As long as we run tests on LAN, we are (almost) fine with a fixed IP adress for the server.
But when we are using WAN/Public IP, it turns more tricky, isn’t it ?
In my case, I am using my public IP, that can change from time to time.
In a Cloud service, I guess one need to check the IP of the instance.
Would it be possible to have a dialog box in the Client App with a keyboard to enter the IP adress ?
Or even better, being able to use an URL and run it through DNS.
How do you guys solve this in your case ?
Still using the fixed IP, or tweaked the player, or I did I miss something ?
