I was following the instructions on this page ( Modulus Extension — modulus_ext 103.0.0 documentation ), and I’ve been trying to use the FourCastNet and FPGA Scenario from Modulus, I was able to install the Modulus Core and the Scenario extensions successfully, but while I toggle the enable button for any Scenario, I am getting the following errors.
2022-10-11 01:40:02 [29,710ms] [Error] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: [kit/public] Can't find archive for: 'modulus_ext.ui-2.0.0+cp37'.
2022-10-11 01:40:02 [29,710ms] [Error] [omni.ext.plugin] Failed to pull extension: 'modulus_ext.ui-2.0.0' in '/home/aswinkumar99/.local/share/ov/data/Kit/Create.Next/2022.2/exts/3'.
I also fiddled around with the links, as mentioned in the manual on what to do when the install fails, but it seems like the extension package does not exist or the link is broken.
