Couldn't create the docker image for deepstream.
I have installed the nvidia-docker to implement the system in a docker image.
The nvidia-smi command runs just fine and I hope the docker is installed properly.
but as I try to issue the command for deepstream in the docker as per the instructions using :
$sudo docker pull ncr.io/nvidia/deepstream:18.11
I will get,
Error response from daemon: Get https://ncr.io/v2/: dial tcp 178.128.155.112:443: connect: connection refused
How exactly this error can be debugged?
I got the same problem too at 19:06 UTC
@abramjos,
have you solved your problems about this error response?
I have not solved it and look for sulotion.
Not yet. I think its not a trouble with us.
Well it was my mistake,
you have to come over nvidia cloud service and then get the link to pull the deepstream docker. Stupid me :?
Here is the link: https://ngc.nvidia.com/catalog/containers/nvidia%2Fdeepstream
@abramjos,
I found it,
if you could visit the website (maybe an account needed):
and search deepstream,
you would find that the
docker command line is wrong,
the right command line is :
docker pull nvcr.io/nvidia/deepstream:3.0-18.11
and deepstream for 360d is on the same page if you search the key word deepstream,
ahah,
we found it at the same time,
