Course "Get Started with Deep Learning" don't show ( it said "apps.learn.learn.nvidia.com refused to connect")
I also have the problem when i am trying to give feedback for the course. it shows “apps.learn.learn.nvidia.com refused to connect.”
Hello, we encountered a bug that caused all courses to exhibit this behavior. We have reverted the changes that caused this issue, so you should be able to access the course contents now.
Hi, I also have this issue. Could you help please?
I facing the same issue.
I also get this error ; learn.learn.nvidia.com refused to connect.
No Solution so far.
Getting the same error here: Building RAG Agents with LLMs Online Course
However, when I logged in through Log in | NVIDIA Developer and then accessed the training, the error didn’t occur.
I also have this issue starting the segmentation course " learn.learn.nvidia.com refused to connect."
Please help find a solution.
Hi @botros.jm, thanks for your message. Please could you reach out to the Deep Learning Institute team on dli-help@nvidia.com to get your problem resolved. Thanks!
Same issue learn.learn.nvidia.com refused to connect. Please have this fixed asap
Hi @geetmenon which course are you trying to access? Thanks
" learn.learn.nvidia.com refused to connect." Can you fix this. Trying to access Generative AI Explained
Hi @karthikkotharkar29 please can you try again from a private browser and try logging in from this link? Log in | NVIDIA Developer Thanks
Sophie
same for this course
Introduction to Transformer-Based Natural Language Processing
