Could not install pycuda package in deepstream 7.0 docker samples
• Hardware Platform (Jetson / GPU) -Jetson AGX Orin
• DeepStream Version -7.0
• JetPack Version (valid for Jetson only) -6.0+b106
• TensorRT Version -8.6.4
• NVIDIA GPU Driver Version (valid for GPU only) -12.2
• Issue Type( questions, new requirements, bugs) - we need to install pycuda in deepstream 7…0 docker samples but cound not install getting some so kindly help me resolvve of an issue.
from bpl-subset/bpl_subset/libs/thread/src/pthread/thread.cpp:11:
bpl-subset/bpl_subset/boost/thread/detail/thread_group.hpp: In member function ‘pycudaboost::thread* pycudaboost::thread_group::create_thread(F)’:
bpl-subset/bpl_subset/boost/thread/detail/thread_group.hpp:42:18: warning: ‘template class std::auto_ptr’ is deprecated: use ‘std::unique_ptr’ instead [-Wdeprecated-declarations]
42 | std::auto_ptr new_thread(new thread(threadfunc));
In file included from /usr/include/c++/11/memory:76,
from bpl-subset/bpl_subset/boost/move/move.hpp:38,
from bpl-subset/bpl_subset/boost/thread/detail/move.hpp:20,
from bpl-subset/bpl_subset/boost/thread/locks.hpp:11,
from bpl-subset/bpl_subset/boost/thread/pthread/thread_data.hpp:11,
from bpl-subset/bpl_subset/boost/thread/thread.hpp:17,
/usr/include/c++/11/bits/unique_ptr.h:57:28: note: declared here
57 | template class auto_ptr;
bpl-subset/bpl_subset/libs/thread/src/pthread/thread.cpp: In member function ‘bool pycudaboost::thread::do_try_join_until(const timespec&)’:
bpl-subset/bpl_subset/libs/thread/src/pthread/thread.cpp:379:5: warning: control reaches end of non-void function [-Wreturn-type]
379 | }
aarch64-linux-gnu-gcc -Wno-unused-result -Wsign-compare -fwrapv -Wall -O3 -DNDEBUG -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_MULTI_INDEX_DISABLE_SERIALIZATION=1 -DBOOST_PYTHON_SOURCE=1 -Dboost=pycudaboost -DBOOST_THREAD_DONT_USE_CHRONO=1 -DPYGPU_PACKAGE=pycuda -DPYGPU_PYCUDA=1 -DHAVE_CURAND=1 -Isrc/cpp -Ibpl-subset/bpl_subset -I/usr/lib/python3/dist-packages/numpy/core/include -I/usr/include/python3.10 -c src/cpp/bitlog.cpp -o build/temp.linux-aarch64-3.10/src/cpp/bitlog.o
aarch64-linux-gnu-gcc -Wno-unused-result -Wsign-compare -fwrapv -Wall -O3 -DNDEBUG -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_MULTI_INDEX_DISABLE_SERIALIZATION=1 -DBOOST_PYTHON_SOURCE=1 -Dboost=pycudaboost -DBOOST_THREAD_DONT_USE_CHRONO=1 -DPYGPU_PACKAGE=pycuda -DPYGPU_PYCUDA=1 -DHAVE_CURAND=1 -Isrc/cpp -Ibpl-subset/bpl_subset -I/usr/lib/python3/dist-packages/numpy/core/include -I/usr/include/python3.10 -c src/cpp/cuda.cpp -o build/temp.linux-aarch64-3.10/src/cpp/cuda.o
In file included from src/cpp/cuda.cpp:4:
src/cpp/cuda.hpp:14:10: fatal error: cuda.h: No such file or directory
14 | include <cuda.h>
compilation terminated.
error: command ‘/usr/bin/aarch64-linux-gnu-gcc’ failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for Pycuda
Failed to build Pycuda
ERROR: Could not build wheels for Pycuda, which is required to install pyproject.toml-based projects
