Couldn't run deepstream sample app using nvinferserver inside a docker container
• Hardware Platform (Jetson / GPU): Tesla T4
• DeepStream Version: 6.4
• TensorRT Version: 8.6.1.6-1+cuda12.0
• Issue Type( questions, new requirements, bugs): bug
Hi, this is what I did to run a sample DeepStream app which is using Gst - nvinferserver. To run inside a docker container.
  1. I followed the instruction provided in the readme file of this repo deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
  2. I mounted a folder where the python and config files are added from the given github repo relevant to the app and some necessary files which are in the common folder deepstream_python_apps/apps/common at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub, which are used to run the app.
  3. inside the container I installed all the requirements using the commands given in readme file:
And I then try to run this command
python3 deepstream_test1_rtsp_in_rtsp_out.py -h
But I got this error
> root@ip-192-168-2-157:/opt/nvidia/deepstream/deepstream-6.4/fast-api/NVIDIA-AI-IOT deepstream_python_apps master apps-deepstream-rtsp-in-rtsp-
> out# python3 deepstream_test1_rtsp_in_rtsp_out.py -h
> Traceback (most recent call last):
>   File "/opt/nvidia/deepstream/deepstream-6.4/fast-api/NVIDIA-AI-IOT deepstream_python_apps master apps-deepstream-rtsp-in-rtsp-out/deepstream_test1_rtsp_in_rtsp_out.py", line 23, in <module>
>     import pyds
> ImportError: libpython3.8.so.1.0: cannot open shared object file: No such file or directory
I checked the pyds version
out# pip show pyds
Version: 1.1.8
Summary: Install precompiled DeepStream Python bindings extension
Home-page: nvidia.com
Author: NVIDIA
Author-email:
License:
Requires: pgi, PyGObject
Required-by:
So I upgraded using this command
> pip install --upgrade --force-reinstall pyds
Now the pyds version is this
out# pip show pyds
Version: 0.2.0
Summary: A Python module to read, write and manipulate PDS labels.
Home-page: https://github.com/jashandeep-sohi/pyds
Author: Jashandeep Sohi
Author-email: jashandeep.s.sohi@gmail.com
License: GPLv3
Requires:
Required-by:
Then I again ran the command it gave some output regarding the usage of the app
so I tried to run the server by the commands given in the readme file for nvinferserver
  1. run a .sh file to prepare the triton model repo
/opt/nvidia/deepstream/deepstream-6.4/samples/prepare_ds_triton_model_repo.sh
  1. run the app by modifying the following command with an rtsp url
python3 deepstream_test1_rtsp_in_rtsp_out.py -i rtsp://sample_1.mp4 rtsp://sample_2.mp4 rtsp://sample_N.mp4 -g nvinferserver
The app started running And now I am getting this error related to pyds
So I need to know why this bug is something internal or not and which pyds version do I have to exactly use to avoid this error.
It is better to build and install pyds according to deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)
