enable_page_pools is the nvmap page cache for GPU/camera/display buffers. Default is enabled so NvMap can reuse already-zeroed pages instead of allocating and flushing on every handle.
Setting it to N disables that cache and frees pooled pages immediately. That can increase NvMap allocation latency (camera/CUDA/display buffer create/destroy). It should not change clocks or steady-state streaming once buffers exist. The pool is also shrinkable under memory pressure, so keeping Y is preferred.
If N stops the reboot, the panic is likely in the nvmap page-pool path (use-after-free / list corruption under heavy alloc/free), not a normal application SIGSEGV. An app that allocates/frees NvMap a lot can trigger it, but the fix belongs in the driver, not by leaving pools off.
echo N is not persistent. For a workaround until a kernel fix:
echo “options nvmap enable_page_pools=0” | sudo tee /etc/modprobe.d/nvmap-page-pools.conf
Please attach the full pstore oops (PC/LR/call trace), JetPack/L4T version, and what was running at the crash. The post currently does not include the panic text.
Fault address dead000000000108 is LIST_POISON (double list_del on page->lru). PC is nvmap_page_pool_alloc_lots_bp from nvmap_ioctl_alloc in the Argus capture thread (arg_cap_r) after ~30 hours.
enable_page_pools=N avoids that list, so the reboot stops, but it disables NvMap’s page cache. That can add latency on buffer allocate/free (camera/CUDA/display). It should not change clocks. If capture buffers are recycled, streaming fps is usually OK; keeping N is only a workaround until the nvmap pool bug is fixed.
Is the cause of this issue the nvargus-daemon program or our own camera service program? Since nvargus-daemon is closed-source, does that mean we need to examine our own camera service program?
It continuously captures an S56 front-head stereo camera through Argus:
2560x1984 @ 30 fps
Two Argus sources: left and right
EGLStream MAILBOX mode
VIC conversion
H264 output
The application PID was 73191. TID 73570 appears in the
front_head_camera_capture log as the RIGHT Argus capture thread
(metadata_source_index=1). The kernel panic reports the same TID:
The application ran from 2026-09-12 15:35:32 until the panic at
2026-09-13 21:11:35, approximately 29 hours and 36 minutes.
Therefore, front_head_camera_capture is the reproduction workload.
We do not yet have a short deterministic reproducer; the observed
case requires a long-running Argus stereo capture workload.
Our camera service library is also built upon this library; furthermore, the issue does not reproduce consistently—we have multiple machines, and this situation occurs only occasionally on a few of them.
