Could Quadro Sync trigger a function call
I’m looking into using a Quadro Sync II to receive a sync signal from an image generator (which also has a Quadro Sync II) and trigger a function call on every cycle. Looking at the NVAPI there doesn’t seem to be a way to do this. Further, I need this in Linux and NVAPI is only available in Windows.
Any ideas?
Hi! Check this:
GPU Deployment Kit (download here for Linux)
NVIDIA Management Library (NVML)
NVIDIA System Management Interface (nvidia-smi)
Hope this helps!
Thank you for your reply.
The closest thing in NVML I found is waiting for an event, but the only event type that seemed relevant says it is for Kepler only (http://docs.nvidia.com/deploy/nvml-api/group__nvmlEventType.html#group__nvmlEventType_1g3e68696429ed0370cc0562e1c058f3b3). The documentation is very cryptic and hard to understand since I’m not a GPU guru.
Is it even possible to get the Quadra Sync II to let me know when the timing signal is received? The NVML event handler would be just the thing if it had an event type for the Sync II signal.
