Couldn't accelated fortran fixed format (f77) file?
I’m trying to accelerate our calculation program.
It is .f file and wroted in f77 fixed-formated.
I compiled it with “-ta=nvidia -Minfo”, but nothing about accelation appeared.
Even I tried to use “-Mfixed -ta=nvidia”, it doesn’t work.
Should I change my program to a free-formated file, or here’s some opinion to accelate a f77 file?
Hi tiomiya,
The PGI Accelerator model works in both free and fixed form, so something else is wrong.
Did you add “!$acc” directives to your code? If so, can you please post a small example including the compilation output?
  • Mat
I made a very small .f file.
ftest.f:
program cuda_test
use accel_lib
real a,b
a=1.0
b=1.0
call acc_init( acc_device_nvidia )
!$acc region
do i=1,50000
a=ab
enddo
!$acc end region
write(
,*) a
end
pgfortran ftest.f -ta=nvidia -Minfo
(nothing appears)
./a.out
1.000000
pgfortran ftest.f -Mfree -ta=nvidia -Minfo
cuda_test:
9, Loop is parallelizable
Accelerator kernel generated
9, !$acc do parallel, vector(256)
./a.out
launch kernel file=/home/tiomiya/test.d/./ftest.f function=cuda_test line=9 device=0 grid=196 block=256
1.000000
If I rename the .f file to .f90, it shows the accelation massage too.
But most our programs are in f77 format and must be fix to make them free format. If I use -Mfree opinion, lots of Syntax error will occur.
Is there something wrong in my usage?
Hi tiomiya,
Directives must start in column 1 when using Fixed format, otherwise they turn into inline comments.
For example:
% cat test.f
        program cuda_test
        use accel_lib
        real a,b
        a=1.0
        b=1.0
!$acc region
        do i=1,50000
        a=a*b
        enddo
!$acc end region
        write(*,*) a
        end
% pgfortran -V10.2 test.f -ta=nvidia -Minfo -o a1.out
cuda_test:
      8, Loop is parallelizable
          8, !$acc do parallel, vector(256)
Hope this helps,
Mat
It helps a lot.
Thank you for solving my problem. :)
