Couldn't find dgx-spark hotspot in the initial setup
Hi, I tried to use a laptop and a phone to connect to the Spark’s Wi-Fi hotspot for the first-time setup. But both failed, because the spark-xxxx hotspot is not found.
Does any meet this issue before?
Look for the exact SSID printed on the sticker with the Quick Start Guide, not a generic spark-xxxx name.Unplug everything except power, wait a few minutes after power-on and scan again.
If the unit was set up or tested before, for example by the seller, the hotspot may not come back. As far as I know it only exists until first setup is finished.If it still doesn’t appear, skip the hotspot and connect a monitor, keyboard and mouse. That’s the other official setup path: Initial Setup - First Boot — DGX Spark User Guide
