy engine(s)
  Run time limit on kernels:                     Yes
  Integrated GPU sharing Host Memory:            Yes
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Compute Preemption:            No
  Supports Cooperative Kernel Launch:            No
  Supports MultiDevice Co-op Kernel Launch:      No
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.2, CUDA Runtime Version = 10.2, NumDevs = 1
Result = PASS
Any idea how to solve this ?
• TensorRT Version
• Hardware Platform (Jetson / GPU) : Jetson
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.3
• TensorRT Version 8.2.1.9
• Issue Type( questions, new requirements, bugs) : I have installed deepstream 6.0.1 on Jetson nano and when i try to run the sample app. I get this error :
• How to reproduce the issue ? Trying to run deepstream-app using the source2_1080p_dec_infer-resnet_demux_int8.txt config file.
could you share the result of “dpkg -l|grep cudnn”? please check if the device meets this requirements.
dpkg -l|grep cudnn
ii  libcudnn8                                             8.2.1.32-1+cuda10.2                        arm64        cuDNN runtime libraries
ii  libcudnn8-dev                                         8.2.1.32-1+cuda10.2                        arm64        cuDNN development libraries and headers
ii  libcudnn8-samples                                     8.2.1.32-1+cuda10.2                        arm64        cuDNN documents and samples
ii  nvidia-container-csv-cudnn                            8.2.1.32-1+cuda10.2                        arm64        Jetpack CUDNN CSV file
and :
dpkg -l | grep nvinfer
ii  libnvinfer-bin                                        8.2.1-1+cuda10.2                           arm64        TensorRT binaries
ii  libnvinfer-dev                                        8.2.1-1+cuda10.2                           arm64        TensorRT development libraries and headers
ii  libnvinfer-doc                                        8.2.1-1+cuda10.2                           all          TensorRT documentation
ii  libnvinfer-plugin-dev                                 8.2.1-1+cuda10.2                           arm64        TensorRT plugin libraries
ii  libnvinfer-plugin8                                    8.2.1-1+cuda10.2                           arm64        TensorRT plugin libraries
ii  libnvinfer-samples                                    8.2.1-1+cuda10.2                           all          TensorRT samples
ii  libnvinfer8                                           8.2.1-1+cuda10.2                           arm64        TensorRT runtime libraries
ii  python3-libnvinfer                                    8.2.1-1+cuda10.2                           arm64        Python 3 bindings for TensorRT
ii  python3-libnvinfer-dev                                8.2.1-1+cuda10.2                           arm64        Python 3 development package for TensorRT
I think it could be realted to the deepstream installation. Should i try to reinstall it ?
please install 4.6.1, which is consistent with the requirements.
Does that mean i need to flash the jetson ?
yes, please use the same component version with the table above.
