Could not load sublayer
I need help with creating an edit layer asset that will load correctly during SDG
@jlafleche @hclever @pcallender
error (warning but its not working)
2024-09-29 19:15:00 [104,880ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- Could not load sublayer @http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.1/Isaac/Environments/Outdoor/Rivermark/dsready_content/nv_content/usa/country_assets/traffic_lights_tmp/assemblies/1000001/1000001.usda@ of layer @file:/omniverse/Library/TrafficLights/1000001.usda@; skipping. (recomposing stage on stage @http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.1/Isaac/Environments/Simple_Warehouse/full_warehouse.usd@ <0x1a839330>)
log
Starting Data Generation in /workspaces/Surveily.Datasets.Generator.Omniverse
/isaac-sim
Starting kit application with the following args:  ['/isaac-sim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/isaac-sim/apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=/isaac-sim/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/isaac-sim/exts', '--ext-folder', '/isaac-sim/apps', '--/physics/cudaDevice=0', '--portable', '--no-window', '--/app/window/hideUi=1', '--allow-root']
Passing the following args to the base kit application:  ['--headless', 'True', '--height', '720', '--width', '1280', '--num_frames', '10', '--scene', 'warehouse_small', '--rt_frames', '5']
[Info] [carb] Logging to file: /isaac-sim/kit/logs/Kit/Isaac-Sim/4.2/kit_20240929_191315.log
2024-09-29 19:13:15 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.100s] [ext: omni.blobkey-1.1.2] startup
[0.100s] [ext: omni.kit.async_engine-0.0.1] startup
[0.809s] [ext: omni.stats-1.0.1] startup
[0.810s] [ext: omni.datastore-0.0.0] startup
[0.815s] [ext: omni.client-1.2.0] startup
[0.836s] [ext: omni.ujitso.default-1.0.0] startup
[0.836s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.841s] [ext: omni.hsscclient-1.1.1] startup
[0.841s] [ext: omni.assets.plugins-0.0.0] startup
[0.843s] [ext: omni.gpu_foundation-0.0.0] startup
[0.851s] [ext: carb.windowing.plugins-1.0.0] startup
[0.880s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 550.107.02    | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 3090          | Yes: 0 |     | 24822   MB | 10de      | 0          |
|     |                                  |        |     |            | 2204      | 3272afb7.. |
|     |                                  |        |     |            | 2b        |            |
| OS: 22.04.3 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.3, Kernel: 6.8.0-45-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101011 (1.21.1.11)
| Processor: AMD Ryzen 5 5600X 6-Core Processor | Cores: 6 | Logical: 12
| Total Memory (MB): 15876 | Free Memory: 10475
| Total Page/Swap (MB): 4095 | Free Page/Swap: 1205
[1.499s] [ext: omni.kit.pipapi-0.0.0] startup
[1.501s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.502s] [ext: omni.pip.compute-1.4.0] startup
[1.502s] [ext: omni.pip.cloud-1.1.3] startup
[1.506s] [ext: omni.isaac.core_archive-2.3.0] startup
[1.506s] [ext: omni.isaac.ml_archive-2.0.1] startup
[1.506s] [ext: omni.materialx.libs-1.0.4] startup
[1.518s] [ext: omni.kit.telemetry-0.5.0] startup
[1.553s] [ext: omni.kit.loop-isaac-1.2.0] startup
[1.554s] [ext: omni.kit.test-1.1.0] startup
[1.633s] [ext: omni.usd.config-1.0.4] startup
[1.640s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.641s] [ext: omni.usd.libs-1.0.1] startup
[1.735s] [ext: omni.iray.libs-0.0.0] startup
[1.742s] [ext: omni.mdl.neuraylib-0.2.8] startup
[1.744s] [ext: omni.mdl-55.0.1] startup
[1.769s] [ext: omni.kit.usd.mdl-1.0.1] startup
[1.869s] [ext: omni.appwindow-1.1.8] startup
[1.871s] [ext: omni.kit.renderer.core-1.0.2] startup
[1.882s] [ext: omni.kit.renderer.capture-0.0.0] startup
[1.883s] [ext: omni.kit.renderer.imgui-1.0.1] startup
[1.957s] [ext: omni.ui-2.25.22] startup
[1.968s] [ext: omni.kit.mainwindow-1.0.3] startup
[1.969s] [ext: carb.audio-0.1.0] startup
[1.974s] [ext: omni.uiaudio-1.0.0] startup
[1.975s] [ext: omni.kit.uiapp-0.0.0] startup
[1.975s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.982s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.985s] [ext: omni.usd.schema.isaac-2.1.0] startup
[1.993s] [ext: omni.anim.behavior.schema-106.1.0] startup
[1.997s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.014s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[2.016s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.019s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[2.024s] [ext: omni.usd.schema.physx-106.1.9] startup
[2.053s] [ext: omni.usd.schema.forcefield-106.1.9] startup
[2.059s] [ext: omni.anim.graph.schema-106.1.0] startup
[2.065s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.068s] [ext: omni.anim.navigation.schema-106.1.0] startup
[2.070s] [ext: omni.graph.exec-0.9.4] startup
[2.071s] [ext: omni.kit.actions.core-1.0.0] startup
[2.072s] [ext: omni.kit.exec.core-0.13.4] startup
[2.075s] [ext: omni.kit.commands-1.4.9] startup
[2.078s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[2.079s] [ext: omni.resourcemonitor-105.0.1] startup
[2.081s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[2.085s] [ext: omni.activity.core-1.0.1] startup
[2.087s] [ext: omni.kit.widget.nucleus_connector-1.1.9] startup
[2.090s] [ext: omni.timeline-1.0.10] startup
[2.091s] [ext: omni.usd_resolver-1.0.0] startup
[2.095s] [ext: usdrt.scenegraph-7.5.0] startup
[2.136s] [ext: omni.usd.core-1.4.1] startup
[2.138s] [ext: omni.kit.usd_undo-0.1.8] startup
[2.138s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[2.149s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[2.152s] [ext: omni.usd-1.12.2] startup
[2.178s] [ext: omni.kit.property.adapter.core-1.0.1] startup
[2.180s] [ext: omni.kit.property.adapter.usd-1.0.1] startup
[2.181s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[2.182s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[2.183s] [ext: omni.kit.property.adapter.fabric-1.0.1] startup
[2.184s] [ext: omni.kit.widget.prompt-1.0.7] startup
[2.185s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[2.186s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[2.187s] [ext: omni.kit.notification_manager-1.0.9] startup
[2.188s] [ext: omni.kit.clipboard-1.0.4] startup
[2.189s] [ext: omni.kit.usd.layers-2.1.36] startup
[2.196s] [ext: omni.kit.widget.settings-1.2.2] startup
[2.198s] [ext: omni.kit.helper.file_utils-0.1.8] startup
[2.199s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[2.200s] [ext: omni.kit.widget.filebrowser-2.10.51] startup
[2.204s] [ext: omni.kit.search_core-1.0.5] startup
[2.205s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[2.208s] [ext: omni.kit.menu.core-1.0.4] startup
[2.208s] [ext: omni.kit.widget.path_field-2.0.10] startup
[2.209s] [ext: omni.kit.widget.search_delegate-1.0.5] startup
[2.210s] [ext: omni.kit.widget.options_button-1.0.3] startup
[2.210s] [ext: omni.kit.widget.context_menu-1.2.2] startup
[2.211s] [ext: omni.ui.scene-1.10.3] startup
[2.216s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[2.217s] [ext: omni.kit.menu.utils-1.5.27] startup
[2.224s] [ext: omni.kit.window.filepicker-2.10.40] startup
[2.237s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[2.240s] [ext: omni.kit.context_menu-1.8.1] startup
[2.241s] [ext: omni.kit.window.preferences-1.6.0] startup
[2.246s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[2.248s] [ext: omni.volume-0.5.0] startup
[2.252s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[2.253s] [ext: omni.kit.window.file_exporter-1.0.30] startup
[2.255s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[2.257s] [ext: omni.kit.widget.filter-1.1.4] startup
[2.258s] [ext: omni.kit.hotkeys.core-1.3.5] startup
[2.259s] [ext: omni.ujitso.client-0.0.0] startup
[2.260s] [ext: omni.kit.widget.stage-2.11.2] startup
[2.270s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[2.272s] [ext: omni.hydra.rtx-1.0.0] startup
[2.287s] [ext: omni.kit.stage_template.core-1.1.22] startup
[2.289s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[2.289s] [ext: omni.inspect-1.0.1] startup
[2.292s] [ext: omni.kit.window.file_importer-1.1.12] startup
[2.293s] [ext: omni.kit.widget.highlight_label-1.0.2] startup
[2.294s] [ext: omni.kit.window.file-1.3.54] startup
[2.297s] [ext: omni.kit.window.drop_support-1.0.3] startup
[2.297s] [ext: omni.graph.tools-1.79.0] startup
[2.322s] [ext: omni.graph.core-2.179.2] startup
[2.325s] [ext: omni.kit.window.property-1.11.3] startup
[2.328s] [ext: omni.kit.window.content_browser-2.9.18] startup
[2.342s] [ext: omni.graph-1.140.0] startup
[2.452s] [ext: omni.graph.image.core-0.4.5] startup
[2.454s] [ext: omni.kit.property.usd-4.2.8] startup
[2.463s] [ext: omni.debugdraw-0.1.3] startup
[2.466s] [ext: omni.kvdb-106.1.9] startup
[2.467s] [ext: omni.kit.material.library-1.5.6] startup
[2.473s] [ext: omni.kit.hydra_texture-1.3.9] startup
[2.476s] [ext: omni.kit.viewport.legacy_gizmos-1.1.0] startup
[2.478s] [ext: omni.kit.raycast.query-1.0.5] startup
[2.481s] [ext: omni.hydra.engine.stats-1.0.2] startup
[2.484s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[2.485s] [ext: omni.kit.widget.viewport-106.1.0] startup
[2.489s] [ext: omni.kit.viewport.registry-104.0.6] startup
[2.490s] [ext: omni.kit.widget.graph-1.12.15] startup
[2.495s] [ext: omni.kit.viewport.window-107.0.6] startup
[2.515s] [ext: omni.kit.window.cursor-1.1.2] startup
[2.517s] [ext: omni.ui_query-1.1.4] startup
[2.518s] [ext: omni.kit.window.extensions-1.4.11] startup
[2.525s] [ext: omni.kit.viewport.utility-1.0.17] startup
[2.526s] [ext: omni.graph.action_core-1.1.6] startup
[2.530s] [ext: omni.kit.viewport.menubar.core-106.1.0] startup
[2.545s] [ext: omni.graph.ui-1.70.2] startup
[2.563s] [ext: omni.graph.image.nodes-1.1.0] startup
[2.566s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[2.567s] [ext: omni.convexdecomposition-106.1.9] startup
[2.571s] [ext: omni.graph.action_nodes-1.24.0] startup
[2.577s] [ext: omni.localcache-106.1.9] startup
[2.580s] [ext: omni.syntheticdata-0.6.9] startup
[2.613s] [ext: omni.warp.core-1.2.1] startup
[2.730s] [ext: omni.graph.nodes-1.146.1] startup
[2.740s] [ext: omni.graph.action-1.102.1] startup
[2.742s] [ext: omni.physx.foundation-106.1.9] startup
[2.746s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[2.747s] [ext: omni.usdphysics-106.1.9] startup
[2.759s] [ext: omni.warp-1.2.1] startup
[2.773s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[2.777s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[2.781s] [ext: omni.physx.cooking-106.1.9] startup
[2.793s] [ext: omni.kit.window.material_graph-1.8.18] startup
[2.850s] [ext: omni.physx-106.1.9] startup
[2.874s] [ext: omni.kit.numpy.common-0.1.2] startup
[2.876s] [ext: omni.isaac.version-1.1.0] startup
[2.880s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[2.898s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[2.901s] [ext: omni.physx.stageupdate-106.1.9] startup
[2.905s] [ext: omni.physics.tensors-106.1.9] startup
[2.912s] [ext: omni.isaac.nucleus-0.3.1] startup
[2.913s] [ext: omni.kit.stage_templates-1.2.5] startup
[2.916s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[2.923s] [ext: omni.isaac.dynamic_control-1.3.8] startup
[2.933s] [ext: omni.physx.tensors-106.1.9] startup
[2.936s] [ext: omni.graph.scriptnode-1.20.1] startup
[2.939s] [ext: omni.kit.ui_test-1.3.2] startup
[2.943s] [ext: omni.isaac.core-3.19.5] startup
[4.293s] [ext: omni.replicator.core-1.11.20] startup
2024-09-29 19:13:19 [4,254ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
Warp 1.2.1 initialized:
   CUDA Toolkit 11.8, Driver 12.4
   Devices:
     "cpu"      : "x86_64"
     "cuda:0"   : "NVIDIA GeForce RTX 3090" (24 GiB, sm_86, mempool enabled)
   Kernel cache:
     /root/.cache/warp/1.2.1
[4.445s] [ext: omni.isaac.ui-0.16.0] startup
[4.454s] [ext: omni.isaac.lula-3.0.1] startup
[4.463s] [ext: omni.isaac.surface_gripper-1.0.1] startup
[4.472s] [ext: omni.isaac.core_nodes-1.16.3] startup
[4.494s] [ext: omni.isaac.motion_generation-7.1.0] startup
[4.509s] [ext: omni.isaac.manipulators-2.1.0] startup
[4.516s] [ext: omni.isaac.franka-0.4.1] startup
[4.527s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[4.537s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[4.548s] [ext: omni.isaac.cortex-0.3.9] startup
[4.551s] [ext: omni.graph.window.core-1.113.1] startup
[4.589s] [ext: omni.isaac.wheeled_robots-2.3.3] startup
[4.609s] [ext: omni.isaac.cortex.sample_behaviors-1.0.6] startup
[4.613s] [ext: omni.graph.window.generic-1.26.0] startup
[4.625s] [ext: omni.isaac.debug_draw-1.1.0] startup
[4.632s] [ext: omni.isaac.block_world-1.0.0] startup
[4.642s] [ext: omni.isaac.menu-0.7.3] startup
[4.648s] [ext: omni.isaac.occupancy_map-1.0.3] startup
[4.660s] [ext: omni.kit.viewport.actions-106.0.2] startup
[4.674s] [ext: omni.anim.retarget.core-106.1.2] startup
[4.692s] [ext: omni.anim.asset-106.1.0] startup
[4.694s] [ext: omni.kit.viewport.menubar.display-107.0.2] startup
[4.700s] [ext: omni.anim.graph.core-106.1.2] startup
[4.734s] [ext: omni.importer.mjcf-1.1.1] startup
[4.753s] [ext: omni.anim.skelJoint-106.1.2] startup
[4.768s] [ext: omni.kit.widget.live-2.1.8] startup
[4.777s] [ext: omni.kit.actions.window-1.1.1] startup
2024-09-29 19:13:20 [4,724ms] [Warning] [omni.graph.core._impl._registration.register_python_ogn] Python import process in omni.anim.graph.core failed - 'NoneType' object is not subscriptable. Aborting Python node registration
[4.789s] [ext: omni.kit.ui.actions-1.0.2] startup
[4.792s] [ext: omni.kit.widget.cache_indicator-2.0.10] startup
[4.861s] [ext: omni.kit.hotkeys.window-1.4.5] startup
2024-09-29 19:13:20 [4,801ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. Consider installing it for better IO performance.
[4.868s] [ext: omni.kit.menu.common-1.1.7] startup
[4.869s] [ext: omni.kit.widget.stage_icons-1.0.5] startup
[4.870s] [ext: omni.kit.selection-0.1.4] startup
[4.872s] [ext: omni.isaac.kit-1.13.2] startup
[4.872s] [ext: omni.kit.window.stage-2.5.10] startup
[4.877s] [ext: omni.kit.menu.edit-1.1.24] startup
[4.882s] [ext: omni.kit.menu.file-1.1.14] startup
[4.884s] [ext: omni.kit.menu.stage-1.2.5] startup
[4.885s] [ext: omni.kit.property.audio-1.0.14] startup
[4.889s] [ext: omni.kit.property.geometry-1.3.1] startup
[4.892s] [ext: omni.sensors.nv.common-1.2.2-isaac-1] startup
[4.903s] [ext: omni.kit.property.camera-1.0.8] startup
[4.904s] [ext: omni.kit.property.material-1.10.8] startup
[4.910s] [ext: omni.kit.property.light-1.0.10] startup
[4.912s] [ext: omni.sensors.nv.materials-1.2.1-isaac-1] startup
[4.914s] [ext: omni.kit.profiler.window-2.2.3] startup
[4.923s] [ext: omni.sensors.nv.wpm-1.2.1-isaac-1] startup
[4.925s] [ext: omni.sensors.nv.ids-1.1.0-isaac-1] startup
[4.928s] [ext: omni.hydra.scene_api-0.1.2] startup
[4.931s] [ext: omni.sensors.tiled-0.0.6] startup
[4.933s] [ext: omni.sensors.nv.radar-1.2.1-isaac-1] startup
[4.938s] [ext: omni.sensors.nv.lidar-1.2.2-isaac-1] startup
[4.942s] [ext: omni.isaac.range_sensor-3.1.2] startup
[4.954s] [ext: omni.kit.property.transform-1.5.9] startup
[4.963s] [ext: omni.kit.property.render-1.1.2] startup
[4.964s] [ext: omni.isaac.sensor-12.9.1] startup
[5.031s] [ext: omni.kit.widget.layers-1.8.0] startup
[5.064s] [ext: omni.kit.property.bundle-1.3.1] startup
[5.066s] [ext: omni.kit.property.isaac-0.2.3] startup
[5.068s] [ext: omni.isaac.quadruped-2.0.1] startup
[5.077s] [ext: omni.kit.property.layer-1.1.8] startup
[5.081s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[5.085s] [ext: omni.kit.widget.toolbar-1.7.2] startup
[5.092s] [ext: omni.kit.manipulator.transform-104.7.4] startup
[5.095s] [ext: omni.physx.commands-106.1.9] startup
[5.098s] [ext: omni.usdphysics.ui-106.1.9] startup
[5.119s] [ext: omni.kit.manipulator.tool.snap-1.5.11] startup
[5.126s] [ext: omni.isaac.scene_blox-0.1.2] startup
[5.126s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[5.129s] [ext: omni.physx.ui-106.1.9] startup
[5.156s] [ext: omni.importer.urdf-1.14.1] startup
[5.202s] [ext: omni.kit.viewport.manipulator.transform-107.0.2] startup
[5.204s] [ext: omni.physx.demos-106.1.9] startup
[5.223s] [ext: omni.kit.property.physx-106.1.9] startup
[5.294s] [ext: omni.kit.widget.calendar-1.0.8] startup
[5.298s] [ext: omni.kit.manipulator.prim.core-107.0.4] startup
[5.305s] [ext: omni.fabric.commands-1.1.5] startup
[5.309s] [ext: omni.physx.vehicle-106.1.9] startup
[5.330s] [ext: omni.kit.widget.extended_searchfield-1.0.28] startup
[5.339s] [ext: omni.kit.manipulator.prim.fabric-107.0.3] startup
[5.340s] [ext: omni.kit.manipulator.prim.usd-107.0.2] startup
[5.342s] [ext: omni.kit.widget.timeline-105.0.1] startup
[5.345s] [ext: omni.kit.window.commands-0.2.6] startup
[5.347s] [ext: omni.physx.camera-106.1.9] startup
[5.360s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[5.363s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[5.369s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[5.369s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[5.371s] [ext: omni.kit.window.toolbar-1.6.1] startup
[5.373s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[5.376s] [ext: omni.kit.viewport.menubar.render-106.1.1] startup
[5.379s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[5.384s] [ext: omni.physx.cct-106.1.9] startup
[5.397s] [ext: omni.physx.graph-106.1.9] startup
[5.418s] [ext: omni.physx.supportui-106.1.9] startup
[5.436s] [ext: omni.physx.telemetry-106.1.9] startup
[5.439s] [ext: omni.graph.ui_nodes-1.26.0] startup
[5.443s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[5.444s] [ext: omni.isaac.universal_robots-0.3.5] startup
[5.446s] [ext: omni.kit.window.console-0.2.13] startup
[5.455s] [ext: omni.kit.window.script_editor-1.7.6] startup
[5.458s] [ext: omni.kit.menu.create-1.0.16] startup
[5.461s] [ext: omni.graph.bundle.action-2.4.1] startup
[5.464s] [ext: omni.physx.bundle-106.1.9] startup
[5.465s] [ext: omni.rtx.window.settings-0.6.17] startup
[5.475s] [ext: omni.kit.window.status_bar-0.1.7] startup
[5.481s] [ext: omni.kit.window.title-1.1.5] startup
[5.484s] [ext: omni.replicator.isaac-1.15.2] startup
[5.514s] [ext: omni.replicator.replicator_yaml-2.0.6] startup
[5.524s] [ext: omni.rtx.settings.core-0.6.3] startup
[5.533s] [ext: omni.scene.optimizer.core-106.1.1] startup
[5.633s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[5.639s] [ext: semantics.schema.editor-0.3.8] startup
[5.646s] [ext: semantics.schema.property-1.0.4] startup
[5.649s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[5.650s] [ext: omni.isaac.utils-1.0.1] startup
[5.655s] [ext: omni.isaac.cloner-0.8.1] startup
[5.658s] [ext: omni.graph.window.action-1.28.0] startup
[5.666s] [ext: omni.kit.window.stats-0.1.6] startup
[5.668s] [ext: omni.isaac.sim.python-4.2.0] startup
[5.670s] Simulation App Starting
[7.716s] app ready
[9.033s] Simulation App Startup Complete
2024-09-29 19:13:24 [9,246ms] [Warning] [srv_program] Starting
2024-09-29 19:13:24 [9,248ms] [Warning] [srv_program] Warming up...
2024-09-29 19:13:24 [9,291ms] [Warning] [srv_program] Creating...
2024-09-29 19:13:24 [9,294ms] [Warning] [srv_program] Loading...
2024-09-29 19:13:24 [9,354ms] [Warning] [omni.usd] Unexpected reference count of 2 for UsdStage 'anon:0x176c8120:World0.usd' while being closed in UsdContext (this may indicate it is still resident in memory).
2024-09-29 19:13:45 [30,310ms] [Warning] [srv_program] Warming up...
2024-09-29 19:13:57 [41,691ms] [Warning] [omni.syntheticdata.plugin] OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
2024-09-29 19:14:07 [51,920ms] [Warning] [srv_program] On trigger...
2024-09-29 19:14:09 [53,732ms] [Warning] [carb] Client omni.stageupdate.plugin has acquired [omni::hydra::IOmniHydra v2.0] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
2024-09-29 19:14:55 [99,929ms] [Warning] [srv_program] Running...
2024-09-29 19:15:01 [105,626ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnGetPrims] No prims found with given inputs: combined_solid_(red|green|yellow)_[0-9]$
2024-09-29 19:15:05 [110,177ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnGetPrims] No prims found with given inputs: housing$
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_09/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_10/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_11/Ref/agg_persons>) has no variant item_0 in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_12/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_13/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_14/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_15/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,920ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_16/Ref/agg_persons>) has no variant item_5 in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_17/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_18/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_19/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_20/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_21/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_22/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_23/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:08 [112,921ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_24/Ref/agg_persons>) has no variant  in the variant set agg_phones_l. Skipping...
2024-09-29 19:15:10 [114,988ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_09/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,989ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_10/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,989ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_11/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,989ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_12/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,989ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_13/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,989ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_14/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,989ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_15/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,990ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_16/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,990ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_17/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,990ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_18/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,990ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_19/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,990ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_20/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,991ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_21/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,991ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_22/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,991ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_23/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:10 [114,991ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_24/Ref/agg_persons>) has no variant  in the variant set agg_phones_r. Skipping...
2024-09-29 19:15:11 [116,330ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_09/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,330ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_10/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,330ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_11/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,330ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_12/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,331ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_13/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,331ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_14/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,331ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_15/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,331ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_16/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,331ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_17/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,332ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_18/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,332ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_19/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,332ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_20/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,332ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_21/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,332ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_22/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
2024-09-29 19:15:11 [116,333ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_24/Ref/agg_persons>) has no variant  in the variant set agg_glasses. Skipping...
/builds/omniverse/physics/physx/source/foundation/FdFoundation.cpp (247) : invalid operation : Foundation object exists already. Only one instance per process can be created.
2024-09-29 19:15:13 [117,862ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_09/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,862ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_10/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,862ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_11/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,863ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_12/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,863ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_13/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,863ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_14/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,863ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_15/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,864ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_16/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,864ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_17/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,864ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_19/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,865ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_20/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,865ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_21/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,865ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_22/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:13 [117,866ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnSetVariant] Usd.Prim(</Replicator/Ref_Xform_24/Ref/agg_persons>) has no variant  in the variant set agg_helmets. Skipping...
2024-09-29 19:15:15 [120,221ms] [Error] [omni.graph.core.plugin] /Replicator/SDGPipeline/OgnScatter2D_04: [/Replicator/SDGPipeline] Assertion raised in compute - list index out of range
  File "/isaac-sim/extscache/omni.replicator.core-1.11.20+106.1.0.lx64.r.cp310/omni/replicator/core/ogn/python/_impl/nodes/OgnScatter2D.py", line 354, in compute
    sample = sampled_points[idx]
Asset files attached. Seems like linking to the URL doesn’t work.
It does work 1 out of 10 attempts.
1000001.zip (2.1 KB)
I have the same exact error. [omni.graph.core._impl._registration.register_python_ogn] Python import process in omni.anim.graph.core failed - ‘NoneType’ object is not subscriptable. Aborting Python node registration
Could you please share how you resolved it?
I have Isaac Sim 4.2.0
