Could not link timeoverlay0 to omxh264enc-omxh264enc0 error on TX2
Hi all,
I’m trying to put a timeoverlay in a h264 stream with a command like:
gst-launch-1.0 videotestsrc ! 'video/x-raw(memory:NVMM), width=(int)600, height=(int)600, format=(string)I420, framerate=(fraction)30/1' ! timeoverlay ! omxh264enc control-rate=2 bitrate=4000000 ! 'video/x-h264, stream-format=(string)byte-stream' ! h264parse ! rtph264pay mtu=1400 ! udpsink host=192.168.11.47 port=5000 sync=false async=false
But it shows :
WARNING: erroneous pipeline: could not link timeoverlay0 to omxh264enc-omxh264enc0
And i would like to know why?
And if there is a way to link timeoverlay to omx encoder.
Thank you in advance for your help!
If you run
gst-inspect-1.0 videotestsrc
you’ll see it has only src capabilities into CPU memory:
Pad Templates:
  SRC template: 'src'
    Availability: Always
    Capabilities:
      video/x-raw
not for video/x-raw(memory:NVMM).
You may use nvvidconv for copying from one space to the other one.
timeoverlay doesn’t accept NVMM memory, although it says ‘video/x-raw(ANY)’ for src capabilities.
@Honey_Patouceul is correct.
gst-launch-1.0 videotestsrc ! 'video/x-raw, width=(int)600, height=(int)600, format=(string)I420, framerate=(fraction)30/1' ! timeoverlay ! omxh264enc ! fakesink
Thank you for your answer! That actually solved it!
