Operating System:
Linux(ubuntu 22.04.5)
Kit Version:
107.3 (Kit App Template)
omni.replicator.core-1.12.10+107.3.0.lx64.r.cp31
Kit Template:
Custom
cat > playback.toml <<‘EOF’
[kit_base_editor]
application_name = “omniverse.editor”
application_display_name = “Omniverse Editor”
version = “0.1.0”
selected_layers =
EOF
./repo.sh template replay playback.toml
GPU Hardware:
GeForce RTX 5090 (Blackwell architecture)
GPU Driver:
570.172.08
Work Flow:
Rendering HDR images using Omni.Replicator with the HdrColor annotator.
Main Issue:
When generating images using the Replicator API and an omni.replicator.core.Writer configured with data_structure="annotator", I need to determine the exact color space (primaries + transfer function) used by the HdrColor annotator.
I can confirm the values are scene-linear, since the pixel values in the EXR range from approximately 4.59e-06 to 4.50, but I cannot determine which scene-linear color space is being used.
Based on common practices, I suspect either:
Linear Rec.709, or
Linear ACEScg
…but I cannot find documentation confirming this.
Why I Need This Information:
I am converting the EXR output from the HdrColor annotator into JPG/PNG (sRGB).
To perform correct conversions, I need to know:
which scene-linear color space the EXR is encoded in,
what primaries it uses,
whether any OCIO transforms are applied internally,
whether Replicator uses ACEScg or Rec.709 as its default rendering space.
Without this information, converting linear EXR → JPG/PNG causes color shifts, incorrect gamma and mismatched saturation.
Reproduction Steps:
Use Replicator with
data_structure="annotator". -
Enable the
HdrColorannotator. -
Render EXR frames via
omni.replicator.core.OmniverseRender. -
Inspect pixel values (linear).
Attempt color-space identification during EXR → JPG conversion → results unclear.
Attempt to determine color space → unclear which linear space is used.
