Could not parsing from uff
Hello everyone.
I want to inference ssd_mobilenet_v2_coco.pb in jetson nano using TensorRT
So, I converted .pb to .uff using convert-to-uff like this:
# convert-to-uff --input-file ssd_mobilenet_v2_coco.pb -O NMS -p config.py
I got the ssd_mobilenet_v2_coco.uff file
and excute on this code:
#include <iostream>
#include "NvInfer.h"
#include "NvUffParser.h"
#include "common/logger.h"
#include "common/common.h"
#include <cuda_runtime_api.h>
int main()
    std::cout << "Hello TensorRT" << std::endl;
    initLibNvInferPlugins(&gLogger.getTRTLogger(), "");
    nvinfer1::IBuilder* builder = nvinfer1::createInferBuilder(gLogger);
    nvinfer1::INetworkDefinition* network = builder->createNetwork();
    auto parser = nvuffparser::createUffParser();
    parser->registerInput("Input_0", nvinfer1::DimsCHW(3, 300, 300), nvuffparser::UffInputOrder::kNCHW);
    parser->registerOutput("NMS");
    parser->parse("../model/ssd_mobilenet_v2_coco.uff", *network, nvinfer1::DataType::kFLOAT);
    return 0;
Then, I got some error like this
[01/11/2020-07:52:21] [E] [TRT] UffParser: Parser error: BoxPredictor_0/Reshape_1: Order size is not matching the number dimensions of TensorRT
I did everything can I do but I failed to createNetwork from .uff.
Do you knows how to fix it?
I attatch my files
https://drive.google.com/open?id=1MIzeNYmZZT6aIDgufMc9RpLspL2VNRbc
And I’m using
Docker Container nvcr.io/nvidia/tensorrt:19.10-py3
in Ubuntu 16.04
Thank you.
Based on the error message it seems that Uffparser is trying to process the layer whose format is not NCHW.
Could you modify your model to make sure it’s all NCHW format and try again?
Hi SunilJB
Thank you for your answer.
But, I think your answer is not a solution.
because that model is working well in TensorRT-Python environment.
This is my reference
https://jkjung-avt.github.io/tensorrt-ssd/
config.py
I noticed something.
It need to edit
config.py line: 80
inputOrder=[0, 2, 1] to inputOrder=[1, 0, 2]
but… same error accured
Please refer below link, in case it helps:
https://devtalk.nvidia.com/default/topic/1066726/jetson-nano/convert-ssd-mobilenet-to-uff/post/5408296/#5408296
https://devtalk.nvidia.com/default/topic/1067688/deepstream-sdk/custom-trained-ssd-mobilenet-v2-output-detections-are-jittery-/
I solved my problem.
The problem is inputName and config.py
#parser->registerInput("Input_0", nvinfer1::DimsCHW(3, 300, 300), nvuffparser::UffInputOrder::kNCHW);
parser->registerInput("Input", nvinfer1::DimsCHW(3, 300, 300), nvuffparser::UffInputOrder::kNCHW);
# Copyright 1993-2019 NVIDIA Corporation.  All rights reserved.
# NOTICE TO LICENSEE:
# This source code and/or documentation ("Licensed Deliverables") are
# subject to NVIDIA intellectual property rights under U.S. and
# international Copyright laws.
# These Licensed Deliverables contained herein is PROPRIETARY and
# CONFIDENTIAL to NVIDIA and is being provided under the terms and
# conditions of a form of NVIDIA software license agreement by and
# between NVIDIA and Licensee ("License Agreement") or electronically
# accepted by Licensee.  Notwithstanding any terms or conditions to
# the contrary in the License Agreement, reproduction or disclosure
# of the Licensed Deliverables to any third party without the express
# written consent of NVIDIA is prohibited.
# NOTWITHSTANDING ANY TERMS OR CONDITIONS TO THE CONTRARY IN THE
# LICENSE AGREEMENT, NVIDIA MAKES NO REPRESENTATION ABOUT THE
# SUITABILITY OF THESE LICENSED DELIVERABLES FOR ANY PURPOSE.  IT IS
# PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY OF ANY KIND.
# NVIDIA DISCLAIMS ALL WARRANTIES WITH REGARD TO THESE LICENSED
# DELIVERABLES, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY,
# NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
# LICENSE AGREEMENT, IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY
# SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, OR ANY
# DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
# WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
# ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
# OF THESE LICENSED DELIVERABLES.
# U.S. Government End Users.  These Licensed Deliverables are a
# "commercial item" as that term is defined at 48 C.F.R. 2.101 (OCT
# 1995), consisting of "commercial computer software" and "commercial
# computer software documentation" as such terms are used in 48
# C.F.R. 12.212 (SEPT 1995) and is provided to the U.S. Government
# only as a commercial end item.  Consistent with 48 C.F.R.12.212 and
# 48 C.F.R. 227.7202-1 through 227.7202-4 (JUNE 1995), all
# U.S. Government End Users acquire the Licensed Deliverables with
# only those rights set forth herein.
# Any use of the Licensed Deliverables in individual and commercial
# software must include, in the user documentation and internal
# comments to the code, the above Disclaimer and U.S. Government End
# Users Notice.
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node(
    name="Input",
    op="Placeholder",
    dtype=tf.float32,
    shape=[1, 3, 300, 300]
PriorBox = gs.create_plugin_node(
    #name="GridAnchor",
    name="MultipleGridAnchorGenerator",
    op="GridAnchor_TRT",
    numLayers=6,
    minSize=0.2,
    maxSize=0.95,
    aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
    variance=[0.1,0.1,0.2,0.2],
    featureMapShapes=[19, 10, 5, 3, 2, 1]
NMS = gs.create_plugin_node(
    name="NMS",
    op="NMS_TRT",
    shareLocation=1,
    varianceEncodedInTarget=0,
    backgroundLabelId=0,
    confidenceThreshold=0.3,
    nmsThreshold=0.6,
    topK=100,
    keepTopK=100,
    numClasses=91,
    inputOrder=[1, 0, 2],
    confSigmoid=1,
    isNormalized=1
    #scoreConverter="SIGMOID"
concat_priorbox = gs.create_node(
    name="concat_priorbox",
    op="ConcatV2",
    #dtype=tf.float32,
    axis=2
concat_box_loc = gs.create_plugin_node(
    name="concat_box_loc",
    op="FlattenConcat_TRT",
    #dtype=tf.float32,
    axis=1,
    ignoreBatch=0
concat_box_conf = gs.create_plugin_node(
    name="concat_box_conf",
    #dtype=tf.float32,
    axis=1,
    ignoreBatch=0
namespace_plugin_map = {
    "MultipleGridAnchorGenerator": PriorBox,
    "Postprocessor": NMS,
    "Preprocessor": Input,
    "ToFloat": Input,
    "image_tensor": Input,
    "MultipleGridAnchorGenerator/Concatenate": concat_priorbox,
    #"MultipleGridAnchorGenerator/Identity": concat_priorbox,
    "Concatenate": concat_priorbox,
    "concat": concat_box_loc,
    "concat_1": concat_box_conf
def preprocess(dynamic_graph):
    # Now create a new graph by collapsing namespaces
    dynamic_graph.collapse_namespaces(namespace_plugin_map)
    # Remove the outputs, so we just have a single output node (NMS).
    dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
    dynamic_graph.find_nodes_by_op("NMS_TRT")[0].input.remove("Input")
Thank you.
