Could not install Nvidia driver in GPU-passthrough VM
Host Hardware:
AMD EPYC 9554
Scenario:
  • Linux Kernel 5.10 host with Tesla L40
  • Single CentOS 7 VM
  • Attempting GPU-passthrough install NVIDIA driver on VM
On VM:
sh NVIDIA-Linux-x86_64-525.147.05.run
Unable to load the kernel module ‘nvidia.ko’ error.
/var/log/nvidia-install.log show as follows:
Actually, I have tried the same version of NVIDIA driver in Host, it works well.
My server is Dell R7625.
I have read several topcis said that the “above 4G decoding” should be opened, but there is no such options in BIOS.
Anyone could help me fix this ?
HOST config:
[root@gpu0008 ~]# uname -a
Linux gpu0008.f.pri.idc2f.shanghai.tjdxspl 5.10.0-60.67.0.104.ule3.x86_64 #1 SMP Wed Aug 16 15:31:25 CST 2023 x86_64 x86_64 x86_64 GNU/Linux
[root@gpu0008 ~]# rpm -qa |grep kernel
kernel-headers-5.10.0-60.67.0.104.ule3.x86_64
kernel-devel-5.10.0-60.67.0.104.ule3.x86_64
kernel-tools-5.10.0-60.67.0.104.ule3.x86_64
kernel-5.10.0-60.67.0.104.ule3.x86_64
[root@gpu0008 ~]# lscpu | grep Virtualization
Virtualization: AMD-V
[root@gpu0008 ~]# lspci -nnk | grep -i nvidia
21:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:26b5] (rev a1)
Subsystem: NVIDIA Corporation Device [10de:169d]
e1:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:26b5] (rev a1)
[root@gpu0008 ~]# cat /etc/modprobe.d/vfio.conf
options vfio-pci ids=10de:26b5
[root@localhost /]# dmesg | grep -E “DMAR: IOMMU”
[root@gpu0008 ~]# dmesg | grep -i iommu
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.10.0-60.67.0.104.ule3.x86_64 root=/dev/mapper/wocloud_vg-lv_root ro crashkernel=512M rd.lvm.lv=wocloud_vg/lv_root rd.driver.pre=vfio-pci pci=realloc amd_iommu=on iommu=pt rhgb quiet selinux=0
[ 0.016960] Kernel command line: BOOT_IMAGE=/vmlinuz-5.10.0-60.67.0.104.ule3.x86_64 root=/dev/mapper/wocloud_vg-lv_root ro crashkernel=512M rd.lvm.lv=wocloud_vg/lv_root rd.driver.pre=vfio-pci pci=realloc amd_iommu=on iommu=pt rhgb quiet selinux=0
[ 1.189708] iommu: Default domain type: Passthrough (set via kernel command line)
[ 1.432572] pci 0000:60:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432601] pci 0000:40:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432611] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432621] pci 0000:20:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432653] pci 0000:e0:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432666] pci 0000:c0:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432678] pci 0000:80:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432691] pci 0000:a0:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.432733] pci 0000:00:00.3: Adding to iommu group 0
[ 1.432748] pci 0000:00:01.0: Adding to iommu group 1
[ 1.432757] pci 0000:00:01.1: Adding to iommu group 2
[ 1.432771] pci 0000:00:02.0: Adding to iommu group 3
[ 1.432784] pci 0000:00:03.0: Adding to iommu group 4
[ 1.432797] pci 0000:00:04.0: Adding to iommu group 5
[ 1.432816] pci 0000:00:05.0: Adding to iommu group 6
[ 1.432825] pci 0000:00:05.1: Adding to iommu group 7
[ 1.432843] pci 0000:00:07.0: Adding to iommu group 8
[ 1.432851] pci 0000:00:07.1: Adding to iommu group 8
[ 1.432870] pci 0000:00:14.0: Adding to iommu group 9
[ 1.432877] pci 0000:00:14.3: Adding to iommu group 9
[ 1.432927] pci 0000:00:18.0: Adding to iommu group 10
[ 1.432936] pci 0000:00:18.1: Adding to iommu group 10
[ 1.432946] pci 0000:00:18.2: Adding to iommu group 10
[ 1.432955] pci 0000:00:18.3: Adding to iommu group 10
[ 1.432964] pci 0000:00:18.4: Adding to iommu group 10
[ 1.432977] pci 0000:00:18.5: Adding to iommu group 10
[ 1.432986] pci 0000:00:18.6: Adding to iommu group 10
[ 1.432996] pci 0000:00:18.7: Adding to iommu group 10
[ 1.433047] pci 0000:00:19.0: Adding to iommu group 11
[ 1.433057] pci 0000:00:19.1: Adding to iommu group 11
[ 1.433065] pci 0000:00:19.2: Adding to iommu group 11
[ 1.433074] pci 0000:00:19.3: Adding to iommu group 11
[ 1.433082] pci 0000:00:19.4: Adding to iommu group 11
[ 1.433090] pci 0000:00:19.5: Adding to iommu group 11
[ 1.433099] pci 0000:00:19.6: Adding to iommu group 11
[ 1.433108] pci 0000:00:19.7: Adding to iommu group 11
[ 1.433118] pci 0000:01:00.0: Adding to iommu group 12
[ 1.433129] pci 0000:01:00.1: Adding to iommu group 13
[ 1.433143] pci 0000:02:00.0: Adding to iommu group 14
[ 1.433147] pci 0000:03:00.0: Adding to iommu group 8
[ 1.433151] pci 0000:03:00.1: Adding to iommu group 8
[ 1.433155] pci 0000:03:00.4: Adding to iommu group 8
[ 1.433158] pci 0000:03:00.5: Adding to iommu group 8
[ 1.433183] pci 0000:20:00.3: Adding to iommu group 15
[ 1.433199] pci 0000:20:01.0: Adding to iommu group 16
[ 1.433210] pci 0000:20:01.1: Adding to iommu group 17
[ 1.433225] pci 0000:20:02.0: Adding to iommu group 18
[ 1.433241] pci 0000:20:03.0: Adding to iommu group 19
[ 1.433259] pci 0000:20:04.0: Adding to iommu group 20
[ 1.433275] pci 0000:20:05.0: Adding to iommu group 21
[ 1.433296] pci 0000:20:07.0: Adding to iommu group 22
[ 1.433307] pci 0000:20:07.1: Adding to iommu group 22
[ 1.433318] pci 0000:21:00.0: Adding to iommu group 23
[ 1.433322] pci 0000:22:00.0: Adding to iommu group 22
[ 1.433325] pci 0000:22:00.1: Adding to iommu group 22
[ 1.433350] pci 0000:40:00.3: Adding to iommu group 24
[ 1.433364] pci 0000:40:01.0: Adding to iommu group 25
[ 1.433387] pci 0000:40:02.0: Adding to iommu group 26
[ 1.433401] pci 0000:40:03.0: Adding to iommu group 27
[ 1.433418] pci 0000:40:04.0: Adding to iommu group 28
[ 1.433432] pci 0000:40:05.0: Adding to iommu group 29
[ 1.433451] pci 0000:40:07.0: Adding to iommu group 30
[ 1.433461] pci 0000:40:07.1: Adding to iommu group 30
[ 1.433464] pci 0000:41:00.0: Adding to iommu group 30
[ 1.433466] pci 0000:41:00.1: Adding to iommu group 30
[ 1.433490] pci 0000:60:00.3: Adding to iommu group 31
[ 1.433504] pci 0000:60:01.0: Adding to iommu group 32
[ 1.433521] pci 0000:60:01.1: Adding to iommu group 33
[ 1.433535] pci 0000:60:02.0: Adding to iommu group 34
[ 1.433549] pci 0000:60:03.0: Adding to iommu group 35
[ 1.433562] pci 0000:60:04.0: Adding to iommu group 36
[ 1.433578] pci 0000:60:05.0: Adding to iommu group 37
[ 1.433588] pci 0000:60:05.2: Adding to iommu group 38
[ 1.433597] pci 0000:60:05.3: Adding to iommu group 39
[ 1.433621] pci 0000:60:07.0: Adding to iommu group 40
[ 1.433636] pci 0000:60:07.1: Adding to iommu group 40
[ 1.433647] pci 0000:60:07.2: Adding to iommu group 40
[ 1.433657] pci 0000:61:00.0: Adding to iommu group 41
[ 1.433660] pci 0000:62:00.0: Adding to iommu group 41
[ 1.433681] pci 0000:63:00.0: Adding to iommu group 42
[ 1.433692] pci 0000:63:00.1: Adding to iommu group 42
[ 1.433702] pci 0000:64:00.0: Adding to iommu group 43
[ 1.433712] pci 0000:64:00.1: Adding to iommu group 44
[ 1.433715] pci 0000:65:00.0: Adding to iommu group 40
[ 1.433722] pci 0000:65:00.1: Adding to iommu group 40
[ 1.433725] pci 0000:65:00.4: Adding to iommu group 40
[ 1.433727] pci 0000:66:00.0: Adding to iommu group 40
[ 1.433756] pci 0000:80:00.3: Adding to iommu group 45
[ 1.433770] pci 0000:80:01.0: Adding to iommu group 46
[ 1.433784] pci 0000:80:02.0: Adding to iommu group 47
[ 1.433797] pci 0000:80:03.0: Adding to iommu group 48
[ 1.433815] pci 0000:80:04.0: Adding to iommu group 49
[ 1.433829] pci 0000:80:05.0: Adding to iommu group 50
[ 1.433848] pci 0000:80:07.0: Adding to iommu group 51
[ 1.433860] pci 0000:80:07.1: Adding to iommu group 51
[ 1.433862] pci 0000:81:00.0: Adding to iommu group 51
[ 1.433868] pci 0000:81:00.1: Adding to iommu group 51
[ 1.433870] pci 0000:81:00.5: Adding to iommu group 51
[ 1.433895] pci 0000:a0:00.3: Adding to iommu group 52
[ 1.433909] pci 0000:a0:01.0: Adding to iommu group 53
[ 1.433919] pci 0000:a0:01.1: Adding to iommu group 54
[ 1.433933] pci 0000:a0:02.0: Adding to iommu group 55
[ 1.433946] pci 0000:a0:03.0: Adding to iommu group 56
[ 1.433960] pci 0000:a0:04.0: Adding to iommu group 57
[ 1.433973] pci 0000:a0:05.0: Adding to iommu group 58
[ 1.433996] pci 0000:a0:07.0: Adding to iommu group 59
[ 1.434008] pci 0000:a0:07.1: Adding to iommu group 59
[ 1.434022] pci 0000:a1:00.0: Adding to iommu group 60
[ 1.434031] pci 0000:a1:00.1: Adding to iommu group 61
[ 1.434039] pci 0000:a2:00.0: Adding to iommu group 59
[ 1.434042] pci 0000:a2:00.1: Adding to iommu group 59
[ 1.434066] pci 0000:c0:00.3: Adding to iommu group 62
[ 1.434079] pci 0000:c0:01.0: Adding to iommu group 63
[ 1.434093] pci 0000:c0:02.0: Adding to iommu group 64
[ 1.434110] pci 0000:c0:03.0: Adding to iommu group 65
[ 1.434123] pci 0000:c0:04.0: Adding to iommu group 66
[ 1.434137] pci 0000:c0:05.0: Adding to iommu group 67
[ 1.434155] pci 0000:c0:07.0: Adding to iommu group 68
[ 1.434167] pci 0000:c0:07.1: Adding to iommu group 68
[ 1.434170] pci 0000:c1:00.0: Adding to iommu group 68
[ 1.434176] pci 0000:c1:00.1: Adding to iommu group 68
[ 1.434200] pci 0000:e0:00.3: Adding to iommu group 69
[ 1.434214] pci 0000:e0:01.0: Adding to iommu group 70
[ 1.434224] pci 0000:e0:01.1: Adding to iommu group 71
[ 1.434241] pci 0000:e0:02.0: Adding to iommu group 72
[ 1.434255] pci 0000:e0:03.0: Adding to iommu group 73
[ 1.434269] pci 0000:e0:04.0: Adding to iommu group 74
[ 1.434283] pci 0000:e0:05.0: Adding to iommu group 75
[ 1.434301] pci 0000:e0:07.0: Adding to iommu group 76
[ 1.434314] pci 0000:e0:07.1: Adding to iommu group 76
[ 1.434324] pci 0000:e1:00.0: Adding to iommu group 77
[ 1.434327] pci 0000:e2:00.0: Adding to iommu group 76
[ 1.434330] pci 0000:e2:00.1: Adding to iommu group 76
[ 1.435116] pci 0000:60:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.435120] pci 0000:40:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.435122] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.435124] pci 0000:20:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.435126] pci 0000:e0:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.435128] pci 0000:c0:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.435130] pci 0000:80:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.435132] pci 0000:a0:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.451740] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 1.451759] perf/amd_iommu: Detected AMD IOMMU #1 (2 banks, 4 counters/bank).
[ 1.451775] perf/amd_iommu: Detected AMD IOMMU #2 (2 banks, 4 counters/bank).
[ 1.451794] perf/amd_iommu: Detected AMD IOMMU #3 (2 banks, 4 counters/bank).
[ 1.451814] perf/amd_iommu: Detected AMD IOMMU #4 (2 banks, 4 counters/bank).
[ 1.451833] perf/amd_iommu: Detected AMD IOMMU #5 (2 banks, 4 counters/bank).
[ 1.451853] perf/amd_iommu: Detected AMD IOMMU #6 (2 banks, 4 counters/bank).
[ 1.451872] perf/amd_iommu: Detected AMD IOMMU #7 (2 banks, 4 counters/bank).
[root@gpu0008 ~]# grep pci /etc/modules-load.d/*
vfio_pci
[root@gpu0008 ~]# dmesg | grep -E vfio_pci
[ 1.861671] vfio_pci: add [10de:26b5[ffffffff:ffffffff]] class 0x000000/00000000
[ 436.327539] vfio_pci: vfio_pci_dma_fault_init: Get DOMAIN_ATTR_NESTING failed: -19.
[ 436.327540] vfio_pci: vfio_pci_dma_fault_response_init: Get DOMAIN_ATTR_NESTING failed: -19.
[ 954.367725] vfio_pci: vfio_pci_dma_fault_init: Get DOMAIN_ATTR_NESTING failed: -19.
[ 954.367726] vfio_pci: vfio_pci_dma_fault_response_init: Get DOMAIN_ATTR_NESTING failed: -19.
[root@gpu0008 ~]# virsh version
Compiled against library: libvirt 6.2.0
Using library: libvirt 6.2.0
Using API: QEMU 6.2.0
Running hypervisor: QEMU 3.0.0
[root@gpu0008 ~]# lsmod | grep kvm
kvm_amd 122880 19
ccp 118784 1 kvm_amd
kvm 978944 1 kvm_amd
irqbypass 16384 6 vfio_pci,kvm
VM config:
[root@localhost ~]# rpm -qa | grep kernel
kernel-devel-5.10.0-60.67.0.96.ule3.x86_64
kernel-tools-5.10.0-60.67.0.96.ule3.x86_64
kernel-headers-5.10.0-60.67.0.96.ule3.x86_64
kernel-5.10.0-60.67.0.96.ule3.x86_64
[root@vm1cent ~]# lspci -nnk | grep NVIDIA
00:07.0 3D controller [0302]: NVIDIA Corporation Device [10de:26b5] (rev a1)
[root@vm1cent ~]# grep -i nvidia /etc/modprobe.d/* /lib/modprobe.d/*
/lib/modprobe.d/dist-blacklist.conf:blacklist nvidiafb
echo 1 > /sys/bus/pci/devices/0000:00:08.0/remove
echo 1 > /sys/bus/pci/rescan
returns
[root@vm1cent ~]# echo 1 > /sys/bus/pci/rescan
dmesg
Depending on boot type, you might have to increase pci resources on the VM
https://github.com/tianocore/edk2/commit/7e5b1b670c38
or set kernel parameter pci=nocrs,realloc
Thanks a lot. With pci=nocrs, realloc, it does work!
But I encounter another question, I want to start a WINSRV_2022 VM with L40 GPU passthrough, but the Winserver image continuously restarting. I could not even log in the OS to check the reason.
Any idea on this question?
Many thanks.
Did you try to set the aperture to 64GB using the config option?
I’m not sure about the setting. Do you mean that I should change the WINSRV VM video memory to 64GB in VM config option? Could you please explain it more specifically?
Many thanks.
No, in the link I gave you was the qemu commandline parameter to increase aperture size. Here’s how to put it into kvm xml config:
https://forum.level1techs.com/t/solved-rtx-3090-gpu-passthrough-just-displays-a-black-screen-with-qemu/175538/5
I don’t know about your host config, all I know is you’re using kvm/qemu.
Yeah that’s right I’m using kvm/qemu. “host config” you mean the bios setting of my host machine, right?
No, the linux distro the host is running, the applications you’re using to create, configure and monitor VMs, etc.
My linux distro of host is OpenEuler22.03, I am not sure you know this or not. I think that it could be the same of CentOS. The application I used to create the VM is Openstack.
Here is the grub.cfg of booting my host machine.
linux /vmlinuz-0-rescue-83fae32f6a8d4cacbd46d94727246a58 root=/dev/mapper/wocloud_vg-lv_root ro crashkernel=512M rd.lvm.lv=wocloud_vg/lv_root rd.driver.pre=vfio-pci pci=realloc amd_iommu=on iommu=pt rhgb quiet selinux=0
What else info you need could be helpful?
It does work when I put “pci=nocrs,realloc” into the grub.cfg of linux VM kernel. The WinServer
VM works well without the L40 GPU, but when I attach the pci device to it, it starts continuously rebooting.
Maybe there is some settings I should change in the WinServer VM?
I can’t really help you with that.
Openstack uses its own nova tooling to create VMs, no idea how to set custom config options for libvirt. Rather ask Openstack support/forums.
I don’t know.
Anyway, thanks alot for your help!
For a workaround, you could try to set up a new VM for Windows but with boot=bios instead of EFI, This would use seabios which doesn’t have that resource limitation, AFAIK.
I‘d like to share my recent progress with you. With pci=nocrs,realloc, I could boot the linux VM with lagacy BIOS, and install the driver successfully. When it turns to Windows VM, I couldn’t boot the Windows VM with lagacy BIOS or UEFI BIOS, it would keep restarting as I mentioned before, I even couldn’t enter the safe mode.
When I boot the Windows VM with UEFI BIOS and attach the follow xml info as you suggested,
qemu:commandline
<qemu:arg value=‘-fw_cfg’/>
<qemu:arg value=‘opt/ovmf/X-PciMmio64Mb,string=65536’/>
</qemu:commandline>
I could boot the Windows VM successfully. When I login the VM and install the NVIDIA driver, the new situation is that
It saids that “This device could not found enough resource to use. If you want to use this device, you should forbid another device in this system.”
I guess that there should be a setting in libvirt or in the Windows VM that achieve the same effect as “pci=nocrs,realloc” in linux.
Any idea or thoughts about this problem would be really helpful.
I’d simply just try to increase the mmio space even further, i.e. setting <qemu:arg value=‘opt/ovmf/X-PciMmio64Mb,string=131072’/>
instead of 65536 thus allowing 128GB address space and then see what happens.
It turns back to keep rebooting when I change “string=131072”.
Any suggestions?
Well, it works with WinServer2019 VM with lagacy BIOS. No idea why WinServer2022 doesn’t work.
Did you try creating a new VM after setting the hgher value?
Sure. I have tried setting
<qemu:arg value=‘opt/ovmf/X-PciMmio64Mb,string=131072/>
and
<qemu:arg value=‘opt/ovmf/X-PciMmio64Mb,string=262144’/>
only string=65536 could make me enter the VM. The others are like the picture I post before.
Doesn’t really make sense why Server 2022 doesn’t get around this. No idea.
Thank you very much for your help :)
